Mirones
HMS Prince 1670 by Mirones - Constructo - Scale 1:61
Greetings,
after thinking for a long time and being un succesfull with plastic-kits i buyed my first wooden kit the HMS Prince of 1670 by Constructo around May-ish from Spain. With alot of Pause in between my work sessions i finally managed to get the first Plank on.
getting started in May:
Sadly i used the wrong deck planks at the bow these were intended to be the vertical Walls :( .
June: after some break adding the fake decks and adding the first planks huray.
Sadly i later had to find out that the fake decks accidently shifted around 1-2mm to starboard wich is causing me some minor problems wich take some time to fix.
August - November: adding more deckplanks and the first Bulkheads/vertical Walls.
Later November: getting the first Planking on the hull.
i hope to get the basic Hull done befor new year. Some tips about steaming the Planks for easyier bending are alot welcome, the material is 2mm x 6mm thank you in advance :cheers:
Share this post
Link to post
Share on other sites
Get yourself a pair of plank bending pliers, which helps a lot. Also yake your time and research at least two or three steps ahead before you start each task.
Mike
Share this post
Link to post
Yep, the Pandora was one of my favorite builds, I chunked the prefab transom and stern windows and opted to make my own out of wood, It turned out great. The Pandora is now resting in a harbor of someones living room area in Canada where it was sold and ship to, also along with the Bluenose and Mayflower.
mike
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
