probablynot
Silhouet [finished] by probablynot - Constructo - 1/60 - Dutch 'tjalk' river cargo boat
Nearly finished.
Still some work to do on the flying jib, and then I need to tighten the mainmast backstays (to tighten up some slack that crept in while I was rigging the foresails).
After that there's just a few hanks to be made and added, and there are one or two places where the paintwork got damaged while I was poking around with scissors, clippers and my special rigging tool.
But ...
I wonder if you can spot the non-deliberate mistake I made yesterday, and discovered when I started work again this afternoon?
Of course I've corrected it now!  But  I had to laugh at myself for making such a careless, beginner's error!
Share this post
Link to post
Share on other sites
Looking again at that 'non-deliberate mistake' pic above, I'm reminded that I do have a little problem with the shrouds that are supposed to be attached to the ends of the spreaders.
The spreaders are a bit of 0.8mm brass wire.  The shrouds are 0.6mm dacron cord.  I've glued them and glued them again and again (with CA) but I only have to look at the shrouds to make them slip off.
I did file a little groove in the ends of the brass wire, and it helps, but only marginally.
Any suggestions?  I'm thinking of using ordinary sewing thread (of an appropriate colour) to apply a serving, and then impregnating that with CA.  It would create a small lump, but probably wouldn't look wrong.
Share this post
Link to post
She's complete!
About eleven months' work, some of which I'm proud of, some of which I'm more or less contented with, and some that I'll regard as part of the learning curve.
I wish I'd been a little more meticulous with the paintwork, especially around the cabin window frames.  But I'm telling myself that the Silhouet is a working boat, maintained by her crew, and I'm blaming the careless brush-strokes on little Hans the cabin-boy, who had spent the previous night drinking and smoking grass with his girl-friend Gerda.
I decided not to reinforce the shrouds where they meet the mainmast crosstrees.  Instead I used a tiny dab of contact adhesive.  Now that I'm no longer having to work on the boat I think they should hold OK.
Here are a few detail shots, to complete my build log:
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
