Gokstad Viking Ship by jack.aubrey - FINISHED - Dusek Ship Kits - 1:35 Scale
A complex piece made with hard wood from which I got the two brackets to support the hull. They will be placed over the display case basement.
y4mBmCwTFH_AYc2_KMDB92DFTtjm5fRSDMrfDMYX
y4mLZ_1JB3VG0NLHc4tAgTvXBFzpP_ARB7flLp7e
With a cut made in the right place, done with the yable saw, I got the two pieces shown here below which will hold the keel on the basement shown in the previous message.
Now I have to drill them to accommodate the keel holding screw.
Then I'll paint them dark red (same color of the shields).
To be finally fixed on the basement in the correct position.
y4mpPTZ5SEXT7WnrWqIUdB-Bx9AVMyA88ft6HoM9
Cheers, Jack.
My personal assistant to check the proper progresses of my work in its strategic role as project supervisor . .
y4mcm8eAmmcUDO3GyCaOCYB2gX3MMfXP2pG9chSE
Edited by jack.aubrey
Link to comment
Share on other sites
Hi Jack, I just want to say what a beautiful job you are doing on the Gokstad. I have been building the same kit for the last week and I find I am constantly turning to your log to see how you've done things. So I really appreciate your step by step details. I hope you also show the rest of your plexiglass showcase construction as I have a few I need to build.
One area that slows me down is how to finish the planks at the bow and stern. When you look at the reconstructed real ship it is evident that they carried the clinker plank overlap right to the ends. I think that's how the clinker system is supposed to work. So far (first 4 planks including the garboard) I am ending the overlap a few centimeters before terminating the planks so that they are edge to edge as they seat into a rabet that I cut. The way the final ribs are cut doesn't seem to invite the planks overlapping at the ends.
Anyway beautiful job!
Regards, Ian
Hi Ian, first of all many thanks for your appreciatons . .
Regarding the planking at bow and stern I'm still a little bit confused. My understanding is that at the end the planks seem not to overlap but are gradually aligned edge to edge.
The following image shows what I mean probably better that thousand words.
What I don't have clear is HOW they got this result . .
Link to comment
Saturday, July 23, 2016
Positioning test to verify if the size of the basement is right . . . Well, the oars are there, then the size is right.
y4mHO25KiWoFJGj0aUGdlQyBFPEa_55xfWV95Ww7
y4m-RTMHrWGwaaKgLPdLm7BvJSGx0LmMCTpfY5UG
y4m4dhTp2lhwm4kkw1Sg07TdxgNBTX-m5a3Up2E9
y4mt3e4qAoFQ2f3LSE4ltSKzDulAkCrGPWLVCvNg
Today I painted the basement frame, the underlying pins and the keel holding blocks with an acrylic dark red paint.
Finally I glued in the final position the two blocks with a bi-component epoxy glue.
Now only the plexiglass is missing to complete the display case, but I have to wait 'cause I need to install the mast to define the correct height of the case.
Link to comment
My attempt to model the seats for the oarsmen.
In practice this is the famous "sailor's box" where the owner kept his personal belongings with a blanket added over its cover to soften the sit. When the ship run with sail the whole was stored under the deck planking.
y4mFr2rOqjbffGLJAsCk-mdtNgzjisPpwoa1bXS0
y4mGK3Ln7OJ0hRRo_Aw_8ZvjrnojElc2_9WYeEAT
y4m1Pm4_smuvZG6s-WYMmKx2OE2sBius_F7H3roi
Here below the reference image for my idea. .
y4mobgvRP307aerUnSf3WhsS3PHkLkR8g_BubQSr
Link to comment
A batch of images of the model installed in its case, with all the oars shown. The base of the case is almost completed, except for one thing which will be discussed later. Till now I'll focus on definitely fixing the pieces located on the deck and to finish the seats for the oarsmen.
With respect of the element mentioned above, I have found that if I don't find an elegant way to keep held the oars, they tend to move easily from their original place. So I'm thinking at a kind of guidance with joints where inserting the blades of the oars. Obviously it must be a minimal and simple structure, which must not attract the attention of a hypothetical observer, other the whole may be disturbed.
Finally I think one or more plates with the model name and more.
y4mvqbCx88TkxCh3EPLjmF3yMtrI1vyE_CK4oVRW
y4mPg92yrJ-4qrzLQbfQ8V-HWMS7DyR-ExBcVIFx
y4mhwKiwHtpKMK3a8Yv4Tel96Ji6i6pQ2RjbSZiS
y4mA07T4ylg2qzTXYTYDw-Ucjw1Px2ETrmBt4m0l
y4mGPaSEdCq8Bqp7xr1Ewswy0RD-zAWaL7hQFKxO
y4mTiJJSJ-7xQlO1Lbt1sYnZjhFAxDqe9JxYF2jp
y4mUtNXp3kBZNbjY_w9FBs2zXyxaqj64kbPk5vC6
y4mVY65C0-zlYq5U2QfEMdgyMDp2Q3tGgBhD7X2r
y4mNlq_PXVEb5GLJcWrEdiGVWF-h4cN1j1T9tD7R
y4mcIdHNWlCJTFEJ0j3o6I_Vi0lWhpQ7FNLdtS7V
Link to comment
Looks great, Jack.   Since it's on the base, would a spot of glue where the oar goes through the hull and another under the bladetip work?   Off the top of my head, that's all I can think of.
Link to comment
Wednesday, July 27, 2016
Another small step forward: I finished the building of the oarsmen's seats and sailor's boxes and, after giving a coat of clear matt paint to the deck, I proceeded to glue them in the same way of the drawing I reproduced some messages ago. Then, considering that hardly the viking warriors were equipped with common uniforms, I thought to paint with different colors the various blankets over the boxes.
An additional note of color most probably plausible . .
Then I continued to permanently fix the other superstructures on the deck: the two lateral mast holders and the mast foot where the mast is inserted and held when the ship runs with sails.
Now the most important, and still missing piece, is the rudder, after which the close of the shipyard is approaching more and more . .
y4mEtMkKWJhzmuJ9lW4a9xo_yVUudveTT0yw7QeO
y4mmkuzt1YjqlGQ-PdnA9vLIQk7cpfMy0xT3ojrY
y4mW9Fi0tadeXrII7DY27BCbOxF0-Tpm-YWR6wTA
y4mpUUhaZo_Ic68UtCll_TkVFOn72E22_1OTCdDb
y4mYyegKsi0FL0P3OymiA7UUQn7wVvS8ewdbxPXy
y4mXSmqbHfrTK41iFagq2qR9E2fOIOLfGw2kWG7h
y4mF_dWhjF9FeEq6hWEmyUwnpwtLf1hI2bbAsqnu
Link to comment
Hi Mark, thank for your suggestion but I don't like it 'cause it forces to permanently fix with glue the oars . . and I prefer to avoid this fact.
I'm thinking to a plexiglass curved bar, +/- 8mm height, with its shape following the sides of the ship and with several slots where the bladetips should rest. This bar should be glued on the basement at the proper distance from the ship sides, close to the oar bladetips. Being it transparent should not interfere too much with the whole . .
Another (and simpler) solution shuld be to use wood instead of plexiglass, provided it has the same color of the basement . .
What do you think ? Thanks Jack.
PS: thank to all of you for your comments and likes.
Link to comment
Jack,
I lost sight of this build, unfortunately. You've done some wonderful work. A nice staining tutorial too.
Maybe something like this is an option: http://modelshipworld.com/index.php/topic/335-hmc-sherbourne-1763-by-tkay11-%E2%80%93-caldercraft-%E2%80%93-scale-164-a-novice%E2%80%99s-caldercraft-sherbourne/page-14#entry429052 I found it a very elegant method, and you could have the oars at a natural angle ...
Cheers
Carl
Link to comment
Saturday, July 30th, 2016 - Rudder
Today I've finished and installed the rudder . . next steps mast and sail.
y4m9FV32KmynJmqQtXKfUDMcyZdTDMAGolRUc1Te
y4mZ2RGZoPlTGskHOhYc2tCbG9Ngvf42wybCQoXK
y4ml_gn7R1lCJBd5ay2pmMIcqvvKPYC9rKiHe8xP
y4mu508LBliHaQ07VpKs9yhTIfhJEPV2-9lAk-nD
y4mF2lHV2H92gOwILIL10bW23UhnjXmdeHmDRh-w
y4mSRxd-r5wmTyPOEdA1Y0RjhQnwx6_QEkwbzQYx
Link to comment
Thursday, August 4, 2016
The first image shows the devices installed inside the ship to "plug" the hole in the hull where the oars were strung when they proceeded without sail. To the left of the pic the device in the "open" position and to the right the device when closed . .
y4mvGML249_y48E7FKVdDRczR8wPSKvncb_psBZw
Here below my personal interpretation: obviously it was not possible for me to make an exact replica of this device given the very small size (diameter 4mm) of it.
y4m-xcx-8rEn8ak-QVVmzFtyqRJkXrp5JiY2T8iB
y4mLYImN8-UApPbzdd35m3lPM_ycqjKKdtdKwkQi
Inizio dell'ultima fatica, preparazione della vela e installazione dell'alberatura . . per ora la vela (è la prima che provo a cucire . . .) fissata sul pennone, e poi alcuni dettagli . .
Begin of the last effort, preparation and installation of the sail and yard . . now the sail (the first I try to sew...) mounted on the yard, and then some details . .
y4moNgQhjVAHvFPZhCLp4uFFg_cvmbXn2U5RGzy8
y4m71oNxcdAfX2u5z4XaMELrQ3MGvuNhNKA_kFcd
y4m-ICqV9BXrYLeBM7chio7bBWfOSlWgiJmfyxQ7
Cheers, Jack.
Link to comment
Wednesday, August 10, 2016
I fixed the mast to the hull and I completed the "standing rigging", even if on Viking ship wasn't always "standing".
y4mdZyQvJXQbmSZJFnbihEHufEtEje3ErUEB30mm
y4mxK3cy_YVWb_2ahMalOTm4B2mGWQdfd13jnqKL
y4mjya1jy8qngYnAu69vyilfFx3-p8_oBPG5i1Sn
y4mFk3fTJ9RxklVEiwZD9KFlzA9AdUpbjGNP9VBa
y4mFBzEUHq1Uaktt3AtlG_9UIK--rDbK2OSp8_Bc
Cheers, Jack.
Link to comment
Thursday, August 11, 2016
Here follow images of the model almost finished, only the plexiglas cover and the oars cradles on the basement are missing.
Rgds, Jack.
y4mQynPzJRvWlBm2TVMWeAf14TiwWFjJaQloeX6i
y4mr6wtretqyoknwfIY9ULe6YqUANhgGUglsHyZT
y4mq0eghlX73s5uh0lHnV604Vc0ixcW_KIygPcTo
y4moIrjwoJjx__QyOQr8yyIMNw00MSu0vJ-SFK1R
y4mBnAIfemVKIm0KxVXo7JABSSHHC0_6ihi7Ug51
y4md1XnQN-uMSduTKpJCCqvNguPONj19zjR-HAxu
Link to comment
Link to comment
Additional images of this ship, same status as yesterday . .
y4mog4xyco3_Lb1IiBvIPtjaPkgvRt9VMASBgbgE
y4mx_5WJxc77F4ptRDsgMY6UwyatqWOmZG-lj2su
y4mOOk2nuqNtSUUNVIR0V_SWlZoUei4GLV5Ukdo5
y4mRn8PlDANU-vJb9ByquaRA-DlSA_ZcX82dBIwt
y4m7cai-FsPkNV7sm0DR3ZDw97mgxs5VukLrbNqx
y4m1tkyRCyI4GW_I_jb0U9GhOVFPyV7yi29P8Ne_
y4mZwUdd8E_DfsaxNTnl5-ksW5ss_zzKorrIzKZ2
Link to comment
Friday, August 19, 2016
The basement of the "display case" finished . . now only the plexiglas cover is missing.
y4mDow1Xwu4zmEv-nf_kGqU2Xlqoxpc2yvCscDHY
Details of the device for housing the oars, with the grooves to hold them in position at the correct distance.
y4mxJ0oA3b-TivXvjiQ4k9Sb9-fr2pNs0dusfFu0
y4mn8S62U08Gzx9PTXewQXdU594rrgYdnAfj_o_7
That's all for now.
Most probably you will not have further news for some time.
The plexiglas cover will be made by a craftsman specialized on this kind of tasks and I have no idea about the time it will take to make it . .
Only then I will be able to shot some final images of the entire, finished model.
Cheers, Jack.
Link to comment
Neat idea for the oars support Jack. Looking forward to seeing the final photos.
Link to comment
Very nice build, Jack. It'll be good to see it all displayed.
I envy you only having to make 30 oars. My dromon has 100, and I don't have a lathe. I'm up to 36 so far . . .
Edited by Louie da fly
Link to comment
Good luck with your 100 oars . . . for me 32 oars plus a tenth broken was enough . .
Rgds, Jack.
Link to comment
I've broken and thrown away maybe 5 or 6 oars, but on purpose - they weren't good enough. I find that when I try to hurry, the quality goes down dramatically. Trouble is, I keep forgetting the lesson and have to re-learn it by messing up good oar-blanks.
Link to comment
That's a nice solution for the oars Jack. I may copy that if you haven't patented it yet :).
Regards, Ian
Link to comment
Torbogdan, do Dusek specify the shapes of the bireme's oars? You might like to have a look at the contemporary representations of Ancient Greek galley oars among the images here.
While doing my dromon, I've got very interested in oar shapes. I've made mine as close as I can to contemporary representations, but as no oars have ever been found, it's largely educated guesswork.
Steven
Link to comment
Steven
On top of this picture is shown the shape of the viking oars for this ship. Some were found inside the wreck in Gokstad.
As you can see they do not correspond to the oars I made. They are much more simple and primitive (in shape) vs mine. I preferred for my model a more "classic" but recent oar shape, more suitable to build with a lathe.
The plan contained in the kit from Dusek reports the same shape you can see in this picture.
Link to comment
I'd never seen these oars before - thanks very much for posting them. But are those other things steering oars? It seems strange that there are three of them for a single ship.
Steven
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
