Bomb Vessel Granado by Rustyj - FINISHED - 1:24 - cross-section
Fantastic joinery, Rusty.  Are you finding things easier with the larger scale?  Or just "different"?
Link to comment
Share on other sites
Hi Ben, Yeah I thought it was kinda neat. I had set the sander next to it while getting more paper
then thought it was a good reference to the size.
Thanks Mark, I guess “different” would be the correct word. The size throws off what we are used to
doing. When doing joints a little flick of a chisel or knife would fix a bad fit. Here a little off requires
the removal of a ½” wide piece of wood!
On the plus side there is a lot more to hang onto so the tips of my fingers have suffered less. :o
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
The inboard hull planking below the motor deck clap has been installed. I still have to drill
it for the treenails and then it’s on to building the home for the cannon balls.
Here are the plans showing the assembly and it’s placement.
Rusty
Link to comment
Now that the floor riders are in I’ve started the floor for the shell room. All of the
beams are cut from some white poplar I had kicking around.
The beams and posts will be sealed with a natural stain prior to the application of wipe on poly.
Here are the shell room floor beams test fit.
And the completed floor with the beams and walkways which are made with boxwood.
Rusty
Link to comment
Thanks Bob and Joe,  It's sure different than anything else I've done and a nice change.
It will be interesting to weight it when I'm all done as its getting heavy already. :blink:
Rusty
Link to comment
Thanks Chris, It's great to hear from you.
The cutting out of the parts and the assembling of the shell room is progressing.
The shelves are made from cherry and the posts from poplar. Each shelf will
have a depression sanded into it for the mortar shell to set in.
Here you can see one row set in place for a test fit.
Rusty
Link to comment
That looks terrific Rusty. Can you explain a little more about how you achieved the depressions for the mortar bombs please? (You just mentioned that you sanded them in).
Cheers,
Edited by gjdale
Link to comment
Thanks Joe, I'll keep the picture coming, that is when I remember to take them! :huh:
Hi Grant, I am too brief sometimes. Sorry about that. :(  I took a 3/8" (9.5mm) drill and used it to
make a small depression in the center of the shelf. I then used 100 grit sandpaper on the tip of my
finger and just kept turning it in the depression until I had it the way I wanted it. I then finished it
with some 220 to smooth it out.
Kinda like sticking you finger in your ear and twisting back and forth when it itches! :D
Rusty
Link to comment
Link to comment
I’ve assembled the two other rows for the shell room, glued the cannonballs in place
and set all three rows in place. I then added the top beams just like the bottom beams.
Here you see the plans for the mortar pit beams and planking as well as the beams cut
out as per the plans.
The mortar pit beams have been cut and test fit into place on top of the shell room. The
bottom of each beam is notched to fit over the top beams of the room.
Here you see the notches cut into the tops of the mortar pit beam and ready to accept
the mortar pit boundary timber.
Thanks for stopping by! :)
Rusty
Link to comment
I'm sorry.....that looks better then the real thing.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Oh my :blush:  thank you all. You are too kind.
Rusty
Link to comment
Hi Rusty Just checking in for the first time, very nice workmanship That is a large cross section.
Michael
Link to comment
Thanks Michael and welcome aboard.
I’ve cut and fit the mortar pit boundary timbers. Between these two timbers will be a first
row of decking. It is cut from boxwood and the calking is simulated using black construction
paper. Doing the pencil on the edges just looked too thin at this scale.
Here I’ve cut out the plans showing the second layer of planking that will go right over the
top of the first. You will notice that a nice circle is formed in the middle for the mortar.
Seeing I don’t have a drill bit that big it should be interesting getting the hole round.
Well this will be the last post for awhile. We are off to the land of oranges, alligators and a
talking mouse with the grand kids. Should be interesting to see how steady my hand is
when we get back. :huh:
You all be good now while I’m away! No slacking off or rum rations will be cut! :P
Rusty
Link to comment
Rusty -  this some very nice work.  I'm glad to see you keeping busy.  About getting that hole to come out round, I imagine it would be easier if you could do the rounding before attaching the planks to the underlying deck - I'm just not sure how that would be done.
I'm curious that the second layer seams line up with the lower layer.  I'd think that offsetting them a bit would add strength to the structure.  Sometimes I wonder why they did things the way they did.
Enjoy your trip - that can be a lot of fun with the grandkids along.  If the food and wine festival is still going on at Epoct, avoid that park on the weekends.  Lots of locals show up to "drink around the world" and it can get ugly - Walt would be rolling over in his grave.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Link to comment
Hi Pete, Glad to hear you are enjoying it.
Hi Bob,
I wondered the same thing about the upper and lower planking but they are different widths
so the majority of the planks overlap. It looks like that all but one plank on each side will be
an overlap. Once I cut the planks and add the construction paper I’ll know for sure. As far as
assembly of the second planking I will do it off model. I plan on using lengths just long enough
to get into the circle and then cut it close with the scroll saw and finish with a drum sander.
Again that’s the “plan”. ;)
As far as mouse world goes thanks for the hint. We always try to avoid the weekends whenever
possible. Especially this being a holiday weekend. :)
Well the Admiral is waiting so it’s Hi Ho Hi Ho and out the door I must go. :D
Rusty
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
