HMS Winchelsea 1764 by Stuntflyer (Mike) - FINISHED - 1/4" scale
The planks that go around the mast partners and coamings are difficult to make and took some careful planning. In a failed attempt, I tried to make all the cutouts at one time. Rather than waste more wood, I decided to make card stock templates that closely matched the area being worked on. The plan was to work one tab at a time. Once a tab was completed, I would then move onto the next tab.
This template was tricky because it required spanning two tabs in order to establish the proper shape. Notice how the tab tapers in width.
When it came time to glue, I adhered a short section of the plank to the false deck. This would make it easier to finish up the remaining unglued areas afterwards. Softer wood strips were used as clamps against the margin plank.
Once the glue was set, I moved onto gluing the remaining areas of the plank.
Pillar files and a sanding stick were used to shape the parts. Sticky back sandpaper was adhered to the stick and sanded flush with its edge.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
Share on other sites
Mike, I have a question for you.  Where did you get the external profile and body plan I saw on page 1 of your log?  Is it an enlarged copy of a plan in a  book/manuscript or is it a plan you sent away for.  If you did send away for it,  where is it from, and how much did you pay for it?  It doesn't look like it's from the NMM.  I would really like to get a copy myself.  Thank you.
Tom
Link to comment
Here it is:
http://ao.sa.dk/ao/data.ashx?bid=31918117
It's a real peach, ain't it?
STAY SAFE
current builds:
Link to comment
Hey Mike:  You're really doing a great job.  I just have a question:
For the "The planks that go around the mast partners and coamings",  is the angle 45 degrees?
Thanks.
Ken
Washington 1776 Galley
Pilot Boat Mary of Norfolk
Completed Builds:
Link to comment
Thanks Mike.  Your model really looks great!
Ken
Completed Builds:
Link to comment
The deck planking and waterway are finished along with a coat of W-O-P.
Winchelsea_9882.thumb.jpg.150575efae7025f29a31ad56ba1e99f0.jpgWinchelsea_9881.thumb.jpg.8d6b0a96a542793601eda3f092e40bc2.jpg
I found a height discrepancy, so I added a paper or card stock shim to compensate. The idea was to avoid having to sand the parquet floor in order to even things out.
Mike
Link to comment
Mike,
Thanks for showing to us your build... it's just pure ship modeling porn 😂
I love this super clean build.
Really impressive.
Two questions... if I may... 😉
What are you using to imitate hull and deck caulking? Graphite... pencil?
Friezes are printed on regular paper?
They look so good.
Some time ago I was doing some tests with decals (like from plastic model kits)
With some setting and softening solutions they lay very so well on prepared wood giving some nice texture from planking.
Cheers,
Matt
Edited by mati
Link to comment
Thank you all for the comments and "Likes".
Matt>I've been using a #2b pencil on one of the two plank edges being joined in order to simulate hull and deck caulking. If I wanted a darker simulation I would pencil both plank edges.
Chuck provides a color pdf of the friezes that can be printed on regular paper stock.
Mike
Link to comment
I've been working on a number of things such as the gun port lids, gun carriages, ladders and rudder. Today I finished the two ladders that go below the gun deck. The initial assembly was all about getting things square and locked up, using the two sides and top and bottom steps. Once done, I inserted the remaining steps. Each step needed to be beveled slightly on the bottom in order to fit into the side grooves. To keep things neat, I glued the steps to the sides from underneath the ladder with a tiny drop of slow drying 3 hour epoxy. The epoxy will eventually wick into the joint and not be seen when the ladder is installed. Once dry, I rounded off the top forward edge of each step and sanded the step overhangs flush with the sides of the ladder. After a coat of W-O-P the ladders were ready to install.
The ladders position was established in such a way that the back and bottom of the sides are sitting flush to the coaming and deck below, respectively. Four layers of the green tape was used to mark the position of the ladders top. The blue tape makes it easy to hold onto the ladder while inserting it. When installing, center the top of the ladder within the coaming and up against the bottom of the green tape. Then lower the bottom of the ladder onto the deck below. Notice where I marked the position of the ladder on the green tape.
Mike
Link to comment
That looks really good Mike! thanks for the tape tip, I will definitely be using that.
JJ
Current Builds: HMS Winchelsea 1764 1:48 - 5th rate 32 gun frigate (on hold for now)
Link to comment
What a great example of perfection! This is absolutely top notch work.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • Santa Maria boat - Korabel (Ukraine) - 1:24
Link to comment
Very very nice workmanship Mike. You're an inspiration to us all!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks so much guys for the nice compliments! I wish I could move along a bit faster but, I often find that the hurrier I go, the behinder I get. I guess I'll leave that for the experts.
Mike
Link to comment
Much to my surprise, Chuck was able to laser cut the rudder from 1/4" boxwood. From what I understand it took some experimentation with the settings in order to achieve a good result. I think that you will agree that he did a great job.
Winchelsea_9906.thumb.jpg.2d27323ee6295b0aa085994844cbfa01.jpgWinchelsea_9907.thumb.jpg.4b55595c49224bc594687396e9e78a45.jpg
The black painted straps were first thinned down to 1/32” and then tapered aft down to 1/64”.
Winchelsea_9910.jpg.a104febf697295e1f05178d1d38e3b12.jpgWinchelsea_9911.jpg.69938cd02a8db6bd9e942c2e3ddf2343.jpg
The strap bolts were made from 20lb mono and are press fitted deep into the drilled holes, but not bottomed out. No gluing necessary. I added only two hoops at the top of the rudder. These were made from a thick, pliable cardboard type material that I found in a package for a mini miter box. They were wrapped around the rudder in one piece and the ends joined at the leading edge so as not to be seen. The uppermost hoop was omitted as it will be hidden by the rudder trunk.
I used a .010 brass strip to help in getting the bolts to stand proud consistently. I drilled an oversize hole in the strip. The hole was placed over the mono and then the mono was flush cut. Before removing the brass strip, I pushed down on the mono with a small dowel to make sure it was flush with the strip.
Mike
Link to comment
After adding the two ring bolts to the rudders spectacle plate, I moved onto the the gudgeons and straps. These were made in the same way as I did for the rudder.
The mill comes in handy for drilling the strap holes.
7 layers of masking tape give the right thickness to sand the gudgeon and strap down to 1/32" before tapering.
The only working hinges are at the top and bottom of the rudder. The other three are faked by gluing the pintles into the gudgeons.
Mike
Link to comment
