Old Collingwood
Posts posted by Old Collingwood
  1. Hi all,     more work  today   -  next stage was to construct the main wheel well, this is made up of Four parts  and contains some good engraving like the front,    after cleaning up some of the edges (nothing drastic  - just where the pips from the spru were joined)  I  then did a few washes of dull white, then when dry  - same procedure with a dirty wash, then a bit of alum high lighting,   I then glued both parts of the front wheel well together.
    The airbrake  pit  them got a coat of flat alum  and a wash,   also  I glued the front fan to the assembly  and dry fitted against the front wheel well assembly.
    OC.
  2. I put the tub aside and going by the structions  - next area is the front wheel bay and  front fan blade assembly/surround,   the blade assembly trunking is one piece  and needed a tiny bit of clean up - then it received severa..............l  coats of dull white acrylic with a brush  (as I mentioned above)  I was aware of getting tiny specs of dust and hairs  on the paintwork  so I needed to keep checking for this, It will need a bit of a polish as its supposed to be a smooth almost satin finish,   next was the wheel bay  - this comes in two sections  to aid detailing,  so agian it was a case of putting down several coats of dull white,   then when dry  I ran a dirty wash of watery dark grey/black  and heated it with a hairdryer  (they were renowed for catching all the dirt and grime in there  - same as the main wheel bay).
    Oh,   and the fan blade received some flat alum.
    Here is a pic of the above on my mat after painting.
    OC.
  3. Evening all,   got some more good progress today   - despite it taking what seemed like ages to put thin paint layers on with hairdryer between each coat,  so  I put the HUD  on the pe frame  (fiddly is not the word)  as you can imagine not getting glue on the clear part was mission inpossible,  after it had  set  I tried to sand the glue out on the one side I could get to - then I tried the old method of polishing the plastic with tooth past (as you do with canopies,  it did a fairly good job  but still left behind some marks  (not a problem as the front screen will mostly hide this).
    So  - the tub is finished  with the seat glued down.
    OC.
  4. 3 hours ago, Canute said:
    I flew with a guy who ejected at a  high rate of speed. He was grounded for months, but eventually did get to fly again. Multiple waivers for stuff, like the special boot for one leg shorter than the other. Great guy, too. I forget what he was flying when he bailed out, but I knew him at Eglin, in Phantoms.
    The MB seat drogue chute was on top of the seat in the F-4 to slow and stabilize the seat. There was a barostat that senses a set altitude and we would separate from the seat with our seat kit and parachute. Think the altitude was 11,500'. Below that altitude, we just separated and the chute deployed. You guys are going to make me drag out my flight manual to check all this stuff. ;)
    Yep  - any "Selfies"  would be good also😃
    OC.
  5. Evening all  - so glad to see our refreshments have turned  up  - building is so much more fun on popcorn,    so  work continues  with the  cockpit tub  -  I gave the bang seat  a bit more weathering  really starting to bring the details out now,    next off was  the tub its self  -  I painted the side walls in flat alum  then gave the rest of it a mid sea grey wash in watery coats,  then I used a mixture of Black and  alum high lighting to bring the details out, same principle with the instrument panel and the rear plate,  I then glued them together  and dry fitted the seat  to check it out.
    Still needs the HUD, and a few other fittings.
    OC.
