Charley54
Posts posted by Charley54
Ok, here we go - Chapter 4 - Stern framing.
Just following Chuck's great directions. I, like everyone else, have discovered how absolutely fragile these parts are. Do not even look at them very hard- they will crumble. Other than that just A, B, C ...........
Now just let the glue dry- Sills and lintels are next
- JesseLee, fnkershner, Sjors and 3 others
- 6
Finally, an update. Real life seems to keep interfering with important things, like working on my Syren, but I have made some progress over the last few weeks.
First, a picture of my MicroLux pen sander which has become indispensable to me. I love this tool. It has really taken away much of the drudgery of sanding for me. Just my opinion of course.
And a few more pictures of my more completed framing. I can not seem to stop tweaking, here and there, but I am almost satisfied.
Now it is on to stern framing. Actually it is already complete. I just have to catch the log up to current state. More pictures in a few minutes
- JesseLee, fnkershner, Nirvana and 3 others
- 6
It looks much more precise than the filler method. No spread through the grain of the wood. Nice close up's. Hmmmm..... I just dont know if I have the patience.
Really looks cool Meredith. What gauge of needle did you use?
Charley
Todd- Checked my kit for you and I see what you mean. I have 5 pieces total for the boat and in the picture it looks like there should be 5 lifts plus a bottom. Hmmm.... inquiring minds want to know........
As for the variation in the vertical framing.. I just made sure that the framing plan was lined up on the last bulkhead and then made small adjustments as I installed all the remaining frames. I think it came out ok for me.
Ive been working to much the last couple weeks so I havent been around as much as I like but your Syren is looking good!
Charley
Thanks for sharing your process, Richard. In reading ahead in the instructions- I have gone over this several times but still was not sure. Your pictures help. Syren sure looks fine when she gets her cap on. Looks great.
Charley
Dont worry Robbyn I stole the idea for the spacer from someone else , Dirk- I believe. I was using the syringe that day for alcohol because I had to redo those frames. It didnt work very well, too big of a syringe and needle, I think. I subsequently switched to insulin syringes with 31 guage needles and am able to control flow much better and get the alcohol right where I want it.
If nothing else, I am getting really good at taking things apart after gluing them together
Floyd- I am going to check out that Chopper thing
I finally finished the rough framing. All of the green, red and blue frames are done. I still have some sanding to do just to get her cleaned up like the lady she is .
I have found I definitley need to work on my cutting skills. I struggle to cut a clean straight edge and angles are an exercise in frustration. I am using an Xacto miter box and razor saw but even so I find a lot of play in the slots. It may be time to put together some kind of jig. Here are a few pictures of progress to date.
Happy New Year !!
Todd- I sent you a PM with copies of the Templates that Chuck sent to me just in case.
Charley
Hi Todd. I will be following along. Good start. I had a time with the insides of the framing also. I got better as I went along.
Charley
Thanks for the support guys. I still have plenty of sanding to do. Im not sure how far down I should go on the grit size of the sand paper at this point, since this is all sub-structure that will be covered up.
I am pretty sure that Santa is bringing me one of those microlux mini sanders so I am hoping that will help me in that regards.
Thanks for stopping by
Charley
Ahhhhhhh..... there it is. I love those last two side views. The deck is beautiful. It fires my imagination. It had to have been a time tested design based on function and the will of the men who used this ship so succesfully. I can already see the masts in my minds eye. Great work John.
Happy holidays to you and your family
Charley
Hey Richard- I checked through my kit and I see what you mean.I dont see any specifically supplied wood. I looked at Dirk's build log and see that he cut his out of some after-market pear wood. I wish I could shed some light on this. I havent made it nearly this far yet but I will be very interested in the pending solution.
Charley
Green frames ( gunport sides) are also done. Pretty straight forward. Measure, cut, sand to perfect size with excruciating care, glue, wait to dry, come back and decide I dont like it, take out then repeat till I finally decide- enough is enough . I can't lie though. I am enjoying every minute of it. I have never found anything that takes my mind off "stuff" better than shipbuilding. Cheap therapy
Anyway gunport sides are all in and sanded and I am on to the frames that define the sweep ports.
I also wanted to say happy holidays to everyone here on MSW. I hope it is a good time- each in your own way. Thanks for being here.
Ok finally a small update. Sills and lintels are all completed. Had to re-do a few. Seems like every time I walk away then come back they move
Yessss...I have taken my medication today but I swear every time I stop working then come back after awhile I see some small error in a spot that looked perfectly fine previously. Anyway I have mastered the art of using isopropyl and debonder. I think you guys are rubbing off on me.
A few of the tools I use and a few pictures of my progress -
Augie- I just re-worked the idea for the spacer from several other builds I have seen on MSW. Someone always comes up with some little way to deal with most challenges. So many great ideas. As for the covering- I have my iron right here along with my heat gun on the shelf---sigh....but I think it would not be the same . Thanks for checkin in
Larry- I am so used to trying to make everything look old and beat up. I am just not happy if I am not trying to weather something
Their are a couple things I may have done differently on the framing that I have done so far
First - I would have faired each set of frames sills, then Lintels after I completed each run, starboard then port, as Chuck suggested.
Instead, I completed sills and lintels on the starboard side then sanded the whole thing. I think this made it more difficult.
Second - I would not have glued the frames in place with so much inboard exposure ( if that makes sense). I have found it veryy difficult to sand inboard as opposed to outboard. ....duh . If anyone knows any tricks, let me know. I almost done with the starboard side ( it has taken me forever) but I still have to do the port side.
Its been a very busy week.....but....back to framing
I made a 15/32 plug to help with lintel spacing. I am trying to make the change to PVA glue but it is hard. I have become so used to CA. I like to make things fit then run a little thin CA in a tight joint- then its done. I have built to many wings I guess.
So, I have used PVA on some of these and CA on others. Of course the CA will be a problem when trying to stain but the frames will all be covered anyway so I am using this as a learning experience. Unless? I wonder if they make a wood grained Monokote?
I could do one quick planking job
Really nice work though John. What you did looked really outstanding. Heck to me the one in the real ship picture looks almost to large, although I am certainly no expert. I guess its just a reaally big skylight.
You know, maybe its the picture, but to me the bottom looks closer than the top.
I admire your dedication. My skills are a long way from accomplishing anything like this.
OK Richard I think Im liking it. Looks good. So, off to home depot I go to get pre- stain and natural stain. Thanks for posting all of this. It is going to save me some work.
US Brig Syren by Charley54 - Model Shipways
Posted · Edited by Charley54
Continuing Stern framing- Chapter 4
Using 3/16 x 1/4 basswood sills and lintels are added using the template provided
The rest is cleaning up and sanding smooth.
Next will be filling below the counter
