Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
I agree Bob, that deck looks awesome, great detailing
Link to comment
Share on other sites
Looking really good Bob. Great craftsmanship.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Bob,
Extremely neat and clean build one to be proud of.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Link to comment
Bob, you continue to be an inspiration. My Halifax kit is supposed to ship late this week or early next. He said it was delayed because the laser cutter guy had to upgrade his machine or something and his thickness sander was down. I'm going to have to go through your posts word for word before I start it.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Link to comment
Hi Bob,  what a lovely job you are doing, I love the detail and workmanship,  the color of your upper planking is very nice almost like a pale cream - light yellow ocre color.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Nice work on the windlass Bob, those octagons can be tricky. Looking forward to the masting.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
Link to comment
Thanks so much OC, Joe and the "likes".
OC, the planking is castello boxwood and that is the natural color (after a finish of Wipe-on Poly).
Joe, as might be expected, the windlass required more than one try, and it's still not a perfect octagon. "Tricky" is a charitable description.
Bob
Link to comment
First work on the masting has now been done with the making and mounting of the bowsprit and jibboom. Both the bowsprit and jibboom were made from dowels, shaped appropriately,  stained golden oak, and then painted black where called for. The cap was cut from boxwood sheet, beveled, holes drilled and filed, and painted black. Various boxwood cleats were added for the gammoning, rigging collars and a jibboom stop.
After assembling the bowsprit, jibboom and cap, I added the lashing for the jibboom and then the collars for the bobstay, shrouds and forestay. A jackstaff was made and mounted to the cap. I then mounted the assembled unit and added the gammoning.
The Hahn drawing provides limited detail as to the masting and rigging, so I am using Lees to provide information on sizing of masting and rigging components.
Bob
Link to comment
Excellent work Bob, how did you attach the jackstaff to the cap?
Link to comment
Thanks so much Don and the "likes".
Don, I sanded the lower portion of the jackstaff flat and glued it to the cap. I then drilled holes on either side and glued in a tiny U-shaped piece of wire as a bracket. The wire didn't show up on the previous photos, so I'm attaching a photo that shows it.
Bob
Link to comment
really a super job Bob.........look'in very  good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Bob.  I love your work. You really inspire me to try and plan each step. Your build is absolutely beautiful so far. 👍🏼👍🏼👍🏼
“Work like a Captain....Play like a Pirate!” — Every Ship Modeler...everywhere.
Link to comment
Link to comment
Thanks so much Denis, Rich, Patrick, Zappto, Thomas and Dave for the very generous comments. Thanks also to the "likes".
Dave, the deadeyes are 3/16" and the heart is 5/16". The shroud deadeyes are probably a little too large, but I was in between sizes and opted to go for a little larger, rather than too small.
Bob
Link to comment
Thanks Bob!
If you email Daniel Dusek (who owns the rights to Mamoli's plans) He'll send you a copy of the very detailed Mamoli rigging plans for Halifax.  He sent me a copy but asks that I not forward it to anyone, but rather request it directly from him.  It is in Italian (of course) but is very detailed.  contact@dusekshipkits.com
Link to comment
Thanks Dave. I actually have the Mamoli plans. I built the Mamoli Halifax many, many years ago (the model was donated to a charity auction almost 20 years ago and I have no photos). There are some discrepancies from the Hahn plan and also from practices as set out in Lees, but I do intend to use them as another possible source of information.
Bob
Link to comment
Thanks Bob, that is a real innovative way of mounting the jackstaff
Link to comment
Continuing with mast construction. I've made and mounted the two lower masts. Each began with dowel, cut and sanded to a square shape for the head and a flat area for the cheeks. The cheeks were cut from boxwood sheet. The trestletrees and crosstrees were made from boxwood strip, with notches filed in to fit them together. The boom step on the mainmast was cut from boxwood sheet with boxwood strip supports. The cleats were made from boxwood strip, sanded to shape and pinned and glued in place. I had Syren laser cut cleats and they are nice, but it was more trouble removing the laser char, than just making them from scratch.The caps and mast coats were cut from boxwood sheet, after the holes were drilled and filed. The unpainted portions were finished with golden oak stain and Wipe-on Poly . The doublings, caps and mastcoats were painted black. Lastly, eyebolts were added for attachment of various blocks.
The masts were mounted in the holes previously drilled in the keelson, with the mastcoats in place. The caps will not be mounted until later.
Bob
Link to comment
Again excellent work Bob, are you carving and shaping all these intricate pieces by hand or do you have power tools such as a mill? Either way it looks real good I especially like the cleats and boom step. A fine example of doing things "the right way" ;)
Edited by donrobinson
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
