allanyed
Posts posted by allanyed
  1. Hi John,
    A warm welcome to MSW to you.  There are alternate routes to get to your destination.  Study the build logs, both kit and scratch to get an idea of what is available and what might meet your needs and desires.  One of the best series, if not THE best for a beginner is the three boat series designed by member David Antscherl.   https://modelexpo-online.com/Model-Shipways-Shipwright-3-Kit-Combo-Series-with-Tools-Glue-and-Paint_p_5290.html
    Good luck!
    Allan
  2. I love bamboo for treenails, but would go with another species for oars.  Even then, a draw plate does not work for me for oars as they are shaped as in the pics below from Steel which I hope you find helpful.  I realize the shapes were likely different from boatyard to boatyard and era to era, but I cannot find any contemporary information prior to Steel's information.
    Allan
    Oar Scantlings and oar making.doc
  3. 2 hours ago, Bob Cleek said:
    The above "stowed" options may warrant more research as to the exact practice common in a given navy at a given period. I included these for the sake of completeness. Although cannon depicted as rigged for sea are rarely seen on models today, they can be a lot less work to model than gun stations rigged for action
    Lots of options including the three below.  From The History of British Sea Ordnance Volume 2, page 382.  He gives the following description of each.
    Illustrations of breechings and gun-tackles on a 1795 pattern carriage, redrawn from Congreve's Treatise on the Mounting of sea Service Ordnance.
    Top: gun tun in.  Center: gun run out and secured.  Bottom: gun run in, secured, and housed.
    Allan
  4. 5 hours ago, DaveBaxt said:
    My primary reason for buying , was for the construction of the Frigate Minerva and learning something about plank on frame and scratch  building.
    HI David
    I have 17 photos that I took of the model of Minerva (38) 1780 at Preble Hall in Annapolis and would be happy to send them your way if you wish.  The description card they had for her in 2011 follows as well as a closeup of her planking at the bow.
    AllanMInerva1780AAA.thumb.JPG.7ef392e12809e6e8878faca62b303582.JPGMInerva16.thumb.jpg.d9845a64de2850851e32514f98fae29d.jpg
  5. Very interesting point and your test group is a great idea.   To add to any confusion that there may be James Lees mentions that the footropes or horses were 2 feet under the yard on page 69 of The Masting and Rigging of English Ships of War, but then on page 70 goes on to say that the stirrups should allow the footropes to hang 3 feet below the yard.  Looking at the photos below, this makes some sort of sense.  Where as the stirrups were probably pretty much the same on a given ship, not all seamen were the same height so maybe topmen assignments were partially based on their height just as strength was a consideration in assignments.  The below are photos thus obviously more modern times, but may fit the discussion.  Hopefully the sailors between the stirrups were the taller ones.  😀
    Allan
    Topman2.thumb.jpg.aeb271a06a9e2b9aa453f8c87eea2887.jpgTopmen.jpg.29622a545db098e63d40932ebac54901.jpg
  6. Overall really nice model and your metal work is some of the best we have seen.  For the future, in the past couple years, thanks to builder/author Ed Tosti, for some parts I have found copper to be better suited than brass.  It solders very nicely and can be blackened instantaneously after being  fixed in place on the model with diluted liver of sulfur then rinsed without staining the wood.
    Allan
  7. On 4/6/2024 at 7:28 AM, DaveBaxt said:
    There is also an additional 2 holes for the outer eybolts for swinging the cannon fore and aft.
    This is really interesting and great that you included it as it is not often seen.  Lavery discusses it briefly in the Arming and Fitting of English Ships of War on page 143.   He states that by an order of 1779 additional eyebolts were to be fitted between the ports to give extra leverage to the side tackles, when the gun was being trained.  It is not clear to what extent this order applied, or how long it lasted.
    Allan
  8. Bonjour Alain
    WELCOME TO MSW!!!    It would be nice if you posted a little intro in the new member forum here at MSW.   I don't think you are supposed to post your email address.  I am sure a moderator will remove it as you may get spammed if it is left there.  If it is in your profile, members can find it or PM you.
    Regarding your question, what era, what type of vessel, which mast, what nationality?   Are you talking about the hoops on the top and bottom of the wooldings or the hoops to which sails are attached on a schooner for example?
    Again, welcome to MSW
    Allan
  9. On 4/6/2024 at 10:55 PM, hamilton said:
    I didn't use any of the kit-supplied planking except below the wales and I also didn't use those metal gunport frames, but framed out the gunports with scrapwood..
    Hamilton,   Kudos for going the extra mile/km.
    Tennfox, many are happy with what the kit provides, which is great, but some are interested in going a bit more in depth.  The dimensions of virtually every piece of your ship is in the 1719 Establishment.  Many of these are inconsequential when viewing the finished model, but some are quite noticeable. These can be found at RMG and in several books if you are interested in this kind of information for now and in the future.
    Allan
  10. 9 hours ago, druxey said:
    For the main part of the process I will loop the end of the shroud up (once it is in place over the masthead)
    I will definitely try this Druxey.  Am I correct to assume you do something similar with a swifter as you do for a paired shroud.   With the pairs, reinstalling evenly seems like it would be pretty easy, but for a swifter is the loop at the mast head done first so it can be removed like the pairs?   Or, do you find it easier to just secure it at the mast head after the deadeye is seized  so it is line with the other deadeyes?   (I am on the road so could not check if this addressed in TFFM IV.😀)
    Allan
  11. BE
    The Construction and Fitting of English Ships of War, pages 108-110 go into this is some detail.  There were either two or four transom knees depending on the size of the ship.  (He also mentions there were exceptions with some ships having an odd number of knees based on contemporary models.)   In short the transom knees (standards) were to add strength to the transom as well as give support to the tabernacle for the flag staff as you show on your model. The fore and aft arm was sufficient to span 3 deck beams and the vertical arms terminated just below the taffrail.
    Allan
  12. Found this on line.
    Creating an Original Plug
    When beginning the process of creating an original plug, you must first determine the type of material that will be used. Plugs can be created from a variety of materials, as long as they are dimensionally stable. These materials commonly include wood, MDF, clay, SMC, foam and balsa. If the plug is to be made from a porous material such as wood or foam, the surface must be sealed with a resin or primer. #1041 Duratec Gray Surfacing Primer is ideal for this application and will be discussed later in this article. Plugs need to have a slight taper so that the mold can be easily removed. Typically, a larger plug will require more rigid and reinforced materials.   From https://www.fibreglast.com/product/Plug-Construction-Guide
  13. On 3/31/2024 at 2:53 PM, Pirate adam said:
    I used black tissue paper
    I have used black tissue on deck planking with good success.  For other joints such as scarfs an alternative that I have found to work very nicely is to add a drop of black acrylic paint to a puddle of PVA glue, mix and apply.  These joints have held up for many years so I am confident the little bit of paint has not weakened the joint.
    Allan
  14. 1 hour ago, wefalck said:
    anyone with a good tool-grinder could make such tools from round HSS-blanks.
    I usually agree with you Eberhard, but on this one, not so much. 😀   The smallest U chisels would be a challenge for 99.5% of anyone trying make these.    These are exquisite chisels that would take someone with lots of experience and time to make a set as well made as Mihail's.    Maybe some member could take up the challenge which would be fantastic.😁
    Allan
