Posts posted by rumbeard
Now for something different. A temporary diversion from Conte Di Cavour. Found these guys online and wanted this ship and Queen Elizabeth class ship for a while. The manufacturer no longer has them available but I found APO Brick a Lego and brick reseller had them so I ordered the two ships. Here's Lützow the Deutschland class pocket battleship. You can see our jerky cat trying to help me in pic 4037
- Ryland Craze, Canute and mtaylor
- 3
- GrandpaPhil, mtaylor, ccoyle and 2 others
- 5
- yvesvidal, GrandpaPhil, Canute and 3 others
- 6
So many learning experiences. After all hope was almost lost I hit on a close-enough match for the grey. Here I post finishing prop #2, re-doing green, using this amazing product Mr. Mask Sol (a paintable rubber that rubs off with a finger pad) for portholes, touch-up including overspray mistakes, and more. The UA617 Italian Anti-vegetativo Verde Scuro is a new bottle. I notice black is a component of this paint as it settles. I tried touch up with a brush and either the new bottle is slightly different in color or it was the thickness of the green when I thinned it for airbrush as it showed a different color streak where I touched up. I tossed the old airbrush green and mixed up a fresh thicker batch and applied it for great success. Lastly I've started touching up the candy cane deck.
- mtaylor, GrandpaPhil, Canute and 2 others
- 5
Finishing up hull bits
Here are a bunch of the greebles for the hull: Rudders, prop shafts, props, bilge keels, etc. Once attached (the other side), I'll remove the prop shafts and mask and touch up the green. Then mask and do the black waterline. Finally I'll work some more on my gray and do small blends with the airbrush (this will be trickier). I will also need to touch up the deck zebra stripes as I did a bit of sanding where the side hull joined the deck. -
So I'm looking for some input here. I've reached the stage where I'm going to finish the hull and start on the super-structure. Some things are obvious that I need to do (e.g. sand one hull seam and re-paint, add the chines, props and rudders and paint, putty the stern crack and bow above the waterline and touch up. I spent two weeks and 3 bottles of white paint trying to color match the grey and I think I'm very close. I need just a touch more white. You see this in one of the photos. The main thing not sitting right with me is some slightly sloppy glue work where either a porthole is sitting on a bulkhead and I have wavyness at the stern or one wave at the bow because there's a bow in the plate. Suggestions on how to fix or reduce the look? Also would like suggestions on if there's a mostly transparent darkening wash people would use for weathering that would hide grey touch up even better?
Punch & Die tool making 220 porthole windows from a scrap from a Paw Patrol toy package. Also trying to match the grey paint which is not the same as the grey in my RN Lifecolor kit. I ended up getting super close but the grey was too warm (yellow greenish which I could see in bright sunlight). I bought some Azure Blue and added 1 ml, so the total mix is Silber Grau (Lifecolor Kriegsmarine set) 10 ml, 19ml Lifecolor flat white, 1 ml Azure blue
Hull coming along. I messed up the other side of the fantail because I glued a PE door too low, so it will need touch up and it's slightly wavy but I think I can fix this OK.
And the thing that tipped me over the edge was a note from a papermodelers forum member pointing at the really cool site: Forums - Betasom - XI Atlantic Submarine Group which has a lot of history on it.
Moravia Boya ve Kimya San. Tic. Ltd. Şti. (moraviapaint.com) - Still in business. Started in the 1860's in Trieste
From this: Quite a few early 20th-century anti-fouling paint used iron oxide, thus the red color. The Italians used 'Italian Moravian' which had copper sulphate, thus the green. I figure it's just convenience, since the Italian used their 'Italian Moravian' while other countries continued to tinker with their paint.
Also they had the first layer red but the final layer green.
Tashkent's Keel: Why Green? - Battleship Era - World of Warships official forum
- ccoyle, mtaylor, GrandpaPhil and 4 others
- 7
- Richard44, GrandpaPhil, Canute and 5 others
- 8
Queen Elizabeth by rumbeard - Panlos Brick - 1:300 - Lego sized bricks
