Schooner Altair by KeithAug - Scale 1:32 - 1931 - Finished
Over the weekend I almost completed the launch.
The foredeck was planked - hard to tell though. I also made the foremost bench together with the 4 gussets that reinforce the attachment to the hull.
The trickiest bit was the splash rail. The corners were much too tight to bend so these were cut from solid. Once mounted on the deck  rail the were joined buy 3 bent planks.
It's probably worth explaining that I am using 2 sources of mahogany (one much lighter in colour) to add interest to the launch.
I then added the interior detail of the engine housing, prop shaft cover and instrument bulkhead. The engine housing has the gear lever mounted.
The rudder then went on with the bracket to support the lower end.
I made and mounted the brass fittings on the small foredeck. The brass protective strip for the stem was also made and mounted. By this stage I had given the inside a coat of poly - still a bit wet when the following photos were taken.
fullsizeoutput_10fa.thumb.jpeg.ec9baf5b82252d9da21a93b20ec69e0c.jpegIMG_0198.thumb.jpg.695167389963a34a5250e1a88639c1d9.jpgIMG_0206.thumb.jpg.68e685b4a40da2004ad428ae979d5f5a.jpgIMG_0209.thumb.jpg.6cb25f9ad4b917492c48b070b5510e3f.jpgI have delayed mounting the wheel and throttle lever until the internal painting is complete. I now need to make the cradles for mounting the launch on the deck.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Share on other sites
Wonderful detailing Keith, the launch is a mini-project in its own right.
cheers
Pat
Link to comment
Keith,
You have really disappointed me for the first time. With your undeniable machining skills I cannot believe you haven't constructed a workable mini diesel motor for the launch, I see the engine cowling and hump for the transmission. All kidding aside the launch is a 10+:cheers:
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Link to comment
Guest Riccardo1966
Hello Kieth,
The launch is beautiful, easily good enough to display on its own. The colour of the wood and the finish that you have achieved really shows up well in the last photo. First class scratch building.
Richard
Link to comment
Thank you Pat.
John,
 Sorry, I would have but I could not find spark plugs small enough ( i think in 1931 it was a petrol engine).
John,
On 15/01/2018 at 7:18 PM, Jim Lad said:
Well, I suppose the launch looks fairly reasonable
You sound like my wife, have you been taking lessons?
Richard - thank you.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
6 hours ago, mojofilter said:
especially like the contrast light/dark mahogany
Thank you Tim.
The darker mahogany is circa 100 years old. It is quite dense and close grained. It came from a once very nice dining table which i suspect was made from prime timber. Not very much like the mahogany sold today. The lighter mahogany was from block flooring recovered from a old building before being relaid on my daughters kitchen floor. I'm using up the offcuts. I think its about 50 years old. It does have a more open grain and fibres lift when coarse sanding.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
I finished the launch by attaching the wheel and throttle lever.
fullsizeoutput_1107.thumb.jpeg.01f9dc2a647bc513afd8ee9a636d7a3e.jpegfullsizeoutput_1108.thumb.jpeg.535b5fe0d34a31c0301115a719f202ce.jpegfullsizeoutput_1109.thumb.jpeg.49b54235f320fd5a9f22bbff8f119e03.jpegfullsizeoutput_110a.thumb.jpeg.b98dd4c3f4ec2f24e3f37946a2ad30e9.jpegfullsizeoutput_110b.thumb.jpeg.65cc9f8a58f90d7baedd9ff11012e395.jpegfullsizeoutput_110c.thumb.jpeg.3841467269764ef6d4055dffadef31ef.jpeg
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
That is superb Keith, love that polished detail against the wood - exudes 'luxury', or should I say 'money' :)
cheers
Pat
Link to comment
That is a very sharp looking launch. Well done!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Link to comment
Keith,
It goes above and beyond any description. maybe the best word is PERFECT. Double Toddy:cheers::cheers:
John Allen
On deck
Finished
Link to comment
Pat, thank you and yes she is a rich mans toy.
Hakan, Thank you.
John, Thanks. a wee dram sounds like a good idea.
The time came to introduce the launch to it mother. I made it cradle from mahogany strip, shaped using the templates for the frames. The holes for the lashings were reinforced with brass rivets (visible in the photos). The cradles are each held down using 4 spectacle repair screws. I made a card template to align the cradles and get them in the correct position.IMG_0268.thumb.JPG.c80145ab421e0d435a246bb107ccfb49.JPGIMG_0269.thumb.jpg.ffbef3eebb130cd2f105e76abf347f21.jpg
When the launch is on the cradles it fills the available space and must restrict deck operations to a significant degree.
IMG_0273.thumb.jpg.fcd2f9da7457462d22fd581a4fbec171.jpgIMG_0271.thumb.jpg.76d6da6840e34ba0d63c426ccddc311f.jpg
Altair actually has 2 other boats, both smaller than the launch. Photographs of Altair frequently show no boats on deck and when they are carried the smaller boats seem to be favoured. In the photograph immediately above I have removed the aft davit to ease access.
I lashed the launch in place using a length of twine. Several photographs show the launch lashed in place. Mother is very pleased to have baby on board.
IMG_0275.thumb.jpg.62a89d32557a21733f4dba095e3fc54c.jpgIMG_0277.thumb.jpg.d1efa89ecfd7caa2cd5eb938985e200b.jpgIMG_0279.thumb.JPG.6eef66a60162b764119d62b403f2078e.JPGIMG_0280.thumb.jpg.e4dbd1e4013c93bd160ba3cfc1ca2056.jpg
 I'm going to try and make some progress on the stand this week - before a diversion into refurbishing my daughters bathroom - yuk!!!
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Wonderful work Keith,
a real classy launch for a top classy yacht, looks awesome !!
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you Nils and John.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Over the last couple of days I made progress on the stand. Im planning to suspend the yacht on 4 legs and the starting point is to work out the proportions of the legs. This I have done by selecting the frames where the legs will sit and then drawing the adjacent leg to scale.IMG_0297.thumb.JPG.a1d8fd195093c1dac6dc27f0386a6aba.JPG
The legs are made from polished stainless steel. Not a material I am very fond of working with.
Where the side arms abut the hull I wanted something more forgiving than metal so the ends are machined from nylon. A brass insert between the side arm and nylon end will can be machined to tune final fitting.
IMG_0299.thumb.JPG.4144e4beb71115a4e8809465da650257.JPGIMG_0300.thumb.JPG.8fc526043417c6a7cedb84144c5907bd.JPG
The top of the legs provide side restraint and where they bear on the hull they softened with "O" rings. The "O" ring grouves could have been machined directly into the stainless but I thought the brass end added a bit of interest.
IMG_0301.thumb.JPG.baca8e2480288b16fa4bf6338dcf338d.JPGIMG_0302.thumb.JPG.9be3908a77636b039afdb6e6ed914390.JPGIMG_0303.thumb.JPG.c9c2795621cc9b88647d05b6660dcebd.JPG
The bottom of the legs are drilled and threaded to take the base attachment bolts.
A 1/4 inch thick stap joins each pair of legs.
IMG_0305.thumb.JPG.8cad72f5f312d406fd33a8df0bf3a987.JPGfullsizeoutput_110d.thumb.jpeg.5e0114c808c401ced8f85577abe11db1.jpeg
The base board is next.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Stylish Keith :-)
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
Link to comment
Very, very nice. A really elegant and stylish way to set off the Altair.  Best, John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
A very complimentary stand Keith; just like an upmarket hard stand cradle?
cheers
Pat
Link to comment
Hi Keith, Beautiful work on the launch, I have to admit I am not fond of the white line holding it to the deck though. I would have thought that a couple of leather covered straps would suit the luxury of the launch.
Your solution for the stands are not only very elegant but are very nicely crafted. I look forward to seeing the yacht in her cradle.
Michael
Link to comment
Haken, Pat, Richard, Mark. thank you all very much for your kind comments.
Michael, an interesting thought. The only photograph I have is one of the smaller dingy strapped to the deck. Here the straps seem to be of webbing.  To carry off the leather idea the leather needs to be very thin and i know of a source as my wife is addicted to fine leather gloves. She is also apt to lose one every now and again so next time she does I may do the upgrade.
No boat progress this week although I have ripped out tiles, rebuilt walls, plumbed in sinks and radiators, and laid 140 sq ft of ceramic tiles. My daughter is pleased.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
I really must crack on and get this build finished. At least I have had time to finish the display stand. It took some time to trim the front legs to get Altair to sit with her waterline level. Now all that’s left to do is make and mount the ensign and the Royal Thames Yacht Club flag. Oh and replace 3 stays that have loosened as the model has acclimatised to the house conditions.
I must catch up on other people’s logs before I get withdrawal symptoms.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
That is a very nice display stand Keith; it should set off the model beautifully.
cheers
Pat
Link to comment
Truly beautiful work, Keith -
The launch and mother ship are beautiful together, and the stand is a piece of engineering worthy of any Museum of Fine Design.  It has been a privelege to follow along on your journey.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Dan
What he said!
Link to comment
Pat, Dan, Tom and Bedford - thank you all for your supportive comments.
Today I was looking at the yacht  thinking “that’s it” when I noticed the obvious omission.
Sometimes in life we lose the big picture in all that detail and end up rudderless.
I made the rudder in September 2016, now I just have to find it.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
