Bomb Vessel Granado by Rustyj - FINISHED - 1:24 - cross-section
Hi All,
Well I’ve come across some interesting plans for a scratch built Bomb Vessel Granado Cross
Section over on Model Ship Builders site. Now I’ve never been known to be
impulsive, carry on more then one build at a time or unable to resist the urge
to start another scratch build.
Talk about going to the darkside! It’s so dark on this side I’m not sure I’ll ever see light again! :o
The Bomb Vessel Cross Section has some interesting details both on and below the deck
(i.e. mortar pit and shell room) The plans are based on "Anatomy of the
Ship - Bomb Vessel Granado" by Peter Goodwin and original drawings by
Thomas Slade. All plans were drawn by Jeff Staudt. In total there are 63 pages
of drawings in the set and are very well done.
The scale for this build is a whopping 1:24 (½” to 1’) so it will be interesting building
something at this scale. The single frame pieces are ½” wide and a completed
frame is approximately 13 ½’ wide by 9” high. The keel is ½” wide by 14 ½” long
and over 1 ¼” high at its highest point. There are some frames that are doubled
so they will be 1” wide!
I have some Cherry cut offs from a furniture factory and I will be cutting them down to ½”
billets for the frames. I’ll decide the other woods as I go. The main problem I
see is turning the mortar and cannon as I do not have a lathe or mill. Oh well
I’ll cross that bridge when I get there.
So here is a look at a couple of sheets of plans to give you an idea of what it will look
like. You also can go to
www.modelshipbuilder.com   to see more information.
Here is a sample of some of the rough cut Cherry I have.
You can see that the sides are rough cut so to start I shaved the sides on the
saw to clean them and then ripped them. The below pictures show I ended up with
two pieces of 1/2" x 3" x 14" and one piece at about 1/8" thick.
I will have to run them through the thickness sander to get them to their finished size.
This should be interesting and will take a good while to complete.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Share on other sites
This will be a cool model. I can't imagine the size at that scale. Build on!
Jeff
In progress:
Medway Longboat 1742 - Syren Ship Model Company -1/2" scale
USS Constitution - Model Shipways - Scale 1:76
HMS Granado - CAF Model - 1:48
HMS Sphinx - Vanguard
Link to comment
Another interesting one to follow Rusty!  Like you, I couldn't resist this one and ordered the plans a couple of weeks ago.  Not sure when I'll get around to it, or whether I'll stick with the 1:24 or go to 1:48, but it sure looks like a nice build.  Can't wait to see your progress on this.
Link to comment
Like you I also can't wait to get started on that one. If there was just more time in the day.
Wish you the best of luck with the cherry.
Looking forward to seeing the rest of this. Hope I get to start mine before you are done.
Later Tim
Edited by Tim C
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Link to comment
Hi Ben, I wouldn’t really say I’ve started, let’s call it
just some preparation work. :P
Jeff, this scale will really be different. I’ll post some
pictures of the plans next to the Triton for some reference. B)
Hey Grant welcome to the club. I too thought about 1:48 and
even printed a set at 1:48 but the lure of building large got me. :)
42rocker, you will definitely start before I finish. With 3
at once the pace will be sloooowwwwww. :huh:
Rusty
Link to comment
Rusty,
Another build?  Wow... I'm looking forward to following it.  This type ship is really different from the "normal" things we see.
Link to comment
I've seen a model of the section at ModelShipBuilder and found it very interesting. The drawings are looking very nice. Please reserve for me a seat in the first row to follow your log :)
Edited by AnobiumPunctatum
Regards Christian
Link to comment
Hi Mark, Yeah I know but I couldn't resist at least starting some of the set up work.
Christian, Seeing it on MSB was what really pushed me over the edge.
Here is another reference to the size of this cross section.
One plan is of a full frame with one of my Echo frames sitting inside of it.
This picture has the scale plan of the Triton cross section sitting side. I couldn't
use the actual Triton as it was drying then.
Here are some of the billets of cherry cut down to size.
And the first batch that have been through the thickness sander.
Well that's it for now so I'm back to the work shop to work on the Triton/Echo/Bomb Cross Section. :blink:
Rusty
Link to comment
That puts it in perspective. It will be a large finished model. It should allow for some very fine detail.
Jeff
In progress:
Link to comment
This looks interesting.  I'm going to follow this one.
Bob
Current build:  SS_ Mariefred
Link to comment
Yikes!  That is going to be one big honkin' cross-section.  You've already started prepping the wood, so I hate to tell you this, but your build is beyond "set-up". :P
Link to comment
Wow - that is gonna be a Whopper!
Are you going to build entirely from that cherry or has an order been put into our friend Jeff? BTW I just ordered some 1/16 boxwood to make the Confeds double beaded moldings - couldn't get a decent result with the basswood.
Ben
Link to comment
Hi Jeff, When I was giving the dimensions I just didn't have the feel for how big it is. So as they
say a picture is worth 1,000 words.
Hi Bob, Thanks for stopping by.
Mark, Maybe your idea of set-up and mine differ just a bit? Na not really. :D
Ben, So far everything is from bits and pieces I have on hand. That doesn’t mean Jeff isn’t shipping
stuff to me once he’s back! As far as wood goes, frames cherry, keel pear and ebony and deck clamps
are maple. No other choices have been made. Yet.
Now I’ve gotta get beck to my set-up! :rolleyes:
Rusty
Link to comment
Rusty,
There's what we call "set-up" and then there's what we tell the Admiral is "set-up".....
Link to comment
:D  B):D  B)   :D
Rusty
Link to comment
Ok this is all Ben’s fault. Ben are you out there? It’s your entire fault. Not mine. Nope no way.
I’m just and innocent bystander. ;) You asked about wood choices and I was thinking of
using some maple I have on hand but I wasn’t really sure.
So all because Ben asked I just "had" to see what the maple would look like. Out came the saw
and thickness sander and I cut up the maple into the correct sizes for the mortar pit deck clamp
lower and upper strakes and the upper deck clamp upper and lower strakes.
Here it is with no finish on it. I think I will like the lighter color against the darker cherry. I’m thinking
the deck beams might come from maple too. They are just way too thick to use boxwood not to
mention it would take half my pension check!
Thanks for asking Ben! :D
Rusty
Link to comment
Ok now since the saw and thickness sander were out I figured what the heck
I'll just cut up the pieces needed for the keel. I mean after all I am just doing
"set up " work here! ;)
So here is some swiss pear cut to the proper thickness all "set up" for when
I'm ready to start actually doing some work on the cross section. :P
Rusty
Link to comment
Nice set-up wood and set-up work.  Can't wait to see the set-up keel.  :rolleyes: post-76-0-48148800-1363322494.gif
Link to comment
Whoa! Sorry buddy - I didn't want to send you down the rabbit hole, I'm sure whatever you decide will be superb.
Please leave a lil of your pension for food and beer, Jeff at hobbymill will survive!!!
Ben
Link to comment
Hey Ben, Already way down that rabbit hole my friend! Rice n beans again for dinner. :rolleyes:
Thanks Pete it may take awhile but should be fun.
I’ve continued on with the now infamous “Set Up” work. Quiet Mark! :D
Here I’ve constructed the jig that will hold the set up keel and frames in the correct position.
The bottom board is some ¾” ash that I had left over and the top piece is ½’ beech plywood
that is eight ply and very solid.  I glued the plans to the plywood and then cut it out using
the scroll saw. After it was done I placed it evenly on top of the bottom piece, clamped it
and drilled 6 holes for the bolts. This way I was pretty sure the top and bottom would stay
square to each other.
post-43-0-80028400-1364413625_thumb.jpgpost-43-0-07635000-1364413627_thumb.jpgpost-43-0-79956300-1364413627_thumb.jpgpost-43-0-44644900-1364413629_thumb.jpgpost-43-0-54119100-1364413649_thumb.jpg
Once the bolts were installed it was a simple matter of adjusting the nuts until the correct
height was archived.
Here’s the Triton Cross Section placed in side for another size reference.
As I complete more “Set Up” work I’ll let you know. ;)
Rusty
Link to comment
Wow buddy, the bloody thing is huge, you'll be able to fire real mortars with it, gonna need a lot of wood to build her - I worry about your pension again, rice and beans for the foreseeable future I think.
Ben
Link to comment
Nice setup work.  That is going to be a huge cross-section.  Now unless I'm wrong... will building the frames be called "frames set-up"?  Need to know in case I pull one of these and my Admiral asks. :piratetongueor4:
Link to comment
Thanks Grant. As you know “set up” can be endless.
Ben, I just wish my brother hadn’t retired as a machinist.
He once made a working cannon. :blink:
Pete, I hope you plan on it taking a while! You know
“set up” takes forever.
Mark, As long as you haven’t applied a sealer or Poly
it could be considered “set up”. :rolleyes:
Rusty
Link to comment
Well the now infamous “set up” has continued. While I was doing some
cutting with the table saw I could hear the keel calling me and it was just
excited to hear the saw running. Well I just couldn’t disappoint it sooooo……
I figured a little "advanced" set up was in order. :P
I cut out the side and top profile plans and glued them to the pear and
started working on the hog. All pieces were left a little long and will be
trimmed to the correct length later.
I set the saw blade height to remove just enough wood to get to the plans line.
I then just started working my way down the hog adjusting as I went.
And here is the hog with all of the cuts made.
Time will tell if the "advanced" set will continue! :D
Rusty
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
