Syren by JesseLee - FINISHED - Model Shipways - scale: 1:64
Jesse, glad everything worked out for you and that's a very impressive clamp arrangement you have there in the last picture.
Sal
Current
USCG Harriet Lane - Model Shipways
Complete
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Link to comment
Share on other sites
Added the gun port sides. Got my thumb cut because before I sanded I used a blade to remove more wood quicker & of course I can never do this without catching the blade at least once with a finger or thumb. Added pieces for the sweep port tops. Measured sweep ports & added the sides. This finishes the gun port & sweep port framing & completes chapter 3 of the instruction manual.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
The gun-ports look good Jesse!  Here's what I do before starting to work with sharp objects. Since I know in advance I'll be cut anyway, I just put band-aids on all of the vulnerable areas first, so when I start to bleed, it doesn't get all over my project.  :D  :D
Cheers
GEORGE
Link to comment
Ah yes, every project must have some blood on it.  Good thing is that we have a build in self fix system, ships don't  ;)
Great progress JesseLee, gun ports look good.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Looking good.  We leave a little DNA in every ship!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Looking excellent, Jesse.  What the others have said about "there will be blood".. and DNA apply.  I think that's actually the first rule of model ship building.
Link to comment
Link to comment
Everything seems to be trying to keep me away from the shipyard but I have been able to start the stern framing. Glued the filler & frame pieces in place. Started gluing in the port sills, checking the height with the cannon cut-out.
Link to comment
super nice progress Jesse  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Been through another bout with my health keeping me from getting much done. Feeling a little better now. Decided to fill in more where the curving is the greatest at the bow & stern. It helps me see better if I have the fairing right. Continuing work on the stern framing & gun ports. The only problem I'm having is determining if I have the right curve/shaping from the last bulkhead up to the bottom of the stern framing.
Link to comment
Hope your recovery continues.  As George said, running a plank through there should tell you if the fairing is ok.
Augie
Previous Builds :
Link to comment
I have on the sides. I'm not sure about the bottom side of it.
Link to comment
Should it bend up this sharp as in the 1st photo? Or, should I sand some of the corner down & make the plank bend at more of a slope like the last 2 photos?
Link to comment
I couldn't tell, speaking for myself Jesse, just by looking at the pics without a frame of reference, like the plans or a picture of the finished product. But there in is maybe the answer you need. Maybe check a couple other builds, and check your plans for the right shape. I know the bend at the stern of my ship is pretty abrupt right there.
GEORGE
Link to comment
Hi Jessie,
Check the 1st page of Augie's Syren build. There's a some pics that show that area before and after planking. The one of the planking before Augie painted the area really shows the sweep of those planks nicely.
You are doing great and I'm glad you are feeling better!
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Link to comment
Here's the link if you haven't already found it Jesse.  Some really good pics.   http://modelshipworld.com/index.php/topic/46-us-brig-syren-by-augie-ms-kit-164-completed/page-1#entry338
GEORGE
Link to comment
Thanks for the link. From those pics & the plan sheet it looks like maybe the curve up should start just past the bulkhead a little more instead of farther up where mine starts at now? Maybe not? I'm having a hard time seeing the same thing on a flat sheet of paper & on the 3D wood hull in a spot like this. Going to try to copy the outline from the plan & cut out a pattern I can hold closer to the hull to see if I can eyeball it better that way.
Link to comment
This area is a little tricky Jesse.  Those planks that rise up to meet the counter both bend and twist at the same time.  If you follow Chuck's method, you'll be laying the wales and several planks below the wales before you get there.  Once you do, the shape of the wales will guide you somewhat.  And you may need some stealers.
The good news is that your fairing looks good.  If you look closely at my log, you'll see a slight bump in the area where the planks pass the last bulkhead.  I was able to correct it later with sanding but only because of the copper and black paint on the hull.  Looks like you won't have that problem.
Take your time here my friend.
Augie
Previous Builds :
Link to comment
Jesse, a great question to which I also devoted a lot of time and energy on my 'Jason', but could never prove definitively.  Looking at a variety of pictures as best I could, I came to the conclusion that there should be a smooth inflection at the transition from the planking of the hull to the lower counter on the 'faster' single decked ships - I'd lean more to the angle in the last picture than the first.  The more vertical transition in your first picture seems to be more appropriate for ships of the line.  Just my opinion from looking at lots of pictures and having to work through the same problem...I could be completely wrong!
Cheers,
Jason
In the shipyard:
Link to comment
Hi Jesse,
Build looks great and if you don't mind I'll also follow along. There still seems to be some room at the back!
Most importantly, I am very glad to hear you are feeling better...long may it continue!
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
Link to comment
Thanks for the input everyone. After cutting out a pattern from the plan sheet I came to the same conclusion that Jason did & re-shaped it to slope up more gradually from the last bulkhead so the planks will end up being shaped more like the last pic.
Didn't get much done today. Someone showed up unexpectedly & kept me from my much planned work day in the shipyard. I did get the gun ports painted in preparation for the next step.
Link to comment
any step forward is a step in the right direction  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Made a plank bending jig with wood pegs for the wales & planks. As I was about to glue on the upper wale I stopped & thought about how can I be absolutely sure I have it in all the right places the whole length of the ship?
I looked at the instruction manual showing 7 planks above the upper wale & where they are at each gun port. I made a jig out of plank ends to measure at each gun port to make sure everything would line up where it is supposed to. I realized something was way off - my plank jig didn't line up the way the pictures in the manual did. I couldn't squeeze 7 planks in that space. Figured out that I was using 5/32" pieces for my jig. Only the wale is 5/32". The planks are 1/8". Correcting this I made a new jig with the 1/8" pieces. Now It all fit right. This jig helped me get the correct marking for the upper wale correct. Good thing too as it showed I would have been off a little bit in the middle sections.
Glued & clamed upper wales on each side.
Link to comment
Well done.  The old adage 'measure twice, cut once' holds true.
Augie
Previous Builds :
Link to comment
It doent look that bad at all.  I would take a bit more off so the bend isnt as sharp where the plank tuck up into the lower counter..
See these pics if it helps.  Couldnt find any of the stern unpainted.
Chuck
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
