Posts posted by Old Collingwood
I could resort to plan num2 - build her as a High Altitude IX in overall Ocean Grey with just the sea grey underneath, that could work and would still be viable and No masking for camo.
OC.
- Canute, Edwardkenway, mtaylor and 2 others
- 5
I'm just a bit fed up at the moment - fed up and angry at the way the world is right now, and my build is supposed to be some light relief to de-stress its actually having the opposite effect making me tense and wound up.
I will sort it (probably wont be as first intended) but it will be built - remember the Yellow Subamrine song? nah only joking aint gonna paint her yellow - Pink she will be.
OC.
- Egilman, mtaylor, Edwardkenway and 2 others
- 5
7 minutes ago, Egilman said:
Ok another question?
Why?
What I would do is find a decent sized cardboard box that can be knocked down when not being used, use it to place your model on when painting therefore you do not have to touch it when painting and you only have to control the paint not both paint and model at the same time.... when done painting knock the box down flat and slip it into a closet.....
Dont have anything to hand like that - I see how easy it is with painters using those turntables hand free painting, I always seem to rush the painting as I am battling either against wind we get funeled in our patio or dodging showers or insects due to heat.
OC.
- Canute, mtaylor, popeye the sailor and 1 other
- 4
I'm just so off the idea of having to have to re mask the whole thing all over again - it feels like a chore (even a head ache) almost dont have the interest tempted to just spray over it in one colour and pretend it was ment that way.
Thankfully the seafire is more straight forward just Sky underneath and dark grey ontop.
So glad my other builds I brouht ages ago are single colour builds no camo patterning.
OC.
- popeye the sailor, mtaylor and Canute
- 3
16 minutes ago, Egilman said:
The whole point of masking the way you were is to keep a clean demarkation between the different colors but create a fade over effect in scale between the colors. (it's called feather edging) Extremely hard to do with an airbrush alone.....
It's only my opinion my friend, but it's too rough an edge, there wouldn't be that much wear and tear on the paint, especially in the areas where it's showing greatest... the edge between the colors would remain feathered but still very clear....
To be honest I was very dissapointed by the finish and without a doubt its down to my less than clinical masking as there are some quite tight turnes using the blue tack - the idea is to roll the it into long worm shapes then press it down onto the fuselage/wings, then cover the part not to be sprayed with either paper or tape, the other difficult thing is the holding the plane without touching areas to be painted - for this I try to attach a stick underneath held in place with lots of tape, then there is the control paroblem using a blast from the Rattle cans, its too fierce and if you go to close to make sure the camo lines are filles - then it can buld up causing runs.
In hind sight it would have been better if I could have masked and painted the fuse and wings seperate like I did the mossie as there was more surface area to work from that way.
I guess I am Always going to have these issue having to use the methods and equipment I have to use - its a viscious circle with no rememdy.
I see people using fine air brushes and I am so jelous and envious and know its whats holding me back - that and not having a man cave or even shed to use use.
OC.
OC.
Evening all, more work on the Spit - first I stripped off all the masks and examined the camo closely, I decided to use some fine wet and dry and give the whole thing a gentle sand over - I then noticed that I was fading the camo and giving the whole surface a worn appearance with a few areas where the primer is showing - question does it look normal or should I touch up the paintwork, not forgeting I will be shading the panel lines and high lighting, after the decals are on.
OC.
- cog, Edwardkenway, Canute and 6 others
- 9
Another interesting build - loving the variety on here at the moment.
OC.
Looking mighty fine Denis - really showing the definitive shape of the Fortress.
OC.
- mtaylor, Egilman, popeye the sailor and 3 others
- 6
Superb - so much detail.
OC.
- popeye the sailor, CDW, Jack12477 and 3 others
- 6
1 minute ago, Egilman said:
Just a suggestion brother, don't forget the starboard 20mm cannon, will look kinda strange with only one....
Yep the housing for that is yet to be put on, the one you see is the bare barrel of the other, they are fiddly (easy knocked off thingys) I have learned that on my other Spit build - I knocked it off twice almost like the glue wasn't holding it strong enough.
OC.
You will be "cooking on gas" my friend - hope you have enough hands.
OC.
I have been into cameras for many years probably had more cameras than my age 😲 I have inherited a camera off my neighour but to be honest my best tool for model photography is my mobile phone camera, as it slim and can get it underneath the actual plane to get shots looking upwards (you could not do that with a lens) but no doubt any decent camera would take better general photos of the model due to quality of optics / pixals etc.
OC.
- Edwardkenway, mtaylor, Egilman and 5 others
- 8
Slight update on this - I de - masked the camo, it didn't come out too bad but neded a few areas of gentle re spraying - so it was a case of stage by stage re masking where I dont want over spray to go, I started by covering most of the plane in a plastic bag then ran some lasking tape to trap it - then more tape and Blue Tack to get a smooth line, then I touched up around the tail using Grey first.
I will remove the bag and move over the plane doing the same as there are a few areas that need the same work, practice makes perfect they say.
OC.
She is looking splendid Kevin - all that hard work is deffinatly paying off.
OC.
37 minutes ago, Jack12477 said:
Great finish, OC. Love the camo and overall color. Your Dad would be proud. Nice tribute to him
Thank you Jack - so kind.
OC.
2 hours ago, Egilman said:
I'm sure, if your dad was there, he would give you a hug.....
Beautiful tribute....... Beautiful job my friend...
Thank you my friend.
OC.
- Egilman, Canute, popeye the sailor and 2 others
- 5
So, where do you get this "Blue Tack"? that type of soft edge effect I used to do with sponges or elevated stencils......
this method looks so much easier....
Here you go bro, just a quick search in Flea bay.
OC.
- Egilman, lmagna, Edwardkenway and 4 others
- 7
Evening all - more progress this eve, I masked off the top edge of the wings, then the front slope on the cowl and the rear lower fuselage, then I used my Tamiya flast Sky and proceeded to hand paint it with my largest brush, I put about Four layers down dried in between layers with the hairdryer, will need the edges lightly sanding to get rid of the ridge.
OC.
1 hour ago, popeye the sailor said:
...a very interesting way to mask camo the methods are endless here........so far so good
Thank you for looking in on the progress Denis, yep the blue tack is supposed to produce a softer camo line due to its edge being further from the surface than like paper or tape would produce, and the paper/tape is just the cover over the painted camo, same system I used on the Mossie.
OC.
- Edwardkenway, Jack12477, mtaylor and 4 others
- 7
WOW!.......OC ...she came out great! few bumps along the way, but ya did it.........sweet looking plane and none the worse for wear glad ya stuck with it
Thank you for those kind words Denis, was certainly an up/down hill build mixed in with some "smile moments"
OC.
- lmagna, mtaylor, popeye the sailor and 3 others
- 6
Looking fine bro, thats a neat little build looks the part and nice and busy.
OC.
- mtaylor, Canute, popeye the sailor and 2 others
- 5
Looking smart mate.
OC.
- popeye the sailor, CDW, lmagna and 3 others
- 6
Hi all, a bit more work on the Seafire - like I said above the front under cowl needed some shaping as it was a bad fit, I attacked the area with a sanding stick then a bit of wet and dry followed up by a bit of putty, I also test fitted the spinner plate - I drew a line around the outside edge then after removing it I sanded the nose back to the pencil line.
OC.
- Jack12477, jwvolz, BLACK VIKING and 8 others
- 11
B-25J Mitchell by Tom E - Revell - 1:48 Scale
in Non-ship/categorised builds
Sounds like a plane Tom - both the food and the decal solutions.
With the micro sol Please - please be carful Not to mess with the decal after you have applied it over the decal, you will see some reaction on the decal - thats Normal (but you Must Not touch the decal till the micro sol has completely dried)
OC.
