Dubz
Continental Frigate Confederacy 1778 by Dubz - 1:64 - kit based semi scratch
Loving your work Dirk.
I just read your tip on not fairing bulkheads 7,8,8B.
Want to guess what my job was this weekend - yup fairing the hull (including 7,8,8B)
Would you believe it, now I will have to put some kind of 'fix' in place like yours.
But please keep the tips coming.
Nick
Share this post
Link to post
Share on other sites
Thanks for comments and likes, much appreciated. Whenever you might have questions please don't hesitate to ask! :)
@Nick: Hmpf ...
Getting closer to finish chapter 3 :)
Stern ports on the lower counter…
It's so hard imo to be sure it is correct but I hope it is  ... hehe ... again pear was used ...
The fake frames. Roughly sanded
Before oiling.
After applying 1st coat of danish oil.
Frames glued.
Frames faired and sanded. 2nd coat of danish oil applied.
Result atm.
As you can see there are still some minor spots to sand, that's why I use the oil too as you better see these spots.
Not sure when the next update might come as I will have a surgery this friday ... gallbladder **** ... :-()
Cheers,
Dirk
Share this post
Link to post
Thanks jesse ... I hope everything goes well ... don't like that ;)
As I needed a bit more distraction I did more work at th stern. For me one of the most difficult part of a ship. I decided to fill everything to get the correct runs.
It took a whil to understand at least a little ho everything is coming together at the stern.
Starting the fillers.
Fillers done.
Some minor adjustments needed.
Cheers,
Dirk
Share this post
Link to post
Sweet!!! Dirk....real Sweet..... the stern looks awesome!!..... Best wishes on your surgery... you'll probably be out in a day if they are going to do microscopic..... mine too has been giving me a problem off and on...hope it stays off.. :D
frank
Share this post
Link to post
I did not have the chance to look at your build log for quite a while. Amazing progress . . . and SUPER work! You are moving the bar higher and higher  :)!
Btw, glad that your surgery went well. I used to work in hospitals and know that gall bladder problems can be pretty painful!
Thomas
Share this post
Link to post
Okidoki I'm kinda back. It's amazing how short recovery time is nowadays. I feel good, not perfect yet but good. As I won't give you a buildlog of my perforated belly, hehe, I will go on with the Confed ...
Before I went to hospital Chuck (he is "everywhere" and that is great :-)) drew my attention to an error at my stern.
So I tried to correct that.
I really hope it is ok now. I find it very difficult to do these lines and interpolated to the wanted endresult.
Left from chapter 2 were the planking of the sub-gun deck platforms. For the deckplanking I will use hornbeam the caulking is made by cardboard.
No danish oil here as I don't want any coloring. Tried Vallejo ... but might need to find another solution as Vallejo is coloring too a bit (going yellow).
After sanding.
Planking the bowsection (not glued yet, needs more sanding down to fit with the doors). Like the coloring of pear and hornbeam though :-)
Cheers,
Dirk
Edited by Dubz
Share this post
Link to post
Finished chapter 3 with doing the false deck.
Started chapter 4 and did the beakhead planking. Perfect linear sanding is not one of my best skills ... hmpf ...
Cheers,
Dirk
Edited by Dubz
Share this post
Link to post
Hi Dirk.
I'm glad to hear your surgery went well. Took me a bit to catch up with all your fine work. The stern looks really nice.
For me there were some confusing angles but you handled them really well. I continued to tweak the fillers at the bow
and stern right up to the point of planking.
I hope you continue feeling better. :)
Share this post
Link to post
Thanks guys. Yeah I'm quite ok, allready did a short 2.5km run. You are right Rusty, the angles are indeed confusing & tricky and I really hope I did everything right (It's always good to have Chuck in the background watching what we do though ... :D
cheers,
Dirk
Share this post
Link to post
Thanks so much my friends :-)
Nigel, I guess Daniel saved them, if not I have them ;)
Unfortunately Google closed their old, good working photoservice "Picasa" for something way crapier .... so I need to find an alternative how to host my pictures so I can "work" with them kinda the same speed as before. First try today is selfhosting. So if any problems encounter please let  me know :)
I started chaper 4.
The temporary batten.
My different approach. Under the batten I place another batten the same height as the sills (lasered from pear).
To correct the position a 0.5mm brass wire is used. I like it this way as I can play all of the sills on the batten and make sure to get a good run over all the single parts.
Sills done.
Lintels are done this way.
The same approach with "two" battens for the quarter deck.
Here were another pear/bulkhead transplantation neccessary ;)
Looking good I hope (?) Any comments & hints appreciated.
Cheers,
Dirk
Edited by Dubz
Share this post
Link to post
Looking good Dirk.
As far as hosting, why not just upload them to the forum?  I also have my own host, but for this forum I just upload them and it works fine.  I have my own copies both local and on my host server, so that way I'm fairly safe as far as not losing them to a single (or even double) point of failure, even without backups.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
