xodar461
Revenge 1577 by xodar461 - Amati - Scale 1:64
time for a new update.   after the planking below the wale was completed, the waterline was drawn and then painted.  this is also the time to construct and hang the rudder.  The tiller arm (orange arrow, second pic) is also connected to the whipstaff assemble at this time.  The quality of the rudder hinges is quite good.DSC_0001.thumb.JPG.d6218d422d3ece67ff9d6248edb70620.JPGDSC_0059.thumb.JPG.fc9447ac0916aef43970ae88a956b57c.JPG
The gunports have also been framed.  Next are a few views of the waterline...
DSC_0060.thumb.JPG.59131649a4338c3d3460e155c8246f5a.JPGDSC_0062.thumb.JPG.2abea1d2c10581f89cbcf8662eb3559b.JPG
Below, the hull sitting in my waterline template...
DSC_0065.thumb.JPG.d8d05d7a6e454ef83b446c24065796fd.JPGDSC_0066.thumb.JPG.4cfef709ca7f2b0937dc6fda2f3338f8.JPG
planking between the wales is next.  while waiting for some additional swiss pear, work was started on the forward 2 bulkheads.
Share this post
Link to post
Share on other sites
Planking between the wales now complete (glad to be done with all the complex curves at the bow!).  Instructions call for completion of the remaining decks before placing the fore and aft side patterns.  This would require placing the lower deck gun carriages without the guns.  As I want to rig these guns with at least the breech tackle, some changes in the order of construction will needed.  First, I decided to plank the spaces between the gunports so these areas could be sanded and finished prior to gun placement.  This would require the wale that runs above the gunports to be laid down first.  As this wale runs the length of the ship, the part of the wale that would be fixed to the side patterns was left unglued  (second pic, arrow).  Also, the instructions call for the wales (lower 2 are 1x5 and the upper one is 1x4)to be glued onto the second layer of planking.  I felt that doing it this way this would make it difficult to exactly match the run of the planks already placed.  Thus, two 1 mm planks were glued together to form the wale and this was then  placed onto the model with spacers to maintain the correct distance from between the wales (first pic, arrow).  the lower wales were made in the same way.
After the planks were place between the ports, the port lids would have to be redone as those supplied with the kit were dibetou wood and this looked quite wrong against the swiss pear.  As the photo below shows, the new port lid was made from 3 planks of swiss pear made to follow the run of the hull planks.
As the supplied port lids were all cut to match their respective ports, rather than waste them, they were trimmed  a bit and used to make the inner layer of the port lid (illustrated in to photo below.
The hinges will be added at a later time.  Next step will be to place the lower deck guns with the breeching tackle then construct the deck above.
jeff
Share this post
Link to post
On 11/12/2017 at 9:10 AM, xodar461 said:
After the frames have been attached, the first deck to place is the orlop.  Although the manual shows this as 1 piece, the kit splits the deck down the middle for 2 pieces - much easier to fit this way.  The deck is planked off the model and then glued onto the frames.  The hatch coamings and gratings are then fitted.  As others have pointed out, the gratings are photo-etched brass and not wood.  One problem with replacing them with wood is that the grating openings may not be to scale - often they are too big.  As this deck is deep within the ship, it won't be too visible anyway so I'll decide later if I want to change out to wood for the upper decks.  here are pics of the deck pre and post application of satin poly.  I think the gratings are acceptable.
5a0774b7480b0_021(Large).thumb.JPG.dfe059a0207adafbe55903b6b1c18841.JPG5a0774c331d7a_023(Large).thumb.JPG.fec55d6a266375c4d302fdf4879a24e5.JPG
Also note that I have decided to not use treenails to the deck.  At this scale they would be barely visible anyway.
Hi Jeff,
my name is Paolo first of all thank you for this blog, your model looks very good. i just start mine and it is my first model at this difficult level. hopping for the best. i will definitely use your building log as guide if you dont mind.
can i ask you if you have a specific rule on how long you cut the planks for the deck?
thank you and again compliment
Share this post
Link to post
Hi Paolo
Thanks for following my log.  I am not a very speedy builder as you can see from where I am in this build.  Re: the deck plank lengths, I started with  a full sized length of 24 FT which is ~ 4.5 inches at a scale of 1:64.  I think I decided on 4 inch planks for the model.  To make it easy, I would recommend a plank length of 10 cm.  This would also make it easy to shift the planks 2.5 cm with each successive plank so joints on the same "beam" would be separated by 3 planks.  Feel free to ask any questions along the way.
hope this helps
Jeff
Share this post
Link to post
Gunports are now complete except for the application of stain and hardware.  DSC_0001.thumb.JPG.4222765c1f80bcb37742df5bb7d45476.JPGDSC_0004.thumb.JPG.5e0af6b8c84754f8988793e75f280c18.JPG
The lower deck gun are now in place with the breeching tackle.  In order to get a secure bond, some spare wood was glued to the bottom of each carriage so as to create a larger surface area than just the 4 wheels for the glue.  Kit instructions call for just the carriage to be placed with the guns going on later.  With the guns in place now, I don't want to accidently dislodge them.  They are all pretty solidly in place.
DSC_0005.thumb.JPG.e1144c6528de8e6a5077a3f0fa690839.JPGDSC_0007.thumb.JPG.090ebd9181809aac4e22ee3b6b920a36.JPGDSC_0006.thumb.JPG.62b21065fde7347e697821aad07adcbf.JPG
I decided to leave the cannons as supplied (bronze) rather than paint them black.  Cannons of this age were made of bronze or iron.  Also, they are getting a little patina as can be seen below.  Makes things a bit more interesting I think.
Last item to add to the lower deck are the gratings.  In doing some preliminary work with placement of the upper deck, I found that the cannons seemed to be a bit low, even when accounting for the deck planking.  this can be seen with some of the pictures of the model on the box.  some spare wood 1 x 4 mm was added to the top of the beams and problem solved,  However, I also encountered this with the forward side pattern.
once again another port slightly off.  This gun also sits quite low on the box top photos.  I plan to cut out the penciled area and fill in the same amount at the top.  This will not have any overall effect on this part of the hull.  For now, next up is lower deck gratings and upper deck placement and planking
Jeff
Share this post
Link to post
15 hours ago, xodar461 said:
Hi Paolo
hope this helps
Jeff
it help a lot Jeff thank you so much. i will start the planking to night  australia time.
Share this post
Link to post
Just noticed your log, hope you don't mind if I pull up a chair and follow, i'll sit quietly at the back.
Share this post
Link to post
Greetings
Upper deck work in progress. First pic shows some 1x4 mm wood added to each  beam to raise up the cannons relative to the lower edge of the gunports (pic 2).  The main deck gratings have also been placed with epoxy rather than CA - lots left to do with this model and I don't want them to get dislodged - thus completing the work on the main deck.  When performing these modifications it is important to check that it causes no change to anything else further down the line.  for instance two bulkheads sit on this deck and they must align with the top edge of the forward and aft side patterns (which they still do).
DSC_0001.thumb.JPG.2d2a70c355fbd56f9b768e64c099b091.JPGDSC_0001a.thumb.JPG.515ae7e053ce23d40c1be2fd9edb3ef8.JPG
The instructions call for planking the upper deck almost in full then installing it.  Problem here is that there has to be some bending to get the deck in place.  This would be difficult fully planked.  So a few planks were placed off the ship to get thing started - the aft plank that runs across the deck ship (large black arrow) and the planks that run centrally up to the openings for the bits (small arrows).  it is much easier to sand these openings and those for the masts while still off the ship.  Once on, the deck is planked almost to the bulkhead frames (which eventually will be removed).
Also seen on this deck is the hatch combing which had to remade as the kit's combing was pretty much destroyed when I tried to sand it.  This part is made of a wood called dibetou.  I am not a fan of this wood as it is VERY brittle along its grain.  even cutting out pieces from the pallet may cause the part to split along the grain.  Here's a pick of the original part (upper) and the beginnings of the new one.  I have a feeling I will be making more scratch parts along the way!  The red arrow shows the tiny tab that hold the part to the pallet.  grain runs the same way as the arrow is pointing.
Below pic shows the final hatch combing
Again I digressed a bit from the plans which call for planking the deck and gluing  the combing onto the planking.  In reality the combing would sit on the beams and planks placed around the combing.  This gives a better look I think as well as being more accurate
Share this post
Link to post
Time for a new update:
The 2 raised upper decks have been planked and installed.  This was all pretty straightforward (green stars).  I decided to plank the inner bulwark on this deck as I did with the main deck.  To support the planks I used MDF from the same pallet as the gunport frames to keep the depth the same green arrows).  The planks are 5mm. The cannons will be glued to the deck and rigged with the breeching tackle prior to the installing the quarterdeck.  Another modification was to divide the quaterdeck into 2 sections at frame 12 (the one just forward of the whipstaff assembly (red arrow). The work aft of this frame is complete allowing this part of the quarterdeck to be installed at this time.
Before placing the cannons, the side patterns will need to be installed so the external planking can be completed.  Next photo shows the starboard aft pattern in place.  I have also completed the placement aft of the upper wale, leaving a space for the balcony door frame (red arrow).
The stern window bulkhead and stern windows are installed before the side patterns.
The poop deck side patterns must also placed at this time (blue star).  I also had to glue the top the frame 14 (blue arrow) back in place as both sides snapped off during the hull planking.  That happened to several frames at the forward deck too.
below is work on the aft section of the quarterdeck.  this will be eventually covered by the poop deck with a bulkhead at the forward end of the poop side pattern.
Both side patterns now in place.  I have also placed one 2x1 walnut strip across the upper part of the pattern  this acted as a guide to help finalize the position of the black wale below so that there will be the correct amount of space for the colored patterns that will be added later.
While doing some rough fitting of the poop deck, I decided to discard beam 14B which goes where the red arrow is on the photo below.  This beam has a slight camber and for some reason, the poop deck is twice as thick as the other decks making it fairly difficult to bend in this way.  Also, there is part 20A which is not listed in the manual but goes across the forward part of the side panel (blue arrow shoes the notch for this beam).  Photos from the instruction manual do not show a notch here.  This small camber is not really noticeable so I just replaced the kit beams with 2 from some spare wood (4x5mm).
DSC_0009.thumb.jpg.181c920390180ada18d5092b4534d06d.jpgDSC_0008.thumb.JPG.2889d87c672fafe58cae4ea1c7d45c92.JPG
Forward side panels will be installed next
Jeff
Share this post
Link to post
Salut!
The forward side patterns are now on and I am working on finishing the planking between the wales.  Both forward bulkheads had to be finished and placed on the model before the side patterns as they would have been difficult to fit after given the curves of this area (pics 2,3).  Note that the aft 2 bulkheads have not been placed.  test fitting showed that there will be no problem to fit them after the aft pattern has been placed.  My goal is to have the exterior planking done so I can fit the last 3 guns with tackle that are below deck (pic 1, blue arrows).
DSC_0004.thumb.JPG.242a4de1bde38ac65007f0505a404eaf.JPGDSC_0003.thumb.JPG.6aefd72e527bb779047e0072a0c4f896.JPG
Below, finishing the aft planking between the wales (orange arrow).  The door frame (not seen in this photo) was used to allow the proper placement of the planks.  Another way to do it would have been to plank up to the opening and glue the frame to the planks.
When laying the plank around the bow, I found that there was not a smooth transition from the forward deck planks to the hull plank.  The arrow shows that the lower forward pattern edge is visible - not a good look IMO.  So I decided to place a strip of swiss pear 1x2 mm around the curve of the bow for a cleaner look.  This required some sanding of the finish from the deck which account for the "unfinished" appearance.  A final photo of the area will soon follow.
Jeff
Share this post
Link to post
it's look awesome Jeff, so many advices. i use more your Blog than amati manual. im very glad i met you here.
Share this post
Link to post
1 hour ago, Oliver24 said:
I will join also, it seems a beautiful ship.
it is Oliver24 so far a good and relaxing journey
Share this post
Link to post
Great work.
With all builds of the Revenge, the triangles and stripes on the hull are always beautifully painted. But I have never seen how this is done.
How do you do this?
With my Golden Hind, I had to cut masking tape for hours before I could start painting :(
Share this post
Link to post
Your Revenge is coming along nicely.
I like the way you are problem solving along the way. Isn't it a satisfying feeling to know you have found solutions that improve the kit, but also make it unique!
I like the lighting too, I think it gives an extra interest.
Share this post
Link to post
Thanks for the great comments.  Re:  the "painted" areas, these are actually printed on paper and are simply cut out and glued to the correct area.  Only one copy given so no going back once they are glued - get it right the first time.  Attempting to paint these areas would be very tedious and I am not sure the result be be as good for most people.  To Vulcanbomber, i agree it is satisfying to figure out ways to fix / improve the kit.  Some parts of the construction are more like a puzzle that have to be solved before moving onto the next stage.  I am always looking ahead in the construction manual to see if I can find a better way to build the ship.  The manual is more like a general guideline in building the model for me.  BTW i love your cross stich project.  very unique
Jeff
Share this post
Link to post
Hi.  new progress report.  Below is a photo of the bow deck, now completed with the addition of the pear strip and a 1x1 mm boxwood strip.
With the 2 upper side patterns now in place, it is time to plank them.  I decided to use full length strips of the wood supplied with the kit (1x5 tanganyca)as a time saving technique as any butt joints will be covered by the colored paper patterns.   Not very impressed with this wood but this area will all be covered so no need to use something more expensive.
DSC_0001.thumb.JPG.015b64d031cf95ba8d0a01640e38ed91.JPGDSC_0004.thumb.JPG.a97645b8cd3937979d929f918151d24a.JPG
The side gallery door frame was temporarily placed to help guide the run of the planks.
Planking at the bow is complete.  Some wood filler added to fill some minor gaps.
Stern is almost complete.  Instructions call for the planking to stop at the red line on the pic below..
However there are several wood strips 1x2 mm that are placed to separate the printed decorations.  If the planking stopped at the red line then the 1x2 strip that goes here would be flush with the 1 mm planking that stops here. Photos in the manual show that this strip is not flush, I decide to continue the planking up to the 1x2 strip already planked aft
Starboard side complete.  After some sanding, side patterns will be ready to go on.  Or I may complete the deck work and 3 cannons that are still to go below deck.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
