Bending with steam easily
I was reading the topic 'bending with heat only' with great interest to learn some new methods
of bending planking. I will give it a try for sure.
I use steam now which is fairly fool proof and quite easy for a beginner like me.
I figured if it was good for the original boat builders it was worth a try.
I put together a vert simple steamer by buying an electric tea kettle I think for about $15.00
a few years ago. I just set it on the floor and slip a piece of scrap fiberglass tube over the spout
turn the pot on and drop a few pieces of wood down the tube. I usually stuff an old rag loosely in the
open end to hold the steam in the tube. After only a few minutes the wood is up to temp and ready to bend.
You just need to be careful in handling the tube because it gets very hot but the wood is workable by hand.
I never let the pot unattended because I will hold the power on so the pot does not shut off when it starts to boil.
JMS
Link to comment
Share on other sites
Hm, for me it works without any extra jigs - I bend pear even with 3-4mm thickness by simply:
1) Boil a full kettle of water
2) When it is done - open the lid and dip the piece into the boiling water while it is still boiling. Of course, it is super hot inside the kettle, so use tweezers to hold the wood piece
3) Wait 15-20 sec
4) Done! Take the piece out, bend and clamp to shape
5) Wash the kettle and pretend you never did it in a first place
Super simple and no problems. Of course, it will be hard to do with long pieces, but super long pieces are typically out of scale anyway, right? :)
I found that for best results it is important to dip when water is still boiling. Maybe it is all that air bubbles and vibration that helps to relax the wood fibers? Just a guess..
At least experimentally - it works better than just dipping in hot water when bubbles are gone, and much faster then using steam.
Edited by Mike Y
Link to comment
Johnnymike: It looks like your jig is intended to steam the whole plank. Most of the time only a small fraction of the plank needs to be bent, I use a tea kettler with excellent results. Just dip the wood through the spout.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Link to comment
I use an old pan which the nob was removed, very effective and good results... I do not use too much water and I put a little olive oil.
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Link to comment
I just did this last night in using a long shallow cooking tray to bend some extra long pear - I'll keep your secret if you keep mine  :rolleyes:
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thanks for your comments guys. I think we found that steam or boiling water work well for bending and is quite convenient.
We use the same method with different equipment because it is what we have to work with.
I don't have a accessible place to boil water so I had to find a compact design.
JMS
Link to comment
For some woods, and depending on the size you need to bend, it doesn't seem like you need boiling water.  Most of the time I just run hot water from the tap.  Usually, by the time I get the piece situated, the water is room temperature.  I boiled water for my first build's planks, but haven't noticed a difference just going with warm water on my current builds.  If you were bending tricky woods like ebony, you probably do need heat.
One thing to remember is that the wood may expand a little when soaked.  So, if you glue it right away when wet, by the time it dries, it might shrink leading to gaps.  I've been a little more conservative these days in soaking, pinning and letting the piece dry overnight before gluing just to be on the safe side.
Edited by Landlubber Mike
Mike
Link to comment
I prefer dry bending by far, but sometimes soaking is a better way to go.  If that is the case, for me, steam and hot water is way too much work and too much wasted electricity. It provides no advantage over using cold water.  I use various lengths of  PVC pipe with one end capped.    I put in a few shaped pieces of wood n the tube and fill with distilled water.  I don't trust the chemicals in the tap water.  Tap water may not eat the lining of my stomach, but may have an adverse effect on the wood color or some such. I do have my priorities!
Depending on the wood and thickness, it takes from a few minutes (holly) to an hour or so (pear and castello).  I usually put in a few pieces at the end of the day and they are ready by morning regardless of the type of wood.   I notice that most bob up as they float in the water in the pipe, so I will put an end cap on to hold them down.  When they are ready, they don't pop back up once the end cap is removed (and they often sink to the bottom.)  Once the pieces are all out and used, the water goes back in the jug for the next round.
Allan
Link to comment
Agree.  I've build a lot of ships and bent a lot of planks.  Water in a glass works just fine for me.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
I use a wine bottle to soak the wood (empty it first, the white is ok but the red stains the wood) there is always one around and they are long enough to do long pieces. Then heat with a plank bender, the kind that in on the end of a soldering iron. Depending on the wood as little as ten minutes soaking does the job.
Current build               Dom Fernando II E Gloria  crossection
Finished boats               Portuguese Caravel     Artenaval
                                  Yacht Mary                 Mamoli
                                  Mayflower                  M.S.
                                  H.M.S. Unicorn           Corel
                                  Whaleboat                 Marine Model Co.
                                  Swift                         A.L.
                                  America (solid hull)      Marine Model Co.
                                  Albatros                     Mantua
                                  U.S.S. Constitution      Revell
                                  Spanish Galleon           Revell
Link to comment
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
Link to comment
  • 4 months later...
I started this topic a while ago but as I wanted to find the best way of bending wood, for me. I could see that there are many different methods and although steam worked best for me at that time I am always interested in searching for a better way to do things.
So for the last few months I purchased a few different heating irons, tried soaking only, used crimping tools and tried heat guns.
For me steam is by far the quickest, easiest method and allows the best complex bends. I am working on the Batavia by Kolderstok and I need to bend 1mm x 6mm walnut planking around the bow to the stern. This is a fairly tight bend with a cross grain twist that leads into a longitudinal sweep up with a slight twist. I tried everything and went back to steam with excellent results. After only 5 minutes in full temperature steam I could take a straight piece of walnut and bend it by hand to the final shape on the hull gluing it into place completely at one time easily. I did not have to fight with the wood at all.
As they say, your results may vary but for me steam is by far the best way to bend wood.
JMS
Link to comment
John
You almost have me convinced to give it a try.  :)     Does the steam expand the wood?  Gluing it in place "wet" is problematic as it leaves gaps when it dries, so I was wondering if the steaming softens the wood without expanding it at all.     Also, 1 mm is the equivalent of only 2" thickness at 1:48 . Have you had success using steam for thicker pieces of walnut or other hard woods, say 3 or 4  mm?
Allan
Link to comment
allanyed
I would recommend trying steam based on what I have experienced. For me nothing else is even close.  And I started bending wood when everyone was recommending using ammonia and water. But be cautious because steam is really hot, obviously, and it also makes the steam chamber and the part you are heating get pretty hot also. I would never use a sealed container either because of the pressure. Steam is great but you have to respect it.
Some expansion must occur in the wood but I have used it on four builds now and have never found it to be an issue. I have only used it for walnut and it does not soften the wood enough to be detrimental in any way.
For my hull work I use a PVA glue and like to leave it set out for a short time to get a little heavy and never had an issue.
I am now bending 1.5 mm x 6 mm walnut which is the heaviest I have bent but I would not hesitate to try it on heavier cross sectional area wood.
JMS
Link to comment
There's a reason every large-scale wood bending operation since the beginning of time has involved steam. The Egyptians were steaming the wood required to make their highly sophisticated and engineered chariots 4000 years ago, for example. It really is the best way to do it. However, it's not always the most convenient way to do it and dry bending at our scales generally works fine. So the recommendation should be to use steam if you can, if that's hard to do for some reason, use Chuck's dry bending with a hair dryer method, it should get the job done also.
Link to comment
vossiewulf
I guess different things work for different people.
I tried a hair dryer and even a heat gun. It was much slower and more cumbersome than steam.
And most importantly it did not impart nearly the flexibility into the wood.
Just my observation.
JMS
Link to comment
You can't do dry heat the same way you do steam, if you do you'd reach the conclusion that it doesn't work. First it's not a good idea for severe bends, if you have a severe bend to do and you don't use steam you need to soak the planks in water first, and then you'll use the heat mostly to set the bend. With no-water you heat and bend in steps, clamping as you go along, and you have to bend it past the final curve you want as it will spring back a bit. Chuck's planking videos show it in action pretty clearly.
Link to comment
I used to use steam
But since finding the hot air soldering tools I have been converted.
Here is a link with more details including my review
https://modelshipworld.com/index.php?/topic/14646-bending-with-heat-only/
This cheap little unit delivers a 300 degree C (or higher if you wish) air stream in a focused nozzle.
I find the advantages over steam are
No preparation needed, just jump straight into a bend.
Steam can only reach 100 C (in atmos), this thing can go a lot hotter, so time to bring a plank to a malleable state is seconds.
You can keep revisiting the bend - put in heat, bend a bit by hand - hold out of heat a few seconds and try - return to heat and repeat as many times as necessary.
It will edge bend and twist.
The timber does not swell with the water/steam.
It is quite safe even though it doesn't look it.
the hot spot is within a millimetre or so of the nozzle.
You can put a finger within a 1/4" of the side of the nozzle without discomfort.
Sounds like I'm selling them :)
But I would recommend taking a look, even just read a more detailed review.
Nick
Link to comment
I have a similar hot air unit.  I've used it on box and temperatures above 225 F tend to char the wood and I've never had the wood go malleable....maybe user error.  A combination of wet and dry bending is still where I am.
Maury
Link to comment
Hey howya goin all, I found this at Rockler <--- Click Here. Good for doing multiple steaming at a time, they even tell you how to make a steamimg box.  :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
Link to comment
The Dutch shipbuilders in the 17th century knew very well how to bend wood.
You need in fact three things:  water to  soften the cell membranes (which in fact is cellulose which dissolves in the water) - then heat to make these cell membranes flexible - and then some force to bend and twist the wood.
Steam has both the water and the heat - whereas a heat gun only has heat and uses the existing water still in the wood. For both methods you need force to bend it.
In Holland wood was often still quite wet - because it was transported via rivers and canals to the sawing mills, and also stored in water.
When a plank was ready in shape to be bend it was stuck into a special construction at one end - then with reed a fire was made under the plank, and with weight (stones) and forcing clamps the plank was bend into the right form.
I have a special device to bend planks. It works with a soldering iron and a curved head. You need to make the small strips of wood wet (and it does not have to be soaking wet - for basswood and walnut 30 minutes in water are more than enough) - put it onto the head of the hot plank bender and force it slowly into its needed shape.
Everyone has his (or her) own method, but this one works very good for me.
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
Link to comment
I think water can only reach 100 C in its liquid state, then it turns to steam which is its gas state and can reach much higher temperatures.
Another trick is to wrap your strips in a wet towel and put it in the microwave!
Link to comment
Maurys, I hear you. I have tried it all and although many like dry heat it just doesn't come close to the ease of steam for me. A $20 electric steam kettle and a 1"x 2"x 3' long piece of fiberglass tube for the chamber. Add water wait 10 minutes and I can bend in another 10 minutes. If things are going good I load 6 to 10 pieces at a time and mount one after the other.
I thought I might be doing things wrong with dry heat too but I just went back to what works for me.
Thanks Eddie. I like the looks of this.
Steam is 100C at 1 atmosphere but that is plenty hot enough for me. If you heat it under pressure you can super-heat it to much higher temperatures.
JMS
Link to comment
  • 3 years later...
The mini travel iron idea is a good one that Chuck Passaro demonstrates in detail in his tutorial.   For very small pieces I now use a flat blade on a soldering iron.  Care needs to be taken not to burn the wood so I turn it on with the trigger for a few seconds, then turn it off while "ironing" for a few seconds, then turn it back on for a few seconds, and so forth. Works really well once I got the hang of the timing so as to not burn the wood.  The first photo shows a pieces that has been soaked in water and the beginning of the ironing. In the second photo you can see the lighter color of the same piece after heating and the water is evaporated.   The wood in this case is castello box, so hard woods can be done with this method.   Softer woods may not need to be soaked first, but this wood did split if bending when dry before the heat procedure. For larger pieces I do prefer an small steam iron.
Link to comment
I have been looking for this bender but can not find it anywhere. Where did you get it???
Edited by Ulises Victoria
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
