Steam schooner LENA by IgorSky - BOTTLE - scale 1/290 - Finished
Very nice work, Igor. Since I started working with PE at 1/350 I now know what you are going through with for example the railing. You are even having more chance to damage items on your build as mine is at a far larger scale. Well done my friend!!
Carl
Link to comment
Share on other sites
Hi, Carl!
Many thanks!
The handrails in front part of the hull were broken off several times in the process of the work, because I glued them too early :(
Link to comment
And, finally, I was able to proceed with the final assembly at the stand.
Assembling was carried out in the same order in which it will be made later in the bottle.
At this stage I revealed some mistakes that are likely to affect the assembly in the bottle, but ... something to alter it's too late :( Although, of course, I will try to fix some of them. For example, I'm going again attach ladder to the bridge and I will to lift up the lifeboats.
So, first I installed the rear mast, the engine room and the bridge.
Link to comment
Hey Igor
At last!  I've been waiting patiently and now, with these updates, I'm not disappointed!
Definitely your best model yet. I'm really loving all the fine details that you're adding.
Beautiful stuff!
Cheers
Patrick
Edited by Omega1234
Link to comment
Hey Igor
Beautiful stuff!
Cheers
Patrick
Hi, Patrick!
I am glad to hear you again!
Many thanks!
I would say that this model is a good school for me. I was able to check out a lot of my ideas, technical solutions and technologies. Of course, I could not avoid some mistakes, but I hope that the experience of this project will allow me to avoid them in the future.
So, we go ahead :)
I then installed the davits complete with the lifeboats and began compiling the assembly diagrams and marking of the ends of the rigging
Link to comment
Link to comment
Yes, the work went very slowly over the last two months, but still some progress has :)
"Work went very slowly", he says.  From hull to finished ship, that's all.  well done.
Bob
Current build:  SS_ Mariefred
Link to comment
Link to comment
Link to comment
Hi, Bob!
But I have started this project 1.5 year ago :(
But just look at all the other SIB's you've done in between.
Bob
Link to comment
fantastic work Igor !
must be a bottle with a super wide throat, unless the hull is placed inside bit-wise... :P
I`m curious what is to come.....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Link to comment
What a wonderful chess set.  But I don't have tweezers small enough to move the pieces without knocking all the others off the board.
Bob
Link to comment
Link to comment
Link to comment
Link to comment
As you remember, I set on the deck several lifting eyes for fixing the rigging. Lifting eyes have a hole diameter of 0.2-0.3 mm. Since I'm going to put the mast in the bottle separatly from the hull, it will be quite a difficult task to stretch the thread through the lifting eyes. So I decided to insert the temporary loops from threads into them.
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
