10th-11th century Byzantine dromon by Louie da fly - FINISHED - 1:50
Starting on the shrouds. Because this is a mediaeval Mediterranean lateener the shrouds are fixed to the hull with pairs of blocks, not deadeyes, and they are attached to the blocks with toggles, for quick release.
20200921_085805.thumb.jpg.fb90e0482f24dbc1febd89c6776cba9d.jpg   20200921_085859.thumb.jpg.f2f6a8085309ea764613a6cf595d25f0.jpg
I've also been working on the belaying points for the tacks. To allow the tacks to be belayed near the lower end of the yard, but also to enable them to be pulled back aft of the mast so the yard could be pulled the behind the mast  to the other side I'd originally intended to add modern style "open" fairleads. Mainly because I couldn't think of any other way to do it. :blush:
images?q=tbn%3AANd9GcR0Ajgda9NxOqCaruL8cWIZIBaK1ClZkfuG3e6-qkszv-l14qYymYtWwiuSDyewsZk979hWJek&usqp=CAc
But looking at modern lateeners, I found they tended to use a much simpler system for belaying - just a vertical wooden rod, basically. I adapted this for the fairleads,using what amounts to a sort of bollard - put a loop around it and it can act as a fairlead and a belaying point as you choose. You can see them sticking up from the "battlements" just at the after end of the forecastle.
And here is the banner still in progress. One side finished:
And because I put down a coat of white first, I have to paint the other side as well, to cover up the white. A bit of overlap past the outline of the "tails" but that's intentional - this will be cut off when I trim them to shape.
Link to comment
Share on other sites
Well, I wasn't satisfied with the shrouds, so I've re-done the blocks. The problem was that the block assembly took up too much room compared with the length of the shrouds themselves - like having a hammer with a huge head and too short a handle - no good (unless you're Thor, of course).
Here is the "old" way
and the new
As you can see the "tails" below the single block and above the double block are considerably shorter, making the whole assembly maybe a centimetre (just under 1/2") shorter (about half a metre or 1'7" in full scale). As it turns out it didn't make as much difference to the overall look of the things as I'd expected - in the photo below the shrouds for the after mast have been changed and those on the foremast haven't -
but I'm still glad I did it - I would have been unhappy with it if I hadn't.
I've also finished the banner. Unfortunately because I'd put down a white undercoat I had to paint both sides and they didn't quite line up when I cut the banner out - so I ended up having to paint the overlapped bits to get rid of the white. A fair bit of work, but I'm pretty happy with it now.
I've also finished the anchors, which have been sitting there incomplete for quite a while: I needed to add the rings and make a couple of extra stocks. These anchors are taken from those of the Serce Limani "glass wreck" which went down in about 1025 AD, pretty much contemporary with this dromon.
And I've done a trial run on how I'm going to fix the shields to the pavesade  - the railing that supports them. Byzantine shields were held by a pair of ropes attached to the back, called an ochanos.
1200925696_EpiskopiEurytaniaStOrestesfrescoC13ochanos.jpg.47e4bfaf5f59e73b156587c91b25700b.jpg
Here's mine - I had to use CA to get them to stick to the paint at the back of the shield. I drew the line at putting tiny metal rings on the back (and anyway, most contemporary pictures don't show them). I didn't quite get the ropes symmetrical about the centre, but I'm not too bothered - they won't be visible anyway. I'm just chuffed that I've found a way to attach the shield that would have worked in the real world - just untie the rope and you can pick up the shield.
Then mounting the shield on the pavesade, with a bit of rope passing through the ochanos and tying it to the upright of the pavesade.
And here's what it looks like from the outside.
This is just a trial run, but it seems to have worked pretty well. Now I know what to do when I add them to the ship.
I haven't quite finished changing the shroud blocks over. I expect to have that done by tomorrow.
Then tidy-up - adding downhauls for the trusses that hold the yards to the masts, belaying the downhauls for the blocks and the downhaul for the fore halyard and making a coil for the free end - working out how and where to belay the tacks, adding the vangs - oh, it's all fun and  games!
Link to comment
Looks amazing Steven, been a real pleasure to watch your model evolve to it's current form. The men's on the yards look spectacular and I'm pleased you've decided to leave all oarsmen in place. Looking forward to restrictions ending and heading up your way for a few days.
Cheers
Peter
Link to comment
A beautiful model   with many details and full of life
 Congratulations on all those self-cut figures 👍
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
It was a long time since I connected, seeing the work you did on the dromon makes you "open your mouth!" both for the realization on wood and the part of historical research,
really well done !!!
for me
it is a stimulus to restart with the creation of an ancient boat.
black Wolf
Lupo nero
_______________________________________
finished models  Carrack Santa Maria by luponero - scale 1/50 - diagrams of Adametz
https://modelshipworld.com/topic/19739-carrack-santa-maria-by-luponero-scale-150-diagrams-of-adametz-finished/
models under construction Athenian triere of the 5th century B.C  https://modelshipworld.com/topic/25956-athenian-triere-of-the-5th-century-bc/
  San Giovanni Battista 1598 by luponero - Medicean galleon  https://modelshipworld.com/topic/25930-san-giovanni-battista-1598-by-luponero-medicean-galleon/
Link to comment
Well as I mentioned before, I've re-jigged the blocks at the bottom of the shrouds. Naturally enough, since I was shortening the block assembly, the shrouds needed to be longer so I had to replace them. I was lucky enough that one shroud in each set could be re-used, and that I seemed to have enough dyed cord to make the rest. Until the last moment, when I discovered I was one shroud short!
The existing shrouds are darkened to look like tarred cordage. I dyed another lot of cord, having to re-insert it into the dye bath three times to get the colour to match . Of course as soon as I'd finished, I discovered I actually had just enough of the old cord to do all the shrouds after all. Ah, well, at least I've got some nice dark cord that I can use for other things. Here is the ship with shrouds undone and incidentally the yards lowered to allow new shrouds to be installed. The bosun is going to be in big trouble from the captain for that horrible raffle on deck.
 Here is the new, shorter, block arrangement. (Sorry about the vagueness of the photos - I don't know what went wrong the day I took them). I'd originally put cleats inside the hull walls to belay the downhauls - I'd used modern cleats because none have been found in archaeology but I really wasn't happy with them. Then when it came to it I found it was much easier and probably more sensible to belay them to the oarbenches. At least as strongly fixed as a cleat and much more convenient to use. You'll note small clothes-pegs hanging from the sides of the ship - they're holding the downhauls in tension while the glue dries. After that I removed the pegs and tied off the downhauls. That raffle of unsecured ropes is getting gradually less. The bosun will be happy.
20200927_101036.thumb.jpg.5e474345da9da9040cc271c24c0026f1.jpg  20200927_101045.thumb.jpg.3250925a2d932721b20d09d70628e193.jpg  20200927_101104.thumb.jpg.832a1014c0d564c5f29bdaff4eb652c7.jpg
After I'd replaced the shrouds my lovely (and observant) wife, all unsuspecting, pointed out that the after yard was hoisted inside the shrouds (instead of outside where it should have been). Oops. So I had to loosen off the tacks which I'd temporarily tied up, undo the toggle that held the yard to the halyard, and take the halyard off and re-set it outside the shrouds. I'm very glad she noticed it. It would have been murder to fix it later in the build.
And here is the after yard in its correct place - you can see the toggle which joins the halyard to the yard itself, as well as the trozza (truss) that holds the yard to the mast.
The guy lying on the deck isn't dead. He's "in storage" - when the four guys are put in place hauling up the yard he'll be holding the tack to keep the yard under control.
To provide belaying points for the ropes of the after lateen sail (tacks and vangs) I need to install the xylokastra (wooden castles). But first I have to add the shields to the pavesade - the castles would make it impossible to reach in and tie off the ropes holding the shields on.
In an earlier post I showed the ochanos (straps) at the back of the shield. To hold each shield in place I tied a piece of cotton sewing thread (to resemble rope, same as I've been using for the rigging) through the ochanos and around the railing and each upright of the pavesade, then added a dab of glue to make it permanent. That holds it fairly securely, though I may also glue the bottoms of the shields in place to stop them from flapping around.
Here are the shields about half-way installed on the starboard side:
And here's the starboard side complete.
It's nice after having painted all these shields some months ago and having had them in storage all this time, to finally be able to put them in place. I'm pretty happy with the way they look. Certainly makes the ship look more colourful.
Link to comment
Wow. The model is certainly taking on a busy and occupied air. I can almost see those oars moving in unison.... The shields look fantastic.
Link to comment
Dark rope is "tarred" - standing rigging was often coated with tar to preserve it. Running rigging couldn't be, because it had to run through blocks etc - tar would make the rope stiff, and also build up on the things it rubbed against (like the blocks).
Link to comment
Whaaat? the shields are not colour matched to the rowers tunic - I am aghast ;)  Seriously though Steven that is one heck of a model, beautifully presented.  You are doing real justice to this buil;d.
cheers
Pat
Link to comment
PhilB that's a whole subject in itself, which others know a lot more about than I do. Apparently there were tables for how thick a rope should be for a particular job - obviously the mainstay had to be thicker than the mizzen stay because the load was greater.
You might try a search for rope thickness or size, or something of the sort in the Search function at the top of the MSW page. Or else look through the "Masting Rigging and Sails" section. Or if all else fails, put an info request up in the same section. Then you'd need to convert rope size (which is measured as the circumference, not the diameter) to thread weight at the scale you're working in.
But that was for the Great Days of sail - the 18th and 19th centuries. There are naturally no tables from the Middle Ages. For my build I got quite a few thicknesses of thread and just chose a thickness that looked "right" for the job it had to do, and I suggest you do the same.
Aaah, you're thinking of Western Europe, where the so-called "coat of arms" was on the shield, on the clothes, on the horse-trapper, sometimes even on the helmet, such as in these renditions of Diepold von Schweinspeunt (Note the wild boar emblem as a pune or play on words on the name Schweinspeunt)
from the Liber ad Honorem Augusti (Italy under Emperor Frederick II) c. 1195
The Byzantines didn't get involved with all that sissy stuff . . .
Link to comment
Thanks for the explanation mate, but I was only being a 'smarta....'
cheers
Pat
Link to comment
This is magnificent. Your carvings and research are exemplary.  I'll be stealing your carving techniques but I'm not sure I have the endurance to carve this number of figures. Obviously a labor of love.
By the way, aren't the shields for the Sixteenth and seventeenth port side rowers reversed?. 🤗😉
Current build: Great Harry, restoration
On hold: Soliel Royale, Mantua
Completed:
Bluenose ll, Artesania Latina
San Francisco llArtesania Latina
Chris Craft barrel back triple cockpit, Dumas
Chris Craft 1940 double cockpit, Dumas
Santa Maria, Artesania Latina
1901 Scow Schooner, scratch built
Hannah, Continental Navy, scratch built
Candelaria bomb ship, OcCre
Pride of Baltimore, Model Shipways
17 foot Chesapeake kayak (2, one scratch), Midwest
USN Picket Boat #1, Model Shipways
Kobuksan, Turtle Korean ironclad, YoungModeler
HMS Revenge, scratch
NY Pilot Boat, kit bashed, Model Shipways
USS Monitor, scratch
Nuestra Senora de Afortunado, 1926 Popular Science plan, Resoration
Martha, CBMM,
Puddle Jumper, scratch stern wheeler
Lady Sarah, kit bashed Constructo Victorian launch
Link to comment
Thanks everybody for the likes.
Me too  :D. (Plus a chance to show off my heraldic knowledge . . .)
More a labour of having painted myself into a corner . . . once I'd carved the figures to go on the poop I was committed to having oarsmen. Then when I discovered I couldn't cast them in resin within any sort of reasonable budget - and knowing I had a lot of free pear wood - I was committed. There were certainly times when I regretted ever starting on them . . . :default_wallbash:
However, I actually do enjoy carving - I just wasn't expecting to have to do so much of it . . .
Ha, ha. Funny man . . . Should I mention that there are no port side shields in the photo, or would that spoil the joke? :P
Link to comment
Link to comment
So
If the zylocastra had a means of communicating with the captain would that be a xylophone?
very sorry, Steven.  Failed to resist.
Wonderful model and backstory.  Getting better as you enter the finishing straight as well.
I hope the little man lying down is feeling better in time to carry out his duties
Andrew
"Pas d’elle yeux Rhone que nous”
Kits under the bench: Le Hussard (Started in the 1980s)
Scratch builds:               Volante, Brig (R/C): Footy Drakkar "Rodolm" (R/C).  Longship Osberg (R/C)
Link to comment
That is looking superb Steven.  Having seen this in real life, the photos do not portray the depth or richness of the colours as they really are, despite looking great on screen.
cheers
Pat
Link to comment
Impressive model and crew.
Regards, Patrick
Link to comment
You really need to switch those shields.... or at least let the guys switch seats!
Seriously, remembering the trials the castles caused, they are a magnificent "crown" to your achievement ship.
Completed:
Martha, CBMM,
Link to comment
I've been having a few problems with the rigging - particularly with belaying points, but I'm making slow but steady progress. My original idea for the foretacks was to run each one to a turn around a "bollard" on the forecastle which acted as a fairlead, to a point aft of the mast so the yard could be pulled back behind the mast when tacking.
Only problem was - it wouldn't have worked (which I realised when I was in bed, where all one's best ideas arrive - usually at some ungodly hour of the morning). I had run the tack under the benches would have made it impossible to pull the yard back.
So I re-ran the tacks, still with a turn around the "bollard", but then outside the shrouds. (The clothes-peg is just holding the rope in place while the glue dries on the bollard.)
Fixed the "bitter end" around an upright of the pavesade aft of the mast, and tied off the free end to the pavesade rail nearby.
Then the vangs. One end of the port vang is fixed around an oarbench, the other to the rail of the pavesade. The starboard vang is still loose:
And both fore-vangs tied off:
20201004_164315.thumb.jpg.c093c23849211f1070bd11bff96ba11a.jpg      20201004_115014.thumb.jpg.fad78f7c148d80d2da24f273bd8e9dec.jpg
Now for the after yard. I added the crewmen hauling up the yard:
20201004_105939.thumb.jpg.6738270e6bfb239b7bd6b22d1bc6c2ee.jpg  20201004_105950.thumb.jpg.9658e8ed9e424bfecffd5922013829d3.jpg
Unfortunately the rope they're all holding just couldn't be a straight line due to the one of the guys standing on the hatch cover. In the real world they would have adjusted their grip to allow for that. Not so easy with carved figures . . . However, it's a small issue and I'm not going to bother about it. I know about it, and now you do as well - but I doubt anyone else will ever notice . . .
Here all the ropes for the yard are loose - bosun very unhappy.
So I put the fellow in yellow to work, holding the port tack so the yard doesn't swing around as it's raised. Sorry about the picture quality.
The other tack will be loose, as will the vangs, as the yard is in the process of being raised.
Now I'm trying to work out how to produce a natural catenary curve in the loose ropes. Cotton thread is "springy" and doesn't naturally fall into such a curve. I'm experimenting with wetting the thread and with soaking it with a weak solution of PVA (white) glue. But if anyone can make suggestions or has been in the same position I'd be grateful for advice.
Link to comment
 That's what I would have tried first. Another, possibly crazy idea, might be to make a pattern of the curve you want (like by bending a piece of wire in-place on the model) and then using that as a guide to shape a glue-soaked line that dries off the model and then is installed when stiff?
Link to comment
I've been looking at what happens to the free end of the ropes for the blocks etc I've been working on so far. Normally there'd be a coil to take up the surplus rope at the end. I've tried making a coil copying a technique used by others on MSW but it's pretty difficult if I'm making it out of the surplus rope at the free end. I think it's probably better to just make separate coils and attach them to make it look like they're part of the main rope.
Wrapping the free end around the end of a pen and gluing the coils together (later I had to remove the grey hair that had somehow got itself mixed up with the coil).
20201005_103826.thumb.jpg.4d662b621f344eba44794c059eb15004.jpg       20201005_110800.thumb.jpg.a3a07f768d7a9f8547700d220b339084.jpg
Then I added an extra bit of cord to simulate the bit that winds around the coil to keep it in shape. And a clothes-peg to hold it all together till the glue dried.
20201005_111333.thumb.jpg.48136151828700d399a9a76d0c0f429f.jpg        20201005_120939.thumb.jpg.ff89b416e5fea5aa00eacea6536cac2b.jpg
20201005_120950.thumb.jpg.d8008f6e2c0abe9ae93f75f2cb41a5b2.jpg       20201005_122235.thumb.jpg.bf2c240632db45de874aa653f4b3b2dd.jpg
And the coil in place next to the oarsman in green. Note also the free end of the vang being held by the standing crewman. My understanding is that it would just lie there on the deck until the operation was over, then be coiled up properly.
And another bit of housework - the free ends of the robands and gaskets were sticking out at all angles - a combination of the springiness of the cotton thread and the presence of random dabs of the glue I used to hold them to the yard. They should be hanging down under gravity. So I've started glueing them in a "natural" position. The left-hand photo is "before", the right-hand isn't so much "after" as "during". The 5th and 7th ties from the end of the yard show the difference. A lot to do here - it'll take a while.
20201005_104724.thumb.jpg.0b523b1e2f9c39cacf101883a5b90a1c.jpg   20201005_105050.thumb.jpg.21f004986c359ec47cf13099a72c629a.jpg
Link to comment
Exceptionally good work - your model is looking really good Steven.
Another idea to try for the centenary of the ropes is wax (preferably conservators type).  Using a minimal amount well worked into the thread usually results in the rope laying in a much more natural centenary.  Pull the thread through the wax  two or three times, then work it in using a lint free cloth or paper so that it doesn't sit on the thread but is worked into it.  Don't put too much friction on the rope when pulling it through the cloth/paper or you may burn your fingers.
The downside; well I have heard of two things.  First the wax sitting on the surface of the thread may collect dust over time if the model is not in a case, and second there is some talk, that over a long time, the wax might give off fumes which, rather than preserving the thread, might make the thread deteriorate faster.  The more learned here may offer better advice on this (ding ding - Druxey are you out there :))  but it certainly makes the thread lay better in a centenary and cuts down a lot on any fuzz the thread may have.
cheers
Pat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
