Javlin
Posts posted by Javlin
My wife has been pestering me about a new table/nightstand type deal for the living room to go by her Lazy Boy.Well,I decided on a triangle base three corners,three braces(7") with three 1/4" stringers.The top will be an octagon with a basic quarter round.The woods I am using is my favorite Sapele(cheap African mahogany) is the main wood and minor is a Birch.I find my self when building pieces using the numbers of God alot like 3,7,8,10,12 and 13 the 12 tribes,apostles and Jesus.That formula lends itself to small pieces like this one and the last one,my way of honoring God in my work.I am pretty useless otherwise
The rubber band method works great for holding together pieces of wood of odd shapes learned it on tour in Lafayette LA one day from an old man maybe 10/12 years ago first time I have used it works better with ole bicycle inner tubes.The angles have been perplexing at times and just had to trust my math from back in the day when going to school for engineering.The Birch up front was somewhat of a Birch knowing all along relative angles exist/abound in the pieces on the table/floor think and one will persevere.I did not want to have to look at a 60' angle up front hence the solution.
- Canute, Haliburton, bruce d and 6 others
- 9
- Canute, GrandpaPhil, Landlubber Mike and 8 others
- 10
- 1
I have been having the sense to build OOB of late like the Mig-3 of late just trying to build something that looks somewhat half way decent to the eye.I will dive into some of the 1/32's that deserve it and do full build logs but here it will be mainly 1/72 and 1/48 that just happen to hit the desk to fill the gaps in-between a full log.
I think he's using .17HMR cases cut down looking good Craig
- NavyShooter, mtaylor, Old Collingwood and 3 others
- 2
- 4
We've gone from raised rivets as a kid to engraved smooth as adults and now seniors/kids sometimes back to raised rivets again
In all honesty looks really good Rob I was wondering about the silver so another coat of gloss black?I await the final results.
4 hours ago, CDW said:
That came out real nice Kevin
Thanks Craig it was a simple build nothing fancy and what needed to be ordered
- Haliburton, Jack12477, Canute and 3 others
- 6
Holy Cow!!!!!!!!!!!!! NICE!!!!!!
This was no SOD build but a kit I bought at the Covington ,LA meet very simple and basic strictly OOB except for the IP I punch various instruments from the 1/48 ICM He-111 I had left over the kit provided zero(keep learning).As I said nothing special but I have another WWII era Soviet Fighter in the cabinet.
The kit has maybe 15/20hrs in it.
The Nazi's underestimated the Russkies and what millions thrown into the fray could do.
- CDW, Haliburton, Canute and 1 other
- 4
3 hours ago, king derelict said:
A really great result Jav. Weathering is excellent.
Thanks Alan I am getting more comfortable with it but WWI and "The Wooden Wonder"are perplexing to me .
- Old Collingwood, AJohnson, mtaylor and 2 others
- 5
I have built one MiniArt kit and it was a Nice fitting enjoyable build looking forward to the end result.
- Old Collingwood, Egilman, Canute and 2 others
- 5
6 hours ago, Landlubber Mike said:
Came out great Kevin!! Nice job!
Thanks Mike I wish I had not missed up the upper insignia I layered it in wash but forgot to clear it.
17 hours ago, CDW said:
not to shake the paint after adding replenisher, but instead to stir it up
I do both Craig just habit.
- Old Collingwood, mtaylor, Jack12477 and 2 others
- 5
She might come out a good looking "Girl" after all?The canopy is not glued down and neither is the tank.The 250lb bombs are drying and need to be weathered .The whole model got covered with Tamiya brown wash with a 1/2" brush sit for thirty minutes and started the wipe.I then came back over that with Tamiya light dust on the upper surfaces and sand on the bottom.The flat clear went on very low pressure and light from a distance so as not to soak the pastels then you can lay it.The prop was painted silver way back and Nato Black very thin on top use a knife to chip.The wheels is the most I have ever gone after a set and think it will pass AK mud paint mixed with the Tamiya pastels from earlier thinking the mud was a waste here but needed to play with it.She's going to look the work horse when done!
Nice room and layout mine is about 1/2 size @6'X16' and cramped.
- Canute, Old Collingwood, Jörgen and 2 others
- 5
Brian we have a local mill shop of sorts stocks some exotic woods and those of the area which are semi-rough cut 4/4 and 8/4 and I finish the planing.You may look around for a place like that if it suits ya that cedar runs under $4 a b/f in my neck of the woods.I really like your shop wish I had a concrete floor but was working to keep those pesky inspectors away after Katrina she's endure a few more storms.
Keep up the excellent work!!Kevin
6 minutes ago, mbp521 said:
With the cooler temperature and lower humidity in the room and the heat and high humidity outside, the door is starting to warp a bit and not closing properly at the bottom.
Brian I have not had any issues with this door on the shop it's Aromatic Cedar main boards are 1" thick with the outside layers bring it to 1 3/8".I did like you glued and biscuit with clamps with a marine varnish.Termites had eaten 3 steel doors and two frames I live on the MS Gulf Coast so they are an issue here.
21 hours ago, Landlubber Mike said:
Another beauty Kevin! Great job!
Thanks been clearing out these SOD kits no more 1/32 kits left on the shelf 1=1/72 and 2=1/48 1=1/56 (ship) 1/350 Eugen it was 10-15 1 1/2 years back
forgot 1/35 Tiger
20 hours ago, Landlubber Mike said:
Did the Sigma Nu Girl decal have the brown background behind the lettering, or was it clear? If it was brown, you did a fantastic job matching the colors together.
It was clear Mike at first it looked like it was going to be opaque looking but applied some softener and it cleared up and hid itself.Mike life must be keeping you busy of late? alittle of the incognito been going on
This is to cool and I may do one myself of the B-17
- Egilman, Old Collingwood, Jack12477 and 4 others
- 7
My other Hobby by Javlin - Tabletop/Nightstand - 1/1
in Non-ship/categorised builds
Thanks Robert coming along well thus far had a SNAFU but hid/fixed.The side you see now is not glued together just the mortise/tenon holding it together the middle rung is about .010 to short I hate that I will take it out and see if will fit one of the other sides better other wise I have shimed before.The tablesaw I have set up for box joints and doing tenons in this case(usually do by hand ) the measurements depth of the blade has changed.The wood is going to pop once I apply my oils and I have started on the top yet.
