Syren by JesseLee - FINISHED - Model Shipways - scale: 1:64
Thank you everyone for all the kind comments & for all the likes!
I changed tree nailing methods. Instead of using toothpicks like I did on the outer hull I went with using a filed syringe needle. I didn't want the tree nails to stand out & look darker on the deck. It worked pretty well, got the results I wanted. I did have a problem with it actually pulling the plug out sometimes & I had to go back over it & fill in where that happened.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
Share on other sites
That method made for a real nice result Jesse!  Well done! Gonna have to log that one in the old memory-banks.  :)
GEORGE
Link to comment
Fantastic job you did on the deck JesseLee, bravo.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Soaked & curved wood strips for the waterways.
Link to comment
Made jig for sanding waterway strips triangle shaped.
Link to comment
Sanded waterways to the right shape.
Link to comment
Got all those nicks in the sides filled in & re-painted. Glued waterways in place. The deck got 2 thin coats of golden oak stain.
Link to comment
That's a nice looking deck Jesse!  Good job on those waterways.  I like the sanding jig you made for that.  :dancetl6:
Cheers
GEORGE
Link to comment
Jesse, what did you use to cut the sanding jig, a router bit?
Ken
Started: MS Bounty Longboat,
Link to comment
Thanks George & Sal.
Ken, I actually just used a small triangle needle file. Did it by hand.
Link to comment
Very innovative on the sanding jig JesseLee.  Deck and waterways look marvy.
Cheers,
                       VOC Ship Surabaya
Link to comment
Thanks Piet!
Beginning to build jig for stamping the copper plates...
Edited by JesseLee
Link to comment
After making the jig somehow glue flowed in & filled one of the small openings that the copper strips slide through. Didn't want to tear it apart & rebuild it so I tried to figure out a way to cut out the opening again. I found this old underwire from a bra I saved out of the dryer a long time ago ( you never know what use you might come up for stuff later on). I filed one end to a very sharp chisel edge. Jabbed it in over & over till it cut through. Worked pretty good!
I've noticed that a large majority of my pics have a pinkish hue to them. I've got to do something different with my lighting. I'm using an old aquarium light over my work bench. The old bulb must be emitting more of the red light spectrum. It isn't as noticeable to the eye but the camera picks it up too much.
Link to comment
Making the stamps for the copper plates....
Link to comment
wonderful progress Jesse........deck looks superb!   you've done some very nice work  ;)   looking forward in seeing how the plate jig works  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Great looking build so far!
I will be following along as I have one of these in the queue to be built eventually, so it will be nice to take some notes as you go through the process and file them away with the ships binder I have going.
Current build: MS Sultana; Corel Endeavour
Previous builds: MS Phantom
Under the bench: MS Syren; MS Bluenose II
Link to comment
Started stamping out some of the copper plates
Link to comment
Looking good Jesse. Great jig/fixture for the copper plates.
Ken
Link to comment
Just checking out your build - the Syren is one of my favorites. Nice, precise work on the deck.
- Bug
Link to comment
Thanks Ken & Bug!
While working on the copper plating I have finally put the cap rails on. I wanted to test the limits some so instead of piecing them or cutting them out to shape I tried soaking & bending 1/4" strips. Not the usual way to try to do that but I just wanted to see if it could be done. It can, took more than one soak & bending.  The strips still wanted to straighten out some so I drilled holes & held the rail down in place with wood pegs & glue. Even though I did make this work, I wouldn't recommend it. It did make the wood buckle & it took some wood filler & sanding to make it flat. Then added the smaller molding strip & grooved it using a small triangle file & a folded piece of fine sandpaper.
Link to comment
Hi Jesse
I was just thinking, have you ever thought about using Flexible Beech.
You can bend that wood any shape you like ( well almost ).
Denis.
Link to comment
Denis, I would love to try it along with some various other wood types but currently don't have the funds for ordering much of anything so I'm stuck with left over scraps from previous builds & whatever I can pick up at the local Hobby Lobby store which is nothing but Basswood which is what I used here. I have heard so many sing the praises of Pear, Holly, etc. & now the Flexible Beech. Ahhh, maybe some day, till then I can dream!
Link to comment
Hi Jessie!
You can make wood strips bend to almost any shape with water and heat. Although probably not the safest (or smartest!) thing to do, I have bent damp wood with a bare light bulb. You need to constantly move the wood slightly in the area to be bent to avoid scorching, and it will become pliable and require very little force to bend in any direction. A safer way is to put a bare bulb inside a thin wall pipe and bend the wood over the pipe. I know folks that have bent acoustic guitar sides this way. It's low tech and works well. If you do the bare bulb, definitely wear eye protection. I've never had a bulb explode, but it could happen. The wood should be damp enough to sizzle and should be re wetted with a spray bottle if it stops sizzling to prevent scorching. The walnut planking on my whaleboat was actually bent that way.
Keep up the great work!
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
