Cutter Cheerful 1:48 by rafine - Finished
I've completed the starboard side topside planking. Same as the port side, but it went a little faster (the old learning curve :) ). Now it's on to the stern planking.
Bob
Link to comment
Share on other sites
beautiful work Bob,
Looks nice and clean for upper planking and wales...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Summer is vacation time (although my family always asks what retired people take a vacation from  :P). As a result of the travel, progress slows considerably.
I do have some new work to report. I've done the planking of the counter and the transom. The first step was to trim down the outer stern frames. I did this with a #15 Exacto saw blade initially, and then sanding sticks. The planking of both areas went relatively quickly and easily, with some shaping and bending of the planks.
Next will be the fashion pieces and painting the counter.
Bob
Link to comment
That looks really good Bob!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Link to comment
Bob I just came across your build and I would like to say that is one of the neatest planking jobs that I have seen in quit awhike.
David B
Link to comment
Link to comment
Some further progress at the stern. First, I painted the counter planking  red. Then I cut the fashion pieces from a boxwood sheet, bent them to shape and glued them in place.
Bob
Link to comment
Beautiful work on those fashion pieces.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Back from another summer trip and eager to to get back to Cheerful.
I chose to deviate from the sequence that Chuck and the other Cheerful builders have followed at this point. Rather than doing the wales and the lower planking, I decided to treenail the upper planking. My reasoning was simple -- I hate to do all of the treenailing at once, and this allowed me to break it up. The treenailing was done by the drill and fill method, but I chose to use a more visible filler, rather than the subtle ( and likely more accurate) route taken by Chuck. I must admit that I simply like the look of the more visible treenails better. After completing the treenails, I applied a coat of Wipe-on Poly as a sealer.
Now I will move on to the wales and lower planking.
Bob
Link to comment
beautiful treenailing and planking Bob,
very clean and good looking hull !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Excellent work Bob B) The treenailing looks great,to be honest,I have used every material for doing these bar fishing line,but I don't think the filler route looses anything to the others unless you are after a structural fixing ;)
Kind Regards
Nigel
Currently working on Royal Caroline
Link to comment
Good evening Bob doesn't that look wonderful,
Maybe one day kevin you could do something like that
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Beautiful tree nailing work, Bob! I love the slightly stronger contrast between nails and planks. Otherwise, if you don't see the nails, why do all the work?  :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Link to comment
I like it as well.  Welcome home!
Augie
Previous Builds :
Link to comment
Work on the planking continues. I've now added the second layer of the wales and painted them black, and done the first two strakes of the lower planking, including the drop plank. Those lower strakes were given a rough sanding.  If I had it to do again, I would probably not add the second wale layer until after doing the lower planking, since the the paint got pretty nicked up and will require extensive touch up later.
In any event, I will now move on to the remainder of the first belt of lower planking.
Bob
Link to comment
Sorry about the paint nicks... seems to be an occupational hazard.  But nice work on the drop planks.
Augie
Previous Builds :
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
