Revenue Cutter 1817 by Eric W - FINISHED - BlueJacket Shipcrafters - 1:48 - first build
The deck house looks very good Eric!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Share on other sites
This weekend I was able to complete the hatches, bilge pumps and bitts. There is a typo in the instructions: the bitt stanchions are part LRC18 not 16. I also shaped the tiller, which like the hatch hinges, was "feel as you go". I used a vice and pair of needle nose pliers. The holes in the deck are for the life rail stanchions.
Link to comment
I have a new "arch nemesis", the 1/8" gun tackle block. The carronade went together well, but the 1/8" blocks were a bear to get pigtails on and rig.
I used a magnyfying glass vice and tweezers. The 3/16" blocks were quite a bit easier and fortunately that is the primary scale for the rigging. Any advice on rigging small blocks would be appreciated. This experience might shy me away from anything smaller than 1/48th scale.
Link to comment
Eric,
Do you have a "third hand" or locking tweezers?   I find they help immensely along with some magnification.  You'll still need plenty of patience and some extra blocks for those that go flying off in the twilight zone.
Looks great...
Link to comment
  • 3 months later...
Hi Eric,
I missed the last page or so of your log, my apologies, but just caught up and read your question about rigging small blocks.  I posted a sort of 'mini-tutorial' on how I did the single blocks when rigging my cannon in my build log - don't know if it's too late or will help, but feel free to take a look:
http://modelshipworld.com/index.php/topic/8085-armed-virginia-sloop-by-gunthermt-finished-model-shipways-scale-148/page-24#entry328294
Link to comment
First off, bluejacket pre-drilled the mast holes which made the initial alignment easy. I bring this up because apparently that's not the case with the model shipways Phantom, which baffles me as an entry level solid hull model.
Edited by Eric W
Link to comment
Another "oops" was on the jib pole. You make a 1/32" hole in the jib pole and run a .010" line through it. I could not get the line through, so I sent the bit back through and popped the tip of the jib pole right off. That required more micro-surgery with tweasers and a magnifying glass. I wrapped the line a few more times around the pole to camouflage the break and strengthen it.
Link to comment
One area I am going to modify is to take the ring off an eye bolt and use that instead of the wire suggested in the instructions to secure the block to the traveller rod for the boom traveller. Funny thing is, bluejacket shows this technique (ring instead of wire) in a photo in the instruction manual. Attached is a photo with the wire used
Link to comment
Good job! Your boat is looking good!
Edited by Elijah
-Elijah
Current build(s):
Completed build(s):
Member of:
Link to comment
One big issue was drilling holes to put the blocks into the gaffs. I snapped the foremast gaff in two and had to make a significant repair. In the future I would do a #55 bit.hole and put an eye bolt in first, then wire the block to it.
Eric,
Looks like you are making nice progress, but in your second picture in the post I quoted from October 10th, it looks like the line is not run through the block on the gaff properly.  Might be just the angle of the photo, but it doesn't look like the line is coming out of the far side of the block at all, or am I missing something?
Link to comment
Okay team, have a question: original brass finish for the life rail stanchions, or black to replicate wrought iron? I like the look of the brass, but think it may not be authentic. I also attached an overhead of the carronade rigged to the deck. To get the coiled line effect, go with at least 18" of line for each rigging point. I "coaxed" the coils in place with a little glue at certain points to help the thread maintain it's shape.
Link to comment
So, I went with wrought iron. I painted them, then dry fitted each stanchion back in place. They went in without any issues. Last step was the halyard for the ensign. For my first wooden ship model build, I thought this cutter was moderately challenging. I would highly recommend it for a novice like myself.
Link to comment
  • 11 months later...
  • 4 months later...
  • 3 years later...
  • The title was changed to Revenue Cutter 1817 by Eric W - FINISHED - BlueJacket Shipcrafters - 1:48 - first build
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
