Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
Thanks so much Michael, Denis, Grant and the "likes".
Grant, all I can say is that it works better than any other method I've tried -- and I'm getting too old to learn anything new.:)
Bob
Link to comment
Share on other sites
I have now completed the upper hull planking. Before beginning, I had to cut away three of the frames to allow for the small gunport openings. As with the previous belt, this was done with boxwood strips without taper, first edge bent and then bent again horizontally to fit the severe bow curve. This planking was done with a combination of 1/16" x5/32 ", 1/16" x 3/16" and 1/16" x 1/8" strips to fit the dimensions shown on the drawings. BTW, the Lumberyard provided pear strips to do this planking, but I didn't like the material supplied and chose to use boxwood that I had on hand. The treenailing was done as before. After treenailing, the area was final sanded and finished with a coat of Wipe-on Poly. No further work will be done on the outer hull at this point
The next task is to cut the hull away from the jig.
Bob
Link to comment
the different wood color banding is nice...adds a decorative flare to the planking :)  looks nice Bob!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Link to comment
Bob,
    You paint the molding before you glue it into place, correct?  That provides for a real sharp paint job without 'overspray' onto the planks above and below.  Looking good!!
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, John Smith Shallop
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch 1/4 scale-Model Shipways plans)
Link to comment
2 hours ago, rafine said:
I think it will look even better when I ultimately put on the black moldings.
Bob
 I really like the contrast between the black and the lighter colored woods.
Link to comment
Link to comment
Rain, rain, and then more rain. That was the weather in sunny Florida for a week. Bad for golf, but good for modeling.
With all that indoor time, I was able to get by a couple of tedious tasks. First, was cutting the hull loose from the framing jig. This proved more time consuming and difficult than I had imagined it would be. I first tried to do it with keyhole saw blades in an X-acto handle, but this seemed like it would be an endless job, and I have no patience for those. I rummaged through my tool box and found a Stanley handle with a hacksaw like blade and this ended up doing the trick, although still slowly and carefully. It is pictured below.
After freeing the hull, I then turned to the task of fairing the interior. This turned out to be quite a chore, because the frames needed to be thinned considerably to reach their proper final proportions. Beginning with a Dremel with a sanding drum, and then using various grades of sandpaper with different sticks and blocks, and some freehand sanding as well, I worked my way through it. This took me days of tedious work. It's likely that I may still need some more work at the bow and stern as I proceed with interior work.
My next job was to add the keelson. Although this is a laser cut part , it still required considerable fiddling and adjustment to get it to fit tightly and properly. Lastly, I added the first strakes of interior planking along the keelson in the hold area, just to get a feel for that process. I'm now deciding just what interior work to do and how to go about it. I would like to show as much of it as I can, but we'll have to see how that works out.
Bob
Link to comment
Tedious it may be, Bob, but well worth the effort! Looking very nice indeed.
Link to comment
Great progress Bob,
she`s  looking fantastic in this phase....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thanks so much Dirk, Grant, Nils, Dave and Michael for the nice comments and thanks also to the "likes".
Getting her out of the jig was a big deal for me, since I like to work with the model in my lap and it's a lot easier right side up without the jig.
Bob
Link to comment
i love u're model ,he 's on my list
very clean work
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Link to comment
Great Job !!!
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
La Jacinthe French Schooner
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Bisquine La Granvillaise
Fishing-boat
English pinnace
18th Century Longboat
Link to comment
look'in good Bob.........nice to see her free ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks so much Denis. I was enjoying having her "free" until I did something really stupid. :(:angry:  With the ship in my lap, I reached for something and the next thing I knew, the model was bouncing off the stone floor, destroying part of the stern framing and some some hull planking along the starboard side toward the stern. All forward progress has now stopped until I can redo the damaged areas.
Bob
Link to comment
Hi Bob,
I`m sure with your skill and confidence in pushing away that "dark damage cloud" you will overcome  that accident and already be well on the way of mending the broken concerned parts,
a super model out of your yard, as usual....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
