Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
Link to comment
Share on other sites
I believe he's a member here. He is definitely  a sponsor.  Just check for Dusek ship kits. He should have a thread in the buy and sell forum
Carl
Completed builds: AL Bluenose II 1:75  Gallery
                              Amati Hannah SIB 1:300  Gallery
Current Build: Bluenose II - SIB - unknown scale
Link to comment
Dave, I almost forgot that I built and rigged a Halifax from the Lauck St kit years ago. I don't have the model and my memory is that I rigged it from the Hahn plan and just figured out the belaying.
Bob
Link to comment
Home again and back to work, so time for an update. I've made up and mounted the three square half frames at the stern. Same procedures as for the full frames. I also did some fairing while waiting for glue to dry. This was primarily in the midship area and consisted of using various sticks and blocks with 60, 100 and 120 grit sandpaper. Final fairing will be done when the frames are complete.
I'm now working on the stern cant frames.
Bob
Link to comment
I just heard back from Daniel Dusek.  He's acquired the rights to Mamoli properties (not Constructo), and the rigging and belaying plans are from the Mamoli model.  He was gracious enough to send me a .pdf copy for free, as long as it's for my personal, non-commercial use.  The plans are TINY, but you can enlarge them in a .pdf reader or have  enlarged hard copies made at FedEx.  There are 6 sheets of plans in total, and the cost to enlarge all six of them on 17" X 24" paper was $14.19, tax included!
Bob: Daniel asks that I not distribute the file directly, but that you email him personally to request a copy if you'd like one.  His email is the same as his website's:  contact@dusekshipkits.com
Link to comment
The framing is looking great, Bob! It doesn't even show signs of being laser cut!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Link to comment
Hi Bob,
It’s looking real good and brings back fond memories of the FA and Halifax!
I think that by the time you finish fairing them up all signs of the laser char will be gone.
Very nice.
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
I've now completed the stern cant frames. These presented two problems. The first was the expected difficulty of cutting and sanding the required angles to get a proper fit. That went reasonably well. The second, however, was more troublesome. The aft most frame did not match the plan and had to be tweaked to get it to fit. it remains to be seen after final fairing and assembly of the stern framing  whether this will turn out correctly, or whether I will need to remove it and make a new pair of frames. As I have been doing, I did some rough fairing to get a feel for the fit of the frames.
I'm now working on the bow cant frames.
Bob
Link to comment
I've now completed making and mounting the bow cant frames and hawse timbers. As at the stern, some discrepancies between the parts, jig and drawings required some tweaks and adjustments to be made. As with the previous work on the framing, I've done the rough fairing of the outside of the hull. For the most part, it seems to fair up well. The exception is at the upper portion of the frames ( at the bottom of the photos because of the upside down construction), where it seems that a few of the notches in the jig are misaligned, causing some low areas. This will be corrected by adding boxwood strip to the outside of the affected frames and then sanding them fair. There should be no visible evidence of this because those areas are to be planked over anyway.
Next up is the framing of the stern, starting with the transoms and stern timbers.
Bob
Link to comment
Beautiful!  I really like the way your cant frames and hawse timbers came out.  I remember those where somewhat of a pain for me to smooth out.
Link to comment
Thanks so much Sjors ,Michael, Steve and the "likes".
Michael, "somewhat of a pain" is somewhat of an understatement. :)
Steve, everything is easy -- once it's finished. ^_^
Bob
Link to comment
the frame looks great Bob.   the curve looks like it carried over from the sides........shimming it will take care of it.   you'll fix that ...no sweat! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
super looking framing work Bob,
here it shows how essential that jig plate is for placing /holding the frames to distance....;)
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Great looking model Bob.  The usual well crafted and clean workmanship.
Cheers
Ken
Washington 1776 Galley
Pilot Boat Mary of Norfolk
Completed Builds:
Link to comment
Thanks so much Nils, Ken and the "likes".
You're so right Nils about the jig. Even very small discrepancies in the jig can cause a lot of trouble, as I'm now starting to see. Hopefully they are all correctable.
Bob
Link to comment
That looks really good, Bob! How is the quality of this framing kit . . . is everything fitting well or do you have to correct a lot?
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Link to comment
Thanks so much  Thomas. Your question is a little difficult to answer. In general, the laser cutting is good, although there have been a few burn spots. The major issues have been that the drawings and the parts don't all match up and that some of the jig slots were misaligned. I've had to make adjustments to overcome these problems and in some cases to scratch build replacements for some laser cut parts. Having said that, it' s been fun so far.
Bob
Link to comment
Great work, as always, Bob.  This is also intriguing to watch as someone who wants somehow to learn more of the skills of scratch-building, and POF modelling.  There's always plenty to discover about these beautiful ships, and your work demonstrates that little fact.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
