Biloxi lugger Captain Roy 1948 by russ - 1/48 scale - POB - Finished
Carl:
That is very kind of you to say. I hope to be able to live up to that one day. :)
More progress photos to come soon.
Russ
Link to comment
Share on other sites
Link to comment
Link to comment
Russ,
I'm joining the audience a little late!  You've got an attractive and unique topic here, and you've got a very well planned and executed build under way.  The hull (bulkhead) framing looked true and aligned; the stanchions (both plan and execution) look smart, and the hull planking is coming along very well. I'll be sure to keep up.
Elia
PS I'm also glad to see your injury has apparently passed and you're back in the model shop!
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
Link to comment
Elia:
Thanks for dropping in. I appreciate your kind words very much. As always, I am learning new things each time I build. Several lessons picked up so far on this build will be forwarded to the next build.
The thumb injury has healed and the thumb is functional. There will always be some pain I reckon, but it seems to be less as time goes along.
Russ
Link to comment
That hull planking looks good Russ, she will be 'dressed' before you know it :)
cheers
Pat
Link to comment
Pat:
Thanks. I am starting to like how the lines are working out.
Russ
Link to comment
look'in real nice Russ :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Link to comment
This is tonight's work. I began the lower belt on the starboard side. The garboard strake is complete and I have worked in the forward planks of the next strakes above. There is a good deal of twist in these forward planks in the lower belt. Like the rest of the planking, they are spiled and tapered and then soaked in hot water. I clamp them in place wet and when they dry, I can glue them in place with very little clamping needed.
Russ
Link to comment
John:
Thanks. The spiling and tapering is working like a charm. :)
Russ
Link to comment
Lawrence:
Thanks for looking in. I appreciate the kind words.
Russ
Link to comment
Some more progress on the lower belt, especially near the bow. This is where you can see the appearance of the planking begin to develop.
Russ
Link to comment
Link to comment
Chuck:
Thanks for looking in. I appreciate the kind words. :)
Russ
Link to comment
John:
Thanks. I appreciate it. I am hoping to get near your expertise one day. :)
Russ
Link to comment
Kenneth:
You are too kind. Thanks. :)
With the rain coming, I should have an opportunity to make some progress on the planking.
Russ
Link to comment
A rainy day and some progress. The lower belt is complete on both sides. No sanding yet on the port side. This is still a little rough looking, but you can see how the planking lines look.
Russ
Link to comment
Planking looks amazingly good, Russ. As far as I can see you have two equal parts on either side of the "lead line" ... considering your present planking state: Ready in a jiffy it seems to me
Carl
Link to comment
Link to comment
progressing really good Russ.........very nice work! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
