Syren by JesseLee - FINISHED - Model Shipways - scale: 1:64
JesseLee,
Sinc your gunports aren't square you could increase the hight by 1 - 2 mm ... they would b touching the rail. Another additional option is to take some weight from the upper and lower parts of the slides aswell, make them thinner
concerning your other question. Something between mat and brilliant (we call it satin) the gloss would take it to far
Cheers mate
Carl
Link to comment
Share on other sites
Jesse,
I had the same problem with the guns being too high.  I removed most of the lower lug, which you can't really see anyway, and added a pin to secure the cannon to the sled.  http://modelshipworld.com/index.php/topic/8410-us-brig-syren-by-sald-–-model-shipways/?p=344563
My cannons still ended up a little high in the ports.  I wouldn't mess around with the ports at this stage of the build. (just my opinion)
Sal
Current
USCG Harriet Lane - Model Shipways
Complete
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Link to comment
Hello Jesse,
As soon as you go with slightly "more substantial" barrels than provided in the kit you run into this problem. My solution to this was exactly what Jparsley suggested: not to worry about it  :). Your carronades look good the way they are.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Link to comment
Jesse,
Looking back at some of your previous entries I found this pic - I thought it was weird that the plans called for a larger cannonade than the kit provided, but when the proper size was installed the positioning was off.  I read that you experimented with the thickness of the sled; it's hard to tell scale in a photograph... are your sleds really 1/16th of an inch thick as described in the plans in the photo?  That seems really thin...
I think it may be an academic discussion.... I agree with everyone else's comments. It all looks great as is!
Stubby
"They that go down to the sea in ships, that do business in great waters;
These see the works of the Lord, and his wonders in the deep."
- Psalm 107:23-24 (KJV)
Link to comment
  Beautiful work on the Cannons Jesse, I really dig it.
Nicely done, I need to check back in more often - I'm missing too much.
- Bug
Link to comment
Hi Jesse,
I built a home made mini lathe using a electric hand drill. I am having trouble getting decent cuts with the miniature cutting tools that I have. Did you make some  custom cutters to get those fine lines? If so, care to share?
Regards
Link to comment
Thanks everyone for all the input, encouragement & advice.
By the time everyone began telling me to leave them like they are I had already started thinning down about 5 of the sleds so I'm continuing with that. Picture updates will be coming soon.
Michael,  I had a lot of trouble with that too. I don't know if it is my cutting tools or the wood. I got much better results from the mini files. They will give you the finest edges & lines. I used a flat square & a square, & a triangle file to get the shapes I needed. I also used a hobby razor edge to cut the thin line between the 2 raised lips. Hope that helps.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
to leave 'em or make the adjustments........you can see that there was no real answer.......only the one that you decided on  ;)   personally,  I would have left them too......especially after seeing that picture of the instruction diagram.    your on the right track Jesse.........wonderful progress!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
JesseLee,
Remember: it's your build, and we can only say what we would do, or what possibilities are open to you ... you are the docyard super/master shipwright in here ;)
Edited by cog
Carl
Link to comment
I have been slowly working on it while I've been sick. Decided to thin the sleds. Had to pop the metal piece off thinned both wooden components and thinned the wheels down a lot too.
While all this was being worked on I looked over my ship & saw a lot of battle damage. Replaced a broken bumpkin, glued down a lot of copper plate corners, and glued some gun port lids back on.
I also filed the gun port openings slightly, not much but every little bit will help with lowering the carronades. This also gave me a chance to even them up better than I had them before.
Link to comment
Very good, Jesse. It looks good to. As you know, slow is good, less chance on mistakes. Glad you are moving on, eventhough you still don't feel good. Hope you feel better soon, you're in my thoughts.
Cheers
Carl
Link to comment
Very nice work on the carronades Jesse, these things always seem to take way longer than they should :-)  Love the detailed close up pics, really nice.
Cheers,
Jason
In the shipyard:
Link to comment
Thanks for the comments, encouragement & the "Likes".
I added a small lip or foot to the brackets. This was very small detail & a lot of extra time but I thought they looked a little better this way. Kept losing the darned little things so I strung them all on a wire loop - lost none after that. Pinned them through the lugs with wire & managed to keep them all movable somehow. (sorry some of the pictures didn't come out focused very well)
Link to comment
Jesse,
Your killing me. Every time I walk past the Syren box, it feels like something is grabbing me by the throat. As soon as I finish my Endeavour, or probably while I am still rigging which begins in a day or so, I will start my Syren. I hope I enjoy the build because everything I do will have to measure up to your Syren, (not a chance), the Gold Standard  of Syren building.
A joy to watch your ship take shape
By the way, what are you using to take your great photos, especially the close ups?
Regards
Link to comment
It's so good seeing you back at the bench JesseLee.  Good idea on the lowering method of the carronades, that'll work.  Some very nice micro work on the carronade brackets too.  Keep at it my friend, your ship is looking really great.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Thanks Michael, Jeff, Piet, Ken and Carl !
Michael, this is the camera I'm using. I don't know a thing about cameras. My wife gave it to me for Christmas last year just so I could do pictures of my build logs. It does pretty good but does not get really close up like I've seen others be able to do. One problem I have is I dropped it last year in the parking lot at a pier when we went to the beach. Now the screen showing what you are seeing is messed up from the drop & I can only see the edge on one side. I can't see if my pics are centered or in focus so I have to guess then take the smart card thing out , put it in the computer & see if it is ok. If not I have to go back & try it again.
Jesse
Link to comment
Jesse, I use the same camera. :) Although I carry it, treating it like it was a baby. :rolleyes:
My last little DSLR got dropped and would never focus properly afterwards. :angry:
Ken
Started: MS Bounty Longboat,
Link to comment
Jesse
I got the same one, but for the colour. It's used for the quick pics. However, it doesn't do close ups very well. I use a Canon EOS 400D for that. An oldy but it does the trick. I try not to drop them ... so far I've managed ... knock on wood. The digital stuff is so much more vulnerable unfortunately. Sometimes a mere sneeze will damage it
Carl
Link to comment
Same here !!
(Except mine is blue)
:cheers:
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Thanks Jeff, I just checked out your build log. looks very good!
Well, I haven't posted anything but I have been working on putting the tiny hooks in the blocks that will be on the carronades. There are so many of them it takes a while, not much to show yet.
Still pretty sick but going with the admiral to take our daughter to college & get her moved in. It will be very hard on me physically & I'll probably cry like a baby when we leave her. Hope to post some pictures of the progress when we get back this weekend.
Jesse
Link to comment
Eventhough it is a kind of parting, you should find joy in your daughter's next step in life. I know you're proud of her ... I can only guess at the train wreck feeling you'll experience to make the trip. It will probably mean a lot to your daughter. I wish you lots of strength and a safe trip to you and your travel companions
Cheers
Carl
Link to comment
Hi JesseLee, hang in there babe.  Crying is okay my friend but it's only temporary.  Happens to all who have children, at some day they have to fly the coop.  Please say hi to her from that old crazy Dutch guy she met last year and wish her all the best.
Hugs for your dear wife and daughter.
Cheers,
                       VOC Ship Surabaya
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
