semorebutts
Bismarck by Semorebutts - Trumpeter - 1/200 scale - with MK1 detail set -FINISHED
Depends on the tickness of the brass. For strong joins: silver solder (wire or paste, paste is easier sometimes), else solder iron with solder. I can solder wih a torch upto (or is it down to) 0.2mm brass wire with silver solder paste. Most will use the solder iron as it is very easy to burn the brass away ... You'll have to try and find out what works for you.
Share this post
Link to post
Share on other sites
Like Carl says, I'd use a hot iron with a sharp point, unless you have a very small torch. I've only done electrical soldering, so favor rosin core solder. It needs some cleanup. There also acid flux, which requires better cleanups. A big torch might melt away the fine brass PE.
I'm sure a lot of guys will fill you in on soldering technique. This is how I'd do it.
Tin your soldering iron after cleaning the tip. Put a bit of solder on the tip to tin it. Nice shiny tip means good heat transfer. Clean and flux your joint. Shiny brass, then apply your flux. Apply the heat to the joint, then touch the solder to the joint. Try not to apply the solder to your iron tip. Heat on one side, solder on the other. Move the solder away and check that you get a shiny looking solder joint. If it's not, you made a cold solder joint, which is weak. Reapply heat and have your solder handy. Make sure you get a shiny joint. Clean up the joint; I might dip it in vinegar to remove the rosin and brush clean any excess solder.
You may want to practice on some frets before launching into the FuMo 25, 26 and 27. ;)
Edited by Canute
Adding verbiage
Share this post
Link to post
I searched in google for : "kriegsmarine rettungsfloß farbe"
And found this :  http://www.forum-marinearchiv.de/smf/index.php?topic=5660.0
They speak about 2 colors
Start WW2  : auf einigen Farbfotos zu erkennen, ein fahles Gelb  fahles gelb =  dirty yellow
 In 1941 : Schlauchboote waren Taubengrau   Taubengrau = pigeon gray
Hopefully, this will answer your question
Share this post
Link to post
Trumpeter kit $250
mk1 PE $200
pontos PE $160
VM gun kits $72 and everything else I had to buy. Compressor, airbrush, all paint and glues, PE tools, tweezer set.... litterally everything. Add it all up its close to $1300!  Not to mention the custom acrylic case and display table and lighting. I bet this will hit $2000. But I LOVE every minute of it!
Share this post
Link to post
6 hours ago, RGL said:
You can never, NEVER, have enough aftermarket
He's right Scott. For my Musashi I've got the Pontos, and the Flyt Hawk detail up sets, besides that I've got a few sets of railing stanchions (7 brass and metal colour), perforated gussets & support beams, water tight doors, epoxy anchors for IJN ships ... I hope to use them on other ships aswell ... that's for my first plastic /PE build. Currently distracted by a dutch sub, and I used some of the stanchions for it. Besides the PE, the tools, the paint (airbrushes/compressor/cleaning utensils/etc), I've got brass rods, sheet, and styrene rods e.a.
Let me put it this way: It is not for the faint hearted. However, it is fun and the support and motivation is awesome
Share this post
Link to post
Thank guys, very well said Cog! I do plan on the Missouri, Hornet and hood after the bismark if I have the stamina.  So it wont go to waste.
The Pontos PE will arrive Monday but I think I can safley airbrush some parts and not have to go backwards later.
I found this cart in the dumpster at work. Spray painted it black(during work hours of course) and made it my new paint station.
IMG_0840.thumb.JPG.f0617574bc2660de1c29313c7b26ce03.JPGIMG_0843.thumb.JPG.b021ec35a24cdd82edba1dbf643c7f4b.JPGIMG_0832.thumb.JPG.0d4f94aa5e0c3d180c25417a0286b26a.JPGIMG_0833.thumb.JPG.e9520abd1f79c5429de520004b3e3a0f.JPG
Trying some shading, I dont know what I'm doing but I will learn.IMG_0842.thumb.JPG.59652b8a8c18f97db09dd72e9552bf0e.JPGIMG_0841.thumb.JPG.1baa30851688e03fbd768121a2303198.JPG
Share this post
Link to post
Nice spray station Scott. You've got quite a steady hand with the brush! I like the fantasy lathe ... old motor as far as I can see, not made any more nowadays
Share this post
Link to post
What you can do after filling the gap with the missing bit...or scrap sheet.... You can use a small lick of acrylic paint to fill a remaining gap.
sand smooth with 1000 or 1200 grit sandpaper...repeat this a few times when needed.
You can fix this! :)
Share this post
Link to post
Some putty might come in handy ... or the nearest equivalent in epoxy filler ... You will need it with plastic kits anyway ... good reason to buy it if you d not have it ... I love it when I need new materials ot tools ...
Edited by cog
Share this post
Link to post
So i got the Pontos advanced add on set. Opened the box only to discover more than half of what should be in there is missing! There is only PE sheets. No resin parts no brass props no pipes, or rod stock at all.  But the good news is i called freetimehobbies.com and he's going to send out everything thats not PE sheets. It's not there fault. So what happens?  Freetimehobbies just gets screwed for the cost of one set? Thats not right.
IMG_0858.thumb.JPG.94f87a8390ddb617da94b9f4cae5185f.JPGIMG_0859.thumb.JPG.a5ee39f3ac21eafc0b2ee296ab6ceab5.JPG
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
