Shaunzy
US Brig Syren by Shaunzy - Model Shipways - 1:64 Scale
I'm just starting the Model Shipways brig Syren.  I spent 3 weeks reading thru the Chuck Passaro practicum and feel ready to go.  I pre-fitted bulkheads onto the former and immediately spotted a problem.
When I line up the laser guidelines on the BF with those on the bulkheads, the "tee" intersection for the deck is not always on point. Sometimes, the bulkhead is higher, lower or dead-even with the deck line on the bulkhead former. So ... what is the proper way to compensate for these "misalignments"? Any advice would be appreciated.
Share this post
Link to post
Share on other sites
Hi Shaunzy,
I don't have a good answer for you but at least something to check on:
 I have (for historical reasons) 2 bulkhead formers and 2 sets of bulkheads.  In both cases I find the scribe lines are right on - no adjustments required.  The only way I can get a discrepancy is by putting a bulkhead in the incorrect slot.  Perhaps if you include a couple of pictures showing the problem we can figure out a fix.
Share this post
Link to post
I think I would go with getting the deck lines flush.That will get a smooth deck. However why don't you put the decks flush and use a batten to check the fairness of lines on the hull.
Share this post
Link to post
Like Heronguy says, check to make sure your bulkheads are in the right slot. My laser marks were spot on. Also don't forget to harden the station part of the bulkhead with CA as the laser marks are cut way too deep,making them very fragile.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
