Posts posted by HIPEXEC
I discovered that after all the glue dried and planks dried out, one gun port warped, and is not aligned with the next gun port from a bird's eye view. This will cause a problem down the road when I will have to mount the final top rail to the gunwale. I am fabricating a fore & aft, top to bottom tapered plank to glue in place to make the alignment. I will make the tapers fine enough so that it will blend very nicely and only need a small amount of filler to make the fix invisible. Then I will shave the inside planks to make it conform with the whole gunwale.
Here's a picture of both the lower and upper gun ports using my method of pre-cutting the planks. As you can see they are nice and square even before filing and sanding. If I had to drill holes in the corners and try to cut them all even and straight....what a mess you would see. I don't have the skill to make good cuts.
Sjors,
Yes, I pre-cut the planks to make the gun ports because I don't like my skills at cutting into the hull and still have straight and perpendicular holes. Here's a picture of the port side with full planks. There's only a small support plank to fit on the inside until I add the rails much later. I'll have to be careful handling the hull until all rails and trim is in place since these upper ports have no top support yet.
- augie, CaptainSteve and Sjors
- 3
First of all, you should know that planking is hard and tedious. Each plank must be treated like a separate model since each plank sits differently on the hull. Planks must be shaped, bent, twisted, tapered, beveled, cut, etc. However, when you finally plank your hull, you will feel like a million dollars. The tutorials on this website are very good. So is the advise you will get from members. Pretty soon you will be inventing your own methods that suit your talents.
Good luck.
- mtaylor and CaptainSteve
- 2
As far as plan errors go, My Constitution had a few. It's a Constructo kit. I looked at other kits and actual photos of the Constitution, as well as asking MSW members what to do. I took their advise which was to use my own head to figure out what to do. I just used common sense, but it is frustrating. I have probably deviated a dozen times from the their plans.
I'm going to enjoy watching your build log for your USS Constitution. Good luck.
I like your plank holders. What are they?
Geoff,
What's the best way to drill the holes on the deck for the three masts? On my first build, I had a devil of a time to get the masts (only two, not three) to line up fore & aft, and have the same rake. In the Connie's case perpendicular.
Thanks for the memories!
Starboard side, next course up is finished. The kit called for me to set all the planks for the gunwales in place, then cut or saw the gun ports. I experimented with my blades, mini saws, etc and it was a mess. I decide to go up by pre-cutting the planks with nice, clean, right angle cuts using my plank cutter, and put each piece in it's place that I pre-measured. So far so good. It will just take some minor filling and sanding/filing. to make the upper planks as smooth as the lower planks.
I like your workmanship. I shall strive to do as well with my Constitution.
Good luck! I just finished planking the main hull on my Constitution. You're right... it's a challenge.
I just glued on the first plank to go up from the deck. This was the most tedious, longest plank prep I've had to do for any plank...and believe me some of the previous planks drove me crazy. This one is the port side plank. I've pre-bent the starboard plank, now when the glue dries on this one, I'll shape the starboard plank in place. These two planks will be the only ones to go on in one piece. The rest of the four courses up will be custom cut to make the gun ports, anchor ports and stairway ports. The pencil marks you can glimpse on the deck are where these ports will be located. I used the plans, photos and my electronic micrometer to pre-locate where they will go. I used this method when I did the below deck gun ports with great results. The plans call for me to glue whole planks and cut the ports. My cutting skills while planks are in place are terrible. I can used my new, very sharp plank cutter to precut all the rest on the pieces.
Pretty darn good for a first build.
Marking and cutting of planks
in Building, Framing, Planking and plating a ships hull and deck
I bought a plank cutter which does a lot of the cuts required.
