Washington Galley by Pirate adam - 1:48 scale POF
I am taking a break from my HMS Alfred to build the Washington Galley from the NRG plans.  I will start with the obligatory shout outs:
- The plan set by Jeff Staudt is fantastic.
- I am using the timber package in Swiss pear from Crown Timberyard.  The wood from Jason is beautiful and has been great to work with.  I am also planning to use some of the extra castello boxwood from my Lumberyard Alfred timbering set, which is also very nice.
- I have learned so much from all the build logs on this site, and I wouldn't even know where to start on a build like this or Alfred without all the tips and pictures from everyone.  Thank you to all.
Adam
Link to comment
Share on other sites
Adam:
This is great news - another Galley Washington build log.  I will be watching with anticipation.
There should be more build logs of this project by now with plan set #68 having been mailed out on Friday.  You will be one of the pioneers.
Take care,
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
First step was constructing the building board.  The building board was inspired by the one in Ed Tosti's Naiad build log and books.  I used melamine coated MDF for the board.  Two slots were cut into the board and two parallel sections of T-track were screwed in place level with the top of the board. I also attached some bracing to the back of the board with scrap lumber to add some stiffness and make it easier to pick up.
I drew a centerline down the middle of the board and attached the framing drawing to the board with spray adhesive.
Link to comment
Next step was building some fixtures to properly attach the keel to the building board.  I used moveable fixtures to hold the stem and the stern post.  This makes everything removable and should allow me to readily re-use the building board once I cut my Alfred model from its upside down Harold Hahn-style building board.
Link to comment
I am using brass wire for the drift bolts.  I though about leaving these out, but I am pretty happy I didn't.  I am going to leave them natural brass color.  This is the back side of the frame, as the drawing is still attached to the front.  The color should pop a bit more as the pear wood darkens over time.
Link to comment
Adam,
This looks both interesting and very good. Guess I will be one of the first to pull up a chair, to watch this build.
Respectfully
Link to comment
hi adam
nice work so far!
just be careful with some of those drift bolts on the forward and aft frames......some of the frame drawings dont show any bolt locations.....if youre tempted to put them in you may find them getting a tad close to the frame edges when you come to fair the hull.......or it could just be my build!!!!!
shall be following avidly
cheers....mick
Link to comment
Forward and aft frames could be bolted safer by drilling shallow holes from each side independently, after initial pre-beveling. That is easier to do comparing with a full-depth single hole. Nobody wll find out that you have two short bolts instead of a single long one ;)
Did it on my model, worked like a charm, even on a really bevelled frames.
Edited by Mike Y
Link to comment
Great to see another Washington build.  Mike's idea of two blind holes after beveling is great.
Toni
Chairman Nautical Research Guild
Current Builds:
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Here I have finished shaping the hawse pieces using a combination of a drum sanding attachment in a Dremel tool and hand sanding.  There is some additional fairing to be done to the cant frame once it is attached to the keel with the other frames.  I didn't want to mess it up for now.
Edited by Pirate adam
Link to comment
Good progress and nice work Adam. I will following your log with great interest. I just received my Washington plans in the post today. They are wonderfully done. I haven't yet decided on a wood species, but I am leaning towards maple or basswood as I have both in my shop and also some walnut and other sorts that might be useful for trim here and there. I also have some small chunks of pear in case I can find some use for them. This will be my first ship model so I'm sure I will pick up a lot of helpful tips from your log. Now I just have to mill the wood (not a fun job) and then start building!
Mike,
an American living in Norway
Current build:  Galley Washington - 1:48 - Scratch POF - NRG plans
Link to comment
  • 1 year later...
  • 4 months later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
