Bomb Vessel Granado by Rustyj - FINISHED - 1:24 - cross-section
Hello Rusty.
I think we are all looking forward to the next installment of your build :)
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Share on other sites
Link to comment
Hi all. I've been looking ahead and they don't show treenails for the inboard planking and my feeble mind is
trying to figure out the correct size a treenail should be at this scale. Now if 1/2 inch = 1foot then would
1/16" treenails be 1 1/2" @  scale?
Then if that's correct would 1 1/2" treenails be the right size?
Help!!!!!!!! :huh: and thanks  :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Rusty,
Not sure if I've understood your question correctly, but your maths is correct. That is, if your "real life" tree nail is 1 1/2", then at your chosen scale of 1:24, this would be 1/16". As to whether 1 1/2" tree nails are correct in the first place, I've no idea!
Link to comment
Hi Grant, Thanks for confirming my math.
Now I have to try and figure out what size treenail to use.
One down and one to go. :)
Rusty
Link to comment
Ok I did a little experiment. I took a plank that the plans call for that is 13 scale inches wide.
I pulled a treenail to a size 55 on the Byrnes draw plate and it would equate to a little over
1 scale inch. Visually it looks good to me.
I might try it a little smaller. Maybe ¾ of an inch at scale.
Rusty
Link to comment
Thanks Sinan.
OK the test continues.
The treenails on the right are approx 1 1/4 of an inch while the ones on the left are 3/4 of an inch.
The colors are different because I used scrap wood. The one on the right are closer to what the color will be.
Rusty
Link to comment
Hi Rusty,
I'm no expert, but the larger ones look "right" to me.
Link to comment
Grant and Bob thanks for your opinion on the treenails. I too like the larger one.
To me it’s better on the eye. I’ll hold off for a while on making a final decision though.
Here I’ve made the false keel. It calls for the top edges to be beveled and to do this I used
the Byrnes table saw with my new tilting table. Once I figured out the angle it worked great.
No surprise there. :)
I then glued the false keel in place. I used a second piece clamping the ends to hold it in
place. I also put a ¼” thick piece in the middle between the false keel and the second
piece to put pressure there until the glue dried.
Next up will be making the deck clamps and floor riders.
Rusty
Link to comment
For a vessel of Granado's size 3/4" treenails are correct. However, it's your decision as you are the one that has to be happy with the result! She's looking very good so far.
Link to comment
Hi druxey. Thank you for letting me know the correct size! When I get there 3/4" it is! :)
Rusty
Link to comment
Thank you Greg. She's fun so far.
Rusty
Link to comment
Hi Ben,
Thanks for stopping by and yes it is fun to experiment. I believe the smaller ones
are closer to scale so you will be seeing them again.
Onward we go. The mortar deck clamps have been cut and test fit.
I have also started cutting out the floor riders and will have to shape them to fit the hull.
So much fun and so little time! ;)
Rusty
Link to comment
As I was making the floor riders I looked ahead in the plans at the shell room
as that comes after the floor riders. I measured up the cannon balls, went to the
shot locker and I just couldn’t understand why I didn’t have any cannon balls
big enough. I mean they are only 14mm (.55”).
So I had a not so bright idea. I tip toed into the Admirals craft room, located her
stash of jewelry making supplies and found some 14mm beads. Then with the
saddest face I could make asked permission to use them.
Permission was granted, hole on one end filled, paint administered and tada cannon balls!
Rusty
Link to comment
Nice find  ---- and congrats on the negotiation skills :D  :D
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Great idea for those cannon balls, Rusty.
It's hard to tell from the photo but did you pare back the inside edge of the mortar clamp so that the beam fits properly athwartships?
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Thanks Augie. A mans gotta do what a mans gotta do. ;)
Hi Greg. The simple answer is yes and no. As the clamp is tacked temporarily in place
for measurements etc I’ve not made the final adjustments to it for the deck beams. Also
the hull is laying on its side which makes it look  even worse. Thanks. :)
Rusty
Link to comment
Hi Ben and thanks. It was good to see you back at the echo cross section but no nothing
from me on the echo right now. That’s a story I’ll have to post there sometime soon.
Here are all of the floor riders constructed. Then I took and numbered each one as they would
be unique as I'm sanding them to fit both the hull frames and the mortar deck clamp.
Once they are finished and in place it will time to put the limited inboard hull planking.
Rusty
Link to comment
Link to comment
Thanks Greg and Grant.
Greg I owe it all to you from when you showed how to use the disk sander and chisels on the Echo Cross Section! :)
Rusty
Link to comment
Thanks Bob, very appreciated.
Rusty
Link to comment
Hi Ben, Thanks for your continued support. I’ve done a couple of admiralty
style POF’s already and I’m not sure when I will do a full one again.
So many things to build. ;)
Well the floor riders have been shaped and installed along with the motor deck
clamps. I’ve also placed the first of the inboard planking between the keel and
the deck clamps. The channel has been cut for the limber boards too.
Seeing that the clamps and riders are installed the framing is stable enough to fair
the outer hull now. So I took her outside and seeing she is so big I was able to use a
palm sander I normally use on full size work to rough her in.
Here you see one side has been done with 80 grit. I’ll work out to 220 grit for now.
Rusty
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
