Bismarck by Semorebutts - FINISHED - Trumpeter - 1/200 scale - PLASTIC - with MK1 detail set
They should have checked what they sent off to you. That would have avoided your problem, the set might have been partly taken by a shop visitor ... not very kind, but shoplifting still happens, untill nothing can be obtained but for through the internet
Carl
Link to comment
Share on other sites
1 hour ago, semorebutts said:
 Now that i think bout it, it was not sealed.
Theres so much more pontos than mk1 with more detail, but There has to be an easier way of doing this!
Sand it off using a sanding stick thats been smoothed a bit to loose a bit of its grit, thats what I do.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
looking good semore.....good you were able to remedy the bumps along the way  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Scott, I use a hand chissel, a small straight one like this:
It gives me far more control than an exacto like knife, and doesn't flex
Edited by cog
Carl
Link to comment
That's a great idea. hopefully they sell small chisels :D
Hobby lobby has a set of 4 or 5 small hand chisels run about 16 to 18 dollars perfect for what your doing price is right.
Takes a little longer to hone the edge after all its not a 75 dollar chisel it resembles what Carl posted:D
Edited by John Allen
correction
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Link to comment
Perfect John thanks! I will order that later.
I must say I like Pontos better than MK1 PE.  The PE itself has much more detail. I think the instructions are also better.
IMG_0865.thumb.JPG.675f9d0e1cf41f20a5523c6510588d86.JPGIMG_0867.thumb.JPG.d037d0ac3b963009fe0caea9d90fa3df.JPG
this is how much more Pontos offers over MK1.  And thats just for that piece. And theres still alot i wont use like the louvers. Don't get me wrong MK1 makes a great upgrade set, but on my next model I would have to go with Pontos... actually why not both again
Link to comment
49 minutes ago, semorebutts said:
What a mess!
What a great idea tackling section by section including painting, its easier that way to get a quality job in a controled area at a time.
OC.
Current builds
Completed works.
Link to comment
I take the "section by section" approach to my models as well. As Yves said it makes keeping track of all the parts a lot easier.
One thing I'd do though - I'd leave painting each section until they are ALL done in case there is an "overlap" with some parts, and also in case there is any filling needed between sections. You'd also get a more even colour overall.
:cheers:  Danny
Cheers, Danny
Link to comment
I have the next 11 days off so im going to try to get alot done in that time. I haven't painted yet because I want to try tamiyas liquid surface primer. I dont knowwhy im going to prime as i dont think it needs it, but ill give it a shot.
Electrical conduate, catapult catwalks, phone booths and signal light guard rails cut out ready to bend or apply.
Link to comment
really nice!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
That's why most use silver solder and a mini torch, Scott. It heats quicker, but is hotter, and it flows nice in between the parts. However, PE will easily burn in front of your eyes, literally, so usually CA thin or thick (even gel form) is used in stead of soldering.
You are a brave man to solder, not one of the faint of hearts.
Edited by cog
Carl
Link to comment
I only bought the soldering iron for the masts. When the model is done the only thing that i want soldered are the masts. I just couldn't resist I had to try on a spare PE part. I have always wanted to scratch build something use just brass stock so maybe this will get more use than just a mast.;) I think I still may buy a torch and silver solder.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
