Cruizer class brig by Timmo - 1:36 scale Radio - Finished
Hi Timmo
You're doing a great job - looks really good! I like the clean processed raw build.  :)
One question: Do you applied soft soldering or hard soldering method for the hinges?
Look forward to your further posts ...
Best regards!
Mike
current scratch build 1:15
Colin Archer - RS14 "Stavanger"
Link to comment
Share on other sites
Hi Timmo
I am by far no expert in soldering technology. Anyway, I had some fear to soft solder the hinges for a function model. Maybe you like to check hard soldering with silver solder - it is not that difficult ...
1. Degreasing of parts
2. Flux on it
3. Some silver solder pieces to
4. Flame on it
5. Done  ;)
All the best, look forward to future posts ...
Regards,
Mike
Edited by mikegerber
Link to comment
Thanks mike.
Full rudder installation is a long way off so I might revisit it.
I tested one with a bit of pressure and it took quite some force to snap the joint so I figured with the load spread across five pintles it should be ok.
Link to comment
The bulwarks are now fully planked, giving the shape of the completed hull.
The first 'mechanical' piece has also been added in the form of a brass tube to carry the tackle for the spanner boom. It exits through the taffrail and was shaped to fit around the chase ports and flow into the hull cavity.
It's not strictly accurate having the boom belayed to the centre of the taffrail but it's one less hole in the deck where water ingress is more likely and also avoids the potential of fouling the steering gear and lines once the tiller is on the rudder head.
Although it's sanded fairly smooth I'll plank the inside of the rear counter to avoid any texture issues.
Link to comment
Looks like you've captured the hull perfectly - I'm suffering from 1:36 Cruizer envy :P
Cheers,
Jason
In the shipyard:
Link to comment
More hull work.
The inside of the stern has been planked. And the capping rail added. This needs some filling still.
Also on the stern the boom crutches have been added. These were shaped from a single piece on each side and a slot cut in the corner of the stern to recess it in.
Once in place the fashion pieces were added with 1.5-2mm timber cut to match the curve on the rear counter side and another piece on the hull side. The seam between them was filled and sanded so it looks like one piece. I'm not skilled enough to cut this from a single pice to match the variety of curves in this piece.
Also three lines of moulded strip were added at under the taffrail and faired in, at the bottom of the counter and lower down at the transom.
A strip also runs the length of the hull. These were made with the shape filed into a razor blade as per Chuck and other luminaries on MSW.
The entry steps had been added, these were made from two pieces- a moulded strip made as above and a flat plank step.
Next it's either the head rails or strengthening the deck beams with cross members and marking out the access hatches. The later might require a bit of wrestling with the hull so it might be best to do that before the head rails are added.
Edited by Timmo
Link to comment
Really nice Wayne, the details you've added really enhance the hull.  Did you spile the planking, especially the top and butt planking on the wales?  Looks fantastic   B) . I'm jealous you have a copy of the 'Irene' book, looks to be very insightful.  Trying to make out the name on the stern - "Harrier"?
Cheers,
Jason
In the shipyard:
Link to comment
Hi Jason, yes it's Harrier but that's not confirmed as yet! There's plenty of options in 100 vessels in the class.
The planking was spiled. Most of the planking lines have disappeared under the resin and paint is yet to come. I might rescribe the wale planking as it was so tortuous to do.
Edited by Timmo
Link to comment
I've moved onto the head rails in order to complete the entire hull before moving on to the internal arrangement for the RC gear and ballast etc.
The hair bracket for each side ( I think that's what it's called) was cut from a single piece of timber. It split on one side but this was easy rejoined and any gap will be filled later.
Upper and lower cheeks have been added with templates for each cut from cardboard and a profile gauge used to get a good fit around the curve of the the bow.
A scroll head was shaped into the brackets with a file. This was very quick and easy and adds a third dimension to the bow decoration. These rails will get a moulded profile scraped into them as per the hull side rail.
The bowsprit has also been turned and had the bowsprit cap and bees added to the end. I've got some small brass sheaves that will be fitted to the bees later. I'll experiment with a piece of timber but I expect it'll be too fragile for the spar most likely to take knocks so fibreglass rod from the local fibreglass/ surfboard shop might be the answer,
Next up is the catheads and their fiendishly complex knees and hawse holes with bolster.
Link to comment
Some decent progress on the Cruiser over the Christmas/new year period with the bow largely completed with the addition of head rails and hair brackets etc.
This makes her look like a proper ship.
The process was started with cheeks, followed by determining positions for the catheads and hawse holes and bolsters. The catheads have slots and holes cut for anchor lifting blocks and are also pinned in place with a brass rod through each.
The cathead knees were cut with the help of paper templates from a single block as per the effort on my granado build. Lots of trial and error to get them symmetrical and sitting right.
The pic below makes it look like catheads are uneven and things are off but it's distortion of the iPad camera at close range.
A brass strip with a moulded pattern filed out was scraped along the components for decorative edge moulding effect.
The rails were cut from timber that had been fibreglassed on one side for strength. However, once the whole production is assembled it's surprisingly strong and should take a few knocks.
I'll likely add a grating of some sort between the rail but am lacking any reference so will just cobble up something that looks right.
A summer holiday awaits so that'll be it in the shipyard for a while. Next up are the channels, which I hope should be fairly simple. Then that's the hull pretty much done.
Link to comment
Really nice Wayne, the scale is giving you a chance to put some really nice detailing.  How did you get the profile onto the various trim pieces?  Love what you are doing!
Cheers,
Jason
In the shipyard:
Link to comment
Thanks Jason, yes the scale is quite nice for detail. It's big enough to add the bits you like and still fudge the bits that are too difficult.
The moulded effect was cut with a scraper cut and filed with a profile and an overhanging edge that could be run along one edge of the timber so it scraped a groove at a consistent distance. Small files and blades were used to define it further.
The timber is a little too soft and my technique not good enough to get a super crisp edge but I'll be looking for painting to further define it.
Link to comment
  • 3 months later...
It has been a while but there has been some progress in the shipyard.
With the hull largely complete attention has turned to the masts.
These were again cut from matai and mainly shaped by hand with a small plane. With a diameter of 14-16mm and length of over 360mm for the lower masts they were a bit big for my small proxxon lathe. This was quite easy to do by hand and very satisfying.
The top gallant masts were turned from fibreglass rod as wood would not have the strength at this scale and if anything will get damaged in transit it'll be the top masts and jib boom.
The fighting tops were made from 3mm ply which was glassed on both sides for strength.
These were up scaled slightly from petrejus' plans after reading about size differences among some forums of SC&H kits.
The batons and trestle trees were cut with the Byrnes table saw which allowed some very close tolerances and ensure everything fits together very closely and is quite strong without being stuck together. Working fids will allow the masts to drop down for transport although a test fitting has surprisingly revealed the vessel fits (with a list) in the back of the family SUV.
The hounds are yet to be added but won't take long. The masts have been stepped in boxing with the help of their square bases and secured with a wood screw so if disaster strikes it's all remove able. It isn't pretty but practical.
Also the rebated frames of the access hatches have been added, giving a final indication of how much room there will be to get at the mechanical entrails - hopefully it'll be enough but I'll aim to have that planned out and largely installed before the majority of the decking goes on.
Link to comment
Timmo, that's a beautiful build. I look forward to seeing her completed and in the water. Any chance of a video when the time comes?
Those masts look very tall to fit in a car. How are you going to transport the model?
Steven
Link to comment
Thanks Steven,
The height from keel to the mainmast tip is about 1100mm. The vessel does fit in the back of the wagon when on a lean. I thought while planning the project that it wouldn't without masts lowered but there you go. Even so with the top gallant and top masts lowered once the fids are removed it'll take at least 300mm more off so no problems on the transport front.
When she finally gets on the water I've got plans to mount a go pro on her. Hopefully it won't be footage of a titanic-esq maiden voyage.
Link to comment
She will look good on the water.  I like the groove to trap the water at the deck openings.  I wish I had have thought of that when I was sailing RC.
Bob
Current build:  SS_ Mariefred
Link to comment
Thanks bob, I'm sure I obtained the idea from someone else as there are very few original ideas out there.
It'll have a rubber sealing strip and some arrangement to secure them down snugly.
I'm hoping to apply some paint soon which will make it look very different.
Link to comment
Outstanding work Wayne, a real beaut in the making there.
Cheers,
Jason
In the shipyard:
Link to comment
We would have used petroleum jelly in the groove and a rubber band hooked from the keel to the bottom of the deck allowing the deck to be lifted just enough to unhook the rubber band for removal.
Bob
Link to comment
Bob
Yes, Simple is usually best.
Link to comment
A coat of primer has been sprayed on and the major imperfections filled.
Main coat of nelson's yellow on black awaits.
The masts are presently varnished timber with black. I think I'll leave them like that as a nod to the fact the boat is not plastic.
Mast rings etc to come.
Link to comment
The false deck has been added with 2.5mm ply. This was done in sections and a hollow near the bow filled.
The access hatches had their own ply covering and sit flush with the rest of the deck. The idea is they almost disappear when in place and planked.
Planks are cut from a basswood sheet with dark grey card glued to one side. This gives a consistent line for caulking which is more of a scale colour than straight black. The wood is a bit soft but it'll have a solid covering of resin or varnish to protect it.
The deck has been marked in the four butt shift pattern based on where the hatches and other deck furniture will be and the first planks laid on straight over the hatches. The hatch joints will be cut through once more planks are laid on and also mast holes recut.
The central planks are laid full length as deck furniture placement means no plank joins would be visible.
The margin plank was drawn on the deck and traced with the pattern transferred to a basswood sheet for cutting. Care was taken to achieve symmetry on these as at the bow as from plank 9 on either side they will be joggled into the margin plank. This pattern was drawn on the deck to make sure both sides lined up.
Lots of repetitive planking ahead but it feels rewarding.
Edited by Timmo
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
