Bismarck by Semorebutts - FINISHED - Trumpeter - 1/200 scale - with MK1 detail set
All the best to you farther  worrying times  hope all turns out ok.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Share on other sites
On 12/3/2017 at 4:54 PM, semorebutts said:
So i have to start thinking about the acrylic case. Does anybody have any experience working with acrylic. I dont know if Its somthing I can do or if I should have it custom made.
I have to make somthing like this acually almost exactly like this.
I have done two types of acrylic cases. One was all acrylic and I butt-joined the edges and used the recommended solvent cement. I was living in an apartment at the time and had minimal tools. It worked quite well but it was on the small side.  For my Essex I built a wooden framework and used the acrylic as one would use glass--fitting onto slots. There is a photo of my case somewhere on this site.  I think if you have a table saw and reasonable woodworking skills you should be able to make a case.
Link to comment
whoa thank you Ragove. yes i have a table saw. I think I am going to do it myself. There is a custom acrylic shop near me but it is expensive. I just dont know if I can get away with 1/8" acrylic over a 53" length or if I would have to use 1/4". If I use wooden framework 1/8" would be ok. also 1/4" slots would be to big.  those plans are awesome thank you. It clears it up for me.
Link to comment
I ordered my acrylic on-line for a reasonable price. There are a number of vendors who will cut and ship custom sizes.  I think i used 1/8th inch.
Ron
Link to comment
awesome job!   funnel starting to take shape  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
You can split the difference and get 3/16" acrylic.  I used 1/8" for my Badger case and though the longest dimension is only 30" or I can definitely see a slight bowing in it.  I tried purposely to get reflections in the glass on the picture so you can see the difference.  IMG_20171207_185151.thumb.jpg.1f8d61b2d701e4ea46034711a40ac7da.jpg
The acrylic on the Tiger model is about 28"  or so long and is 3/16".  No bowing and very rigid.
Edited by shane762
Link to comment
2 hours ago, semorebutts said:
Those 7 pipes took 2 hours. So all 47 should take like 8 hours
When I have small PE to fit I use a drop of PVA to tack down the part first, then go over all of them with CA glue. This way you can manoeuvre the part into position more easily. I've had no problems with either glue not sticking.
:cheers:  Danny
Cheers, Danny
Link to comment
Those 7 pipes took 2 hours. So all 47 should take like 8 hours...
Well then, you are way quicker than me. Last week I did 1.5 tripple AA guns in 2.5 hours ... I have 27 in total ... about a week and a half work I'd say. Just couldn't finish the job then as I got meself a nasty flu, sneezing and coughing doesn't seem to help much with those parts. So don't sweat it. You just get to spend a wee bit more time on your model!!
Carl
Link to comment
sweet!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi everyone. The funnel went from enjoyable to a nightmare fast.  Suddenly every piece i try to add does not fit right and has to be modified.
If you look at the right winch You will see I had to file a whole side flat so the crane will fit into the hole next to it
you will see the railing had to be cut short so the canopy could be offset to the platform so brass deck in the first photo would fit
a notches cut out and joyces under this deck cut just to fit in place
so all i got done was gluing this hatch door
this railing
these two hatches
IMG_1272.thumb.JPG.5e0ffbab2105747e49e7cbd9ba357809.JPGIMG_1273.thumb.JPG.8f201ed43c6a406a9b9f54ed016c13b7.JPG
And the two cranes
Link to comment
I think you glued the winches on too close to the crane. The inside of the winch should probably be closer to the funnel, according to my 3D Bismarck book. There's quite a bit of space to move it without hitting anything else, though it's most likely too late now :( :
:cheers:  Danny
Cheers, Danny
Link to comment
Sometimes dry fitting helps :o:huh: I know it's a wee bit late, but try it. It helped me with some tricky bits on Musashi. Especially superstructures are a blast ...
It's strange, though, that the other one doesn't need any correction ...
Carl
Link to comment
It is strange Cog. I realized nothing fit right on the dry fits. I guess ill just move on but that was so frustrating. I just hope theres no more of that  I think that was the first time with fit issues on this ship.
Moving on to somthing I hated in the beginning but actually love to do now, bending railings!
Link to comment
the funnel is coming along nicely,  in spite of the issue ;)    looks really good.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
