HMS Winchelsea 1764 by Stuntflyer (Mike) - FINISHED - 1/4" scale
She's looking really good. The pictures are nice but she looked  even better in person. Keep up the good work.
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
Share on other sites
Love those chisels!
Maury
Link to comment
Thank you all for the comments and "Likes"!
Here is a small update regarding the black strake installation and my somewhat lengthy method. I say that because I will do whatever I can to avoid having to paint the top edge of the strake where it overlaps the hull planking after it is glued down. Even if the area where masked off, I would question my ability to get a clean edge.
The hull has to be prepared for any glue seepage that might occur. To do that I taped off a small area below and above where the top edge of the black strake is located. I applied a coat of W-O-P between the taped edges. I used some old striping tape that I had lying around.
_DSC8982.jpg.a61c6b3e47fe92cae09c8df6bf45475c.jpg_DSC8983.jpg.9fbcb2c15dff93c3ff07f2e8943bf1f8.jpg
The top edge of the these planks are beveled and painted with Windsor and Newton "Mars Black" which has been thinned down considerably. Two coats is all that was needed. Once dry the remaining unpainted wood was masked off on both sides. A thin coat of Testors "Dullcote" was applied to the black paint which will protect the paint if glue seepage needs to be wiped off later.
With the prep work completed, the planks can be glued onto the hull. I used a 1/8" flat paint brush trimmed very short to place a small bead of glue down the middle of the underlying hull planking. To avoid creating a mess each plank was glued its entire length in one shot. The end result is a clean edge where the black strake overlaps the hull planking. So far, with one side completed, there has been no glue seepage at all.
There is no point in my painting the entire strake now since there are a number of steps that have to be completed before final painting.
1. Bevel the top edge of the wales
2. Install at least one strake below the wales which includes the drop plank.
3. Taper the wales towards its bottom edge for a pleasing transition into the strake below.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
  • 2 months later...
Its been a while, but before proceeding further I have decided to wait for Chuck to catch up to me. Design changes to the prototype build are inevitable and as much as I wanted to move ahead, I think it's best to wait.
Meanwhile, I bought some 5" x 15" boxwood sheets from Chuck's supply that I thought would be a good match for the planking above the wales. I ripped a strip off each side and applied a coat of W-O-P to each strip. As you can see, the color can vary quite a bit from one side to the other. The darker grain in the sheet on the left side is harder to see than the photo would suggest.
Here is the same sheet compared to the sheet I used for the upper hull planking which shows a good match on one side.Winchelsea_9040.thumb.jpg.f4a8a2b4f9149f33195663f8c782ac5a.jpg
The drop plank has to be made from 3/64" sheet due to its being so wide. Here again the W-O-P tells all. Using the outer area of the sheet should yield a reasonable match.
It's a shame to have to discard some of this rather expensive wood, but I want to keep things as uniform as possible.
Mike
Link to comment
Its all lovely wood actually....but as you mentioned, there will always be variables.   So after you rip your strips,  they should be sorted for color.  Those being darker for your tastes can be set aside for areas that you know will be painted.   For example, the inboard bulwarks.   Dont throw it away or discard it Mike....use it for the bulwarks.
Chuck
Link to comment
I forgot about that, Chuck. Thanks for the reminder.
Mike
Link to comment
After a lengthy discussion and given the choice to remain with a painted black strake or switch to a natural one, I decided to go with a natural one. I removed the black strakes shown in post #129. They popped off rather easily using a small chisel as a wedge.
The new black strakes will be added after the wales are painted. Something I didn't do the first time around was to make sure that the top edge of the wales were of even thickness throughout. To do this, I added nine layers of .005" striping tape to achieve the wale thickness of .045". I was not surprised to see that the thickness does vary a bit which I attribute to the gluing process and not to variation in wood thickness. The upper edge of the wales were sanded down close to the tape surface. Once completed the first three three layers of tape were removed. The remaining 1/32" thickness of tape is equal to the black strake thickness and the 1/64" exposed edge can now be tapered and softened. The photo below shows the before and after.
The drop plank was made from 3/64" boxwood sheet and installed before the last 2nd layer wale strake was added. The two rows of planks that follow the drop plank were also completed.
Winchelsea_9250.thumb.jpg.a29e7292ab6aca2376cee858b8198902.jpgWinchelsea_9251.thumb.jpg.8cd8e6e5d962b4f9486f457351d35030.jpg
Some creative clamping was used in order to hold things down
The last wale strake was painted black on one edge and glued into place. Once done, the striping tape used in the previous step was placed below it. The bottom edge of the wale is tapered down to approx 1/32". The photo below shows the before and after.
Now onto the other side before painting the wales.
Mike
Link to comment
Very nice work and explanation Mike!
Rusty
Link to comment
Mike, as I contemplate planking my Bellona, I came back to your site for inspiration--you have done a beautiful job so far.
I do have a couple of questions. How did you cut the ends of the planks so precisely at the ports, with an even reveal for the gunport stops? Did you draw the reveal on the frame, or use a temporary stop block in the port itself?
And how did you color the joints between the planks? I am not a fan of strongly contrasting joints, and I like the subtlety of yours. I have had some success with using dark titebond glue elsewhere in my build, but would be interested in how you are doing your's.
Link to comment
Mark,
I did not measure anything on the frames beforehand, though I did consider using a stop block. Since the gunports are not all the same shape, making a stop block for every port was more than I wanted to do. The reveals were all done by eye with the aid of the OptiVISOR. Also, I didn't sand the plank ends by hand. I used the disc sander either powered or by hand rotation depending on how much I needed to finesse the fit.
For the joints between the planks, I like to use a number 2b pencil on one plank edge only and not on both edges being joined.
Mike
Link to comment
I managed to complete a few things this week. . In preparation for spray painting the wales on the port side I added the section of anchor lining that will be painted black. It was tapered down to 1/64" at the bottom. The hull was then taped off along the wales.
Winchelsea_9262.thumb.jpg.a55fd334fbd0300313ee91e5cfea1f7d.jpgWinchelsea_9263.thumb.jpg.8fcd1af12cc3db48a41df997f5de0fee.jpg
After painting was completed, I added the black strake. This was done in four sections. I also added the 3/16" wide fairing caps over the top of the sheer. The ones over the hance pieces were laser cut and the 3/16" x 1/16" strips were cut on the table saw. From what I understand, the final shaping of the hance fairing caps will be done after the fancy molding and volutes are in place.
To finish off the anchor lining, I added the clear piece that sits above.
Mike
Link to comment
Mike its looking outstanding.  If you bring it by on the shop on the 17th we should take some pics of both models side by side.  It looks fantastic.
Do you have a coat of poly on the boxwood upper planking yet?
Link to comment
Thank you all for the nice comments and for all the "Likes".
Chuck, I will have the poly on the upper planking sometime this week. I've been putting it off for too long.
Mike
Link to comment
Mike, I signed up for a scratch build of Winnie and I was just wondering if you could outline how you made the gammoning knee and extension? I’m using pear so no laser kits for me, They look so small, scroll saw or mill and describe the fitting process? Looks like a pretty big hurdle.... you aced it btw.....
Link to comment
Thanks, Lou,
The knee sections are large enough to handle at this scale. Paper templates taken from the plan were glued to the wood parts with school glue. The scroll saw was used to cut the initial shapes by cutting close to the line. Drum sanding along with the disc sander and hand sanding was used to get the parts to the proper shape. Paper templates were then removed. Working on two adjoining parts at a time, the parts were checked for fit by holding them together against a glass window or light box. Light coming thru will show any gaps in the fit. I spent a lot of time finessing these parts for a near perfect fit. Once completed the two parts are glued together and the next part is made to fit to the completed assembly. The three sections along the stem were completed before adding them to the knee. The gammon slot was done on the mill.
Something I picked up from druxey describes how he uses various shaped sanding blocks, cut at a 90° angle to get the needed shape. In order to sand the whole edge, simply raise the part of the flat surface with scrap sheet of wood and then run the block over a flat surface and against the part.
I know it's a rather short explanation, but I'm hoping that it helps.
Mike
Link to comment
Thanks Mike, that’s perfectly clear now, what a great technique using various sanding shapes and raising the work to get the 90degree edge. I had heard of the light box but forgot about it☺️, just what I needed to overcome the confidence barrier.... This is what is great about MSW and this whole project, making the inconceivable possible!
Link to comment
I was driving home from Chuck's on Saturday when I noticed that sunlight coming through the car window exposed a few misses in my initial sanding of the upper planks. So, I was anxious to correct this asap. Once that was taken care of I added the forecastle fairing cap, port side. This was made from boxwood sheet as described in Chuck's Cheerful instructions. Also, I was able to check out Chuck's fancy molding and volutes over the weekend and they are really nice. Turns out that they will completely cover any gaps around the area of the hance fairing caps. Just one more thing I was worried about for nothing.;)
Mike
Link to comment
Last week I started the process of tick marking and lining off the hull. I used Chuck's templates which proved to be very helpful, though not perfect. My hull is not exactly the same as his, so after lining off the hull some adjustments were made before starting the planking of the first belt.
While adding the last plank of the third strake I noticed that there were still a few tick marks that were off a bit. For some peace of mind, I lined off that area of the hull again and adjusted the tick marks accordingly. Though not exactly a fun process, I can definitely see the benefit in lining off. Not doing it could lead to some regrets later on.
Mike
Link to comment
