Bismarck by Semorebutts - FINISHED - Trumpeter - 1/200 scale - PLASTIC - with MK1 detail set
2 hours ... not bad. How do you apply your CA? I use a small piece of bass rod (0.5mm thick), the CA on a piece of plastic  (everything seems to be packed in plastic so that's the obvious choice) and dip the rod in the CA and apply it to the parts.
Carl
Link to comment
Share on other sites
I love this CA applicator...
flex-i-file-ff5555-ca-glue-applicator-set-handle.thumb.jpg.47b8339537fc54eaeb84231f80283ffb.jpg
you can pin point tiny drops with it. Clean with a lighter and fine sandpaper...will last.
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
Link to comment
when I buy the Testor's glue in the tubes,  I buy the pack that has the nozzles in it.   I have a bunch of them,  but what I use them for the most though,  is wood filler.  I cut the neck so I can fit a nozzle in the hole,  and I can extrude a fine line of filler wherever I need it.  I hardly use them for glue because they always tend to clog up.
your doing a great job so far.......definitely wouldn't class you as stupid ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
"Took way longer than I thought to paint this." That's what they all say...
You have a very nice finish on those items, and I have to say your railings look very sharp!! The mast doesn't look bad at all, that is to say the rungs stand out quite well
Carl
Link to comment
THANK YOU!  The top 4 rungs look solid. where it looks like the top of the ladder ends there's another 4 hidden rungs lol. but all in all I'm happy, it was waaaay worst before. Painting always takes long for me. after looking at what I had to paint I said to myself 15 drops of thinner and 30 drops of paint should do it. I ended up doing that 3 more times! I was way off!
also I don't know if I should bother shading any of these pieces. maybe just the ladder on the mast?
Edited by semorebutts
Link to comment
Hi,
You have a beautiful build here.
I use a simple home made tool for precisely placing tiny drops of CA.  You take a needle and snip off about 1/2 the eye leaving you with a small “V” shaped end. Stick the pointy end into a dowel for a handle.  I then place a drop of CA onto a piece of foil and dip the tool into the drop.  The “V” will pick up some glue and when you place it where you want the glue to go, capillary action draws it from the needle.  When the end gets clogged with glue, take a lighter to it and it burns right off.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
For Tamiya I use 1:1 paint:thinner
On Vallejo Air I use it straight from the flask, the others 2:1 1:1 paint:thinner ratio, it depends how it works out I have used 1:2 ratio for it's primer. It just depends on the weather/humidity temp, etc. It isn't an exact science you might say. I had to store my airbrush and paints, as night frosts are cooling the attic, and spraying gets rather difficult whit frozen paint ;)
Carl
Link to comment
Put your paint pots in some warm water before loading your brush. And don't let the paint freeze. Shouldn't have much of a odor issue with the acrylics, so store then in your work-space.
Ken
Started: MS Bounty Longboat,
Link to comment
Cog I have only ever done 2:1 ratio and only ever used tamiya. Seems to be working out ok so far. I had a horrible experience with lifecolor paints. Its to bad they have an entire kreigsmarine set with excellent colors.  I have the set but its awful to Airbrush.  I wonder which paint company has colors for the missouri? I dont think tamiya does but I'm scared to use anything else after the disaster with life color.
Canute, warm water, thats a good idea! thanks for the tip.
Link to comment
I know you can't, but when you know the colour code from lifeColor, you can get the corresponding colour from the chart. I've got a another chart somewhere which gives the mixtures for certain colours, but haven't found it yet
Carl
Link to comment
Perhaps THIS LINK to Kriegsmarine colours may be of use to you. If you click on the "Return to Paint Chips" button it also has the US Navy colours and others.
:cheers:  Danny
Cheers, Danny
Link to comment
That just looks fantastic. Weathered enough to look realistic but not overdone, and lovely detail. This has been really fun to follow.
Link to comment
Thank you Eric. It's been my pleasure as the advice I get here is great and plentyfull.  Im just relieved people actually watch my build.
I was starting to install the catspult catwalks and paravane booms. Just as I was getting started I got an emergency call into work, but before I left I got one catwalk on. Sorry it's not much progress.
Link to comment
Does anyone know if I can buy a photo etch set of these 20 mm flak guns anywhere. Even if its part of a bigger set. I know theres eduad, white ensign, ka, pontos. One of them must have a smaller set which has these guns. Or even a set with just guns. I broke the trumpeter guns and dont know what to do. IMG_1093.thumb.PNG.26d30dd86213778e25b2a72e61c9e540.PNG
Link to comment
I use lifecolor  and had no problems  but also hand paint never spray,    at 1/350 scale the sub assemblies are small enouth to be painted by hand,   what I did/do find usefull is to keep the pots stired whils't working with them also to keep the tops of the pots/jars real clean from dried paint residue.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Scott, you'd better start lookin' on ebay like: 20mm flak PE 1/200 or bismarck 2mm flak PE 1/200, etc, etc
e.g. this one unfortunately 1/48 but you'll get my drift
Carl
Link to comment
THESE are the ones I got for my Bismarck. They would be the exact guns you're looking for :).
:cheers:  Danny
Cheers, Danny
Link to comment
tuning in from my work week Scott....you've made some really nice progress!   the super structure looks really nice with the railings.....very good paint work as well.
    I've got three of the life color sets......haven't tried to use them yet.  I use enamels for all of my models,  although I have a few acrylic colors kick'in around.  the Testor thinner that I use comes with a secondary cap....a sort of plug to prevent leakage.   I use it though to measure out the amount of thinner to prep the paint.  since the EZ airbrush I use,  uses the 1/4 oz bottles as the siphon pot,  I just mix up the whole bottle......I get empty bottles by buying the 1/4 oz thinners.   I use Model Master as well,  for the flats,  but they come in 1/2 oz bottles,  so it's good to have the extra bottles.   look online for conversion charts.....they can also give reference to the difference brands and what to use.  for the particular model though.....I guess you'd have to see if anyone published that information.   it is out there though........your doing a really nice job!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
