Eugenio Treviño
About Eugenio Treviño
  • Birthday 11/09/1966
  • Gender
  • Location
    Monterrey, Mexico
  • Interests
    Philately, cactus, Mexican coins, modelism, nature.
878 profile views
  1. https://www.archyde.com/ancient-anchor-found-in-the-port-of-progreso-in-yucatan/ A recent discovery in Progreso port in Yucatan, Mexico. I hope you like it. Best regards to all !
  2. This is the link for the news. Best regards to all.
  3. Today, after 9 months, I have reached what I consider my second milestone. Finishing the HMS Victory’s hull and all its structures. I am very happy with the result. Of course it is not the greatest Victory model, but one I am really proud of. I have learn a lot and overcome a lot of difficulties. Now the third and final stage will begin. Masting and rigging. I have no idea how I will do it, but I am decided to do my best to accomplish the task. Here are the picks!!!
  4. Nicolas thank you very much for your kind words!!! Congratulations for your new home! Fortunately my professional activity has come back to a more normal situation, so my time for the build has been reduced significantly. Nevertheless today I reached my second milestone and I am very happy with the result. I will post the pics next. Best regards!
  5. Hello friends. The fore channel’s deadeyes have been set. Not so satisfied with the port side, but after some practice the starboard side turned out much better. Here are the picks. Best regards.
  6. Hi Robert: I hope you are doing great! I have been away from my build for some days, but hope to re take it next week. Have you worked in yours recently? Keep us posted! Best regards.
  7. Sheerline: Your solution for the galleries’ windows is fantastic. I liked it very much! Keep up the great work! Best regards.
  8. Hi everybody! All channels are in place now. The only structures I see on the plans are still missing before starting with the masts and rigging are the boats davits; but I think I will do them at the end of the build. Best regards!
  9. Hi everybody! These past few days I have had less time for the build. So I could only do the main channels and de boomkins. I am surprised how solid the channels set. I hope I will not break them while rigging. Here are the picks! Best regards.
  10. I have installed the starboard mizzen channel. A tricky job but, thanks to Pythagoras, I could installed the supports on the first try and it feels really solid in place. Now I can tell my oldest daughter that you do use math in real life! The vertical strakes were also set. Now I have several pieces ready for varnishing. Here are the picks! Best regards.
  11. Hi my friends!!! Today I finished installing the side ladders. I just need to apply varnish. A few things more and I will be ready for installing the channels and start with the mast and rigging. Here is the pick! Best regards.
  12. Nice job Robert! Have you glued them poop deck? If not, please do not forget to remove the deck beam there. It helps as support, but the height of that area (between the two decks) will be not correct if you keep it. Check the attached pick of my Victory. I didn’t remove it and it is not correct. Best regards.
  13. Valeriy thank you very much for the information! Nice postcard with those Japanese post stamps of their 1913 definitive series. I collect post stamps (specially Mexican stamps), so two of my hobbies are represented here. Do you know if there are models of any of those ships, either wood or plastic? It would be nice to build one. My best regards to you in Ukraine!
  14. It looks very nice Robert. A good smooth surface will help a lot with the second planking. Take your time. A pair of planks on each side per day is enough at the beginning. That will allow you to check a correct positioning, alignment, tapering and glueing. I am sure you feel much better today!!!
  15. Hi everybody! Netting has been completed! I also worked on the poop kevels and the channels. Here are the picks. Best regards.
