Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
Thanks so much John, Ken, Russ , Grant and Michael for the great compliments. Thanks also to the "likes".  All are appreciated.
Ken, I'm afraid that you will have to wait about a week for the answer. :)
Bob
Link to comment
Share on other sites
Superb work  those ropes just look so fine and detailed.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Link to comment
Hi Bob -- If "bad" language helps, then it's not bad in my opinion.  And if your hands aren't as steady as they used to be, well, you're still getting things done at an impressive skill level.
Fabulous to see!
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
rigging looks awesome Bob........very cleanly done!  you nailed it with the braces.......no deflection on the shrouds  ;)   you've really done a superb job on this vessel ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks so much Martin, Denis and the "likes".
Martin, I appreciate the vote of confidence, but I don't feel that way when I have to tie off a line with two tweezers in a tangle of other lines. :(
Bob
Link to comment
Done! Halifax is now completed. The last work was the swivel guns and the anchors.
The swivel guns were done using the barrel castings supplied by the Lumberyard, to which I added a handle made from wire with a small bead at the end. The mounting brackets were made from some brass backing links that I had on hand, which were bent to shape, a hole drilled, and a mounting pin inserted. The whole assemblies were painted black and glued in place.
The anchors were entirely made from boxwood strip. The "metal" portion of the anchors were painted black and the stocks were left natural. Simulated bolts were added to the stocks, as well as black painted paper bands. The rings are wire with puddening done by wrapping tan line around the wire. The anchors were then rigged and mounted.
I will post photos of the completed model in the next day or two, as well as starting a new log for my next project, Prince de Neufchatel, starting with the Model Shipways kit.
Bob
Link to comment
beautiful fitting out Bob !,
anchors, swivels and mounting supports look great...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
congratz Bob on a fine looking vessel!  the swivel guns.....especially the anchors,  are the crowning touch ;)    definitely museum quality  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Nicely done, Bob! Looking forward to your next build, as always.
Mike
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
Excellent build Bob. Your workmanship is first rate and its always a pleasure to follow along.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks so much Rusty, Lawrence and the "likes".
Lawrence, I chose this kit because it had laser cut framing. I have no power tools and don't wish to cut frames by hand. With the exception of the framing, I basically scratch built almost everything. I also substituted wood from Wood Project Source for that supplied in the kit. All of that is a long way of saying that the kit suited my needs because of the framing, but if that isn't a consideration, I would go for the timbering set only. In answer to your last question, the kit contained no materials for masting and rigging, and the blocks and rigging line were all from Syren.
Bob
Link to comment
Congratulations Bob - another fine model for the collection. I look forward to following your next project.
Link to comment
Congratulations, Bob! This is another wonderful model added to your fleet. Outstanding craftsmanship and detail!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Link to comment
What a Superb job you have done bob,  not just your beautiful workmanship but also your step by step guides, I know not only myself but others will have found your build so enjoyable.
Thank you.
OC.
Current builds
Completed works.
Link to comment
Since no log can be deemed complete without some overall photos of the finished model, mine are attached here.
I'd like to take this opportunity to thank all of you who have followed this build, who have hit the "like" button, and, particularly, those who have provided their support and encouragement through their generous thoughts and comments. It is gratifying to have such an appreciative response from such a talented and accomplished group of modelers. Thanks again.
I hope to see you all on my new log for Prince de Neufchatel, which will be opened a little later today.
Bob
Link to comment
What a wonderful model. I dream to arrive one day to build a model like this one.
I will follow your next log with great interest.
Thanks to share your work.
Jean-Paul
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
Congratulations Bob to that beautiful built "Halifax" schooner....
Did you already mention which your next project will be ?
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
You always do some awsome work.  Always a joy to follow along with your builds.  Looking forward to whats coming next....
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
