Great Republic by rwiederrich - FINISHED - four masted extreme clipper - 1853
Yes.....I agree with both of you.  I suspected it was going to take up loads of room...but when I placed it in the actual space it would occupy..... It gobbled up the space. and then just cramped the area, resulting in a complete imbalance of the room.  It's not just about displaying the model, but creating a well balanced room.  the place I ended up compromising.... does place the display off to the side  a bit but, it doesn't overpower the space...distracting from all the other viewable items in the library.
Rob
Current build:
Finished build:
Current build(On hold):
Link to comment
Share on other sites
Rob, it sounds like you embraced your inner Feng Shui. I'm sure you're room will thank you.  Not to mention the room will function better. 😄
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Link to comment
Just back after a PC disaster Rob (got hacked0 - sorry to hear you had to change the planned display position for your model but you seemed to have resolved a good solution.
cheers
Pat
Link to comment
I haven't worked on the case for a while(so much family stuff going on), but I think I will build a short base to elevate it up about 7", just under the bottom edge of the stove mantle.  I'll relocate some pics.  Here it is simply sitting where it will be...next to the shelves in a seldom used corner of the library.
The stove does not blow heat on the case...it's a relatively cool location out of the way.
Rob
Current build:
Finished build:
Link to comment
Nice cosy library you have there Rob, pity you can't get it higher but has the advantage of better shoing the rigging and looking down on to the upper deck.
cheers
Pat
Link to comment
Pat...it will be higher.  I'm currently building a pedestal that will raise it just over 8".  I'm just fenagling with all the level issues that are associated with the built in.  Once I correct all that, I will paint it an antique metallic color.  I'll then post some pics.
I figure, once the case is acceptable, then, I'll return to finishing up the model, with addition of the starboard shrouds.
I'll be using those small round LED lights that you press the lens to activate...for the lighting.  With them aiming down into the case.   They illuminate quite well.
Rob
Current build:
Finished build:
Link to comment
Sounds like a nice way to display this beauty Rob, look forward to seeing the completed case.
cheers
Pat
Link to comment
Thanks Pat.
I wrestled with the new location...but there just isn't enough room to place her anywhere else...and the room is a library....not a model display room.  Starting out, my collection was small and space was more or less available.  But now an entire wall is a book case and as you see in the image there are built in shelves along the North wall(both sides of the old incased chimney). (Partly seen).
Up until now, I haven't given to much thought about displaying the Great Republic....I just piddled along in the shop building her...always moving forward...without much planning, concerning her display.
I did entertain the idea of placing her on the mantle over the stove...but she would completely block the painting...not to mention she would be there NOT in a case.  Dust is always a problem and with her, it would be a nightmare to try to keep her clean.
We'll get there.....
Rob
Current build:
Finished build:
Link to comment
Well I built the riser for the GR case and leveled everything up too.  It looks better and much taller.  Now on to finishing the Great Republic.
Here are some pics of the library after I rearranged a few things.
Rob
Current build:
Finished build:
Link to comment
Nice library Rob; a good cosy place to settle back for a good read or to take a pleasurable look at the models.  Your new case fits into the aesthetics and ambiance of the room very nicely.
cheers
Pat
Link to comment
cheers
Pat
Thanks Pat.  It's a big case...for a big model(and at 1/128, that says a lot).  When the fire is crackling, it is so comfy nestled up on the couch with a good book and some coffee.  When my mother comes to visit..she loves this room to sit and read in.
Rob
Current build:
Finished build:
Link to comment
12 hours ago, Tigersteve said:
Looks like a nice cozy space.
Steve
I've worked hard to make it so...and a great portion of its design goes to my sweet wife...who has a great understanding of special design and flow.
Now to get to filling that case with a finished model...….
Thanks for the fine comments.
Rob
Current build:
Finished build:
Link to comment
I started again on the shrouds of the spanker mast.
Rob
Current build:
Finished build:
Link to comment
Spent some time today working on the shrouds and ratlines of the spanker mast.
Rob
Current build:
Finished build:
Link to comment
Now that that is done I am beginning with the first of the backstays....
Rob
Current build:
Finished build:
Link to comment
Not much more to do now Rob; looking good!
cheers
Pat
Link to comment
cheers
Pat
My son and wife just today said when are you going to fill that empty case.....?
Not, before the model is finished I said.....
Rob
Current build:
Finished build:
Link to comment
On ‎3‎/‎16‎/‎2020 at 6:14 PM, druxey said:
Nice to see the end in sight, Rob. It's been quite a journey!
Yes it has.  Time availability means the world.  I built my 1/96 Cutty Sark on its *ways* depicting her rudder repair...in just over 3 months.  The entire thing.  Because I had nearly unlimited time to dedicate to it...almost 8 hours a day...and if one is ambitious and tenacious...it is possible.
Here, with the Great Republic...she was made totally by scratch...just a set of plans and a start date.
I'll try to really focus on getting the spanker rigging finished up...because there is still some sail rigging to tend to and the national flag to mount.  NOT TO MENTION....I have a few more details to finish up on the head gear with the addition of some stays.
Apart from that..she is about ready to be put in her case.   All this really means is that as I finish her up..the Glory of the Seas is waiting..and she will be hauled out on the work bench and I will begin again on her rigging and yarding.   IT NEVER ENDS.  Then we'll be over at that log.
Rob
Current build:
Finished build:
Link to comment
Worked a bit tonight on the final backstays and the mizzen sheets.
Rob
Current build:
Finished build:
Link to comment
great looking case rob..........and you have some splendid displays as well Bob :)    great progress on the rigging...mizzen is awesome!
Edited by popeye the sailor
spoke too soon
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looks beautiful! You have taken every bit, piece and part to perfection and it shows in the final display. Very inspiring!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Link to comment
She's the only clipper to have had four masts. Was she one of the first four masted vessels? By the time of the iron ships of the next generation, there were 4 and even a 5 masted ship but not in this generation. I wonder when that started. Nice work Rob. She's looking great.
Link to comment
I'm getting close to finishing her...just a few more lines on the head gear and some flags.
I found this print of her.  she was amazing.
Rob(Hope to get her in her case soon)
Current build:
Finished build:
Link to comment
Finishing up...on the flags and the head gear.
And finished model.
Current build:
Finished build:
Link to comment
Got her put in her case......and lit up too....
Rob
Current build:
Finished build:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
