HM Cutter Cheerful 1806 by Blue Ensign - FINISHED - Syren Ship Model Company - 1:48 scale
Nice work, BE, and good save on that gap.  Surely, if there is a warp, it won't be enough to lead to other problems. (?)
Looking over your tool setup again, I noticed you had a vacuum hose hooked up.  (And I've often wondered how you took care of the dust in a carpeted work room.)  Does that lead to a shop-vac, or do you have a fully-blown dust-collection system (one of the many, many upgrades I've been craving)?
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Share on other sites
Hi Martin,  I only usually bother with the vac if I'm making serious dust; all the Proxxon machines take my Henry vacuum cleaner connection, but I have been toying with the idea of getting the Proxxon version which comes on automatically with the machine.
Nor sure Mrs W of the Shires would appreciate industrial grade extraction equipment running around my office cum workshop. :rolleyes: although she likes the idea of the Proxxon cleaner, has visions of using it around the rest of the upper floor, when I'm out of the way I think.
B.E.
Link to comment
Happy new year to you BE!  I haven't been on much lately, but missed your Cheerful project.  Great start already, and even better, you have extra toys to play with :)  Hope you don't mind if I follow along, it's always a treat and a learning experience.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Hello BE, I too just happened to find your new build. Your logs are instructive and very entertaining. If you don’t mind, I will pull up a chair and follow your build. Have a wonderful new year.
Current build: HMS Pegasus, English Pinnace (on hold)
Completed build: MS BluenoseSkippercraft
Link to comment
Thanks Mike and Dave, and belated New year greetings to yourselves. :)
Post 6
That fairing business
Not done much work in the Shipyard since before Christmas, lacking some enthusiasm most probably because one of my least favourite aspects of a build is now required. Fairing seems to go on forever, and there is always the worry in the back of my mind that I may overdo it, and end up having to shim the bulkheads.
4024
One needs a good supply of sanding sticks for this task and I've added to my supply a curved stick made from a strip of Yellow pine left over from a much earlier scratch build of a twelve gun Brig, put into ordinary for many years and then abandoned due to terminal wood worm.
The wood comes off pretty easily during the bevelling operation, but the devil is as always in the detail of the process.
4469
I made a simple block jig to support the inverted hull whilst working.
4467
Once I reached the point where I felt there was a smoothish transition a walnut batten was pinned along the hull at gunport cill level.
4474
getting there I think, at least on the starboard side.
4470
4472
4462
4473
The fairing continues, a further batten strip will be added at Wale level, and a third lower down.
B.E.
Link to comment
Looks all neat and tidy B.E.
surely it will be a beautiful cutter....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Looking good. I am just a little bit ahead of you. The fairing itself isn’t too bad since the bulkheads are so close together. A suggestion if I may. If I were to do it over again, when It comes to installing the stern frames. Create some sort of jig so everything ends up where it is supposed to be in regards to alignment. I ended up ripping out the first set and replacing them. I still did it depending upon eyesight and a million measurements. I’m still fussing and tweaking things. I also placed sacrificial supports between the frames to be removed at a later point. This helps keeping things were they belong when fitting the gun ports. It also strengthens the area while fairing. Snapping one will break your heart. Been there. I actually discussed this with Chuck and he agrees. Hope this will lessen some anxiety when you reach that point.
Regards,
Kurt
Edited by Kurt Johnson
Link to comment
Snapping a bulkhead extension is no problem at all. Just mate it to a brace that bridges the extension and body of the bulkhead. Placed on the side away from the gun port. Everything will be pretty much removed prior to inboard planking. Have two on mine, quite proud of them really. The bulkheads and profiles set on the shelf for 1 1/2 years and the entire thing developed a twist at the bow and stern. Deviateing 1/16” to the right at the bow and to the left at the stern 1/16”. Took some work, but she’s pretty much dead straight again. Snapping a stern frame is different, they remain exposed and have quite a bit of leverage just begging and pleading to be snapped until planked. Mine laid in wait and pounced on my shirt sleeve, they’re very devious.
Enjoy,
Kurt
Link to comment
Ah shirt sleeves, the bane of ship modellers, especially when it comes to masting and rigging :rolleyes: I shall take great care Kurt when it comes to those stern frames, a little way off yet I think.
Post 7
Fairing, fairing, and more fairing.
Another day of sand and check, sand and check, and for a bit of light relief, check and sand.
4499
4491
4502
The test strips seem to be sitting fair across the bulkheads, only the central four bulkheads seem to require no adjustment although they will have the char taken off.
At this point I think I can fit the batten strip to mark the gun port sills.
4534
Seems to run with a fair curve, at least to my eye.
4540
4544
With the port sills marked, the next stage beckons.
B.E.
18/01/2018
Link to comment
Hi BE,
Your fairing looks spot on. Very nice.
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
Very nice start on 'Cheerful'.  I like your heat bending setup!
Cheers,
Jason
In the shipyard:
Link to comment
Cheers Guys,:)
Post 8
Port Sills
I cut some ¼" square strips from some old Boxwood stuff I had to form the sills. The Proxxon Band saw and Surface planer proved very useful for this job.
4620
More of the stuff was used for the uprights following as far as possible the plan thicknesses, but there were differences in practice.
My approach was to fit the thinner uprights on each port and then using a port width template establish the broader upright thickness.
When it came to the forward port cut outs I allowed extra width and depth to allow for a Boxwood lining.
DSC04623.thumb.JPG.f9181d8faaa11cad076b5a912f9881ad.JPG4623
I used temporary guide strips for the upright cuts.
4630
Once the bulk was removed, easily done with razor saw diagonal cuts, I cleaned the bottom with a scalpel blade.
4627
The port width template can be seen in this shot.
4641
The  linings were then glued into place.
4637
4638
4636
4644
The external port fairing now largely done, now need to consider the stern framing.
B.E.
24/01/2018
Link to comment
Very interesting, BE.  I wouldn't have thought the balsa filler blocks would extend above the ports.  Is this common in your experience?
Cheers,
Martin
Link to comment
Link to comment
Post 9
Thinking about stern frames
Before I started on the stern frames I added short bracing sections of Walnut square stuff between those bulkheads not braced by the Port sills.
4655
The hull is now very stable without any flex in the bulkheads.
4648
getting the levels right for the outer frames
4650
attaching the outer frame sections.
These frames are beautifully cut and fit together perfectly.
4654
Marking the approximate fairing line on the outer stern frames. This method of attaching a pencil stub to a wood strip I copied from Rustyj's Cheerful log, thanks Rusty, it worked a treat.
4657
More fairing of the outer frames still required, but at this point I added the four internal frames.
4668
I used a copy of the stern plan to check the set up, not exactly a perfect fit but it did align with frames 'Y' so I took those as the reference points to mark the height of the port frames.
4672
At this point I think I will fit the port sills and lintels which will add a little stability to the quite fine inner frames.
B.E.
28/01/2018
Link to comment
Hi B.E.
It looks like you've got the stern just right. Very nicely done!
Rusty
Link to comment
She`s well under way B.E.,
and all the sequences done to date are looking very good...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Steve, of course there is modelling life without Proxxon, just takes much longer by hand, but I would hate to give up my scroll saw in particular.
I do have the Crown wood set for Cheerful, but haven't used any as yet. I have a stock of old Boxwood that I've used thus far for the Port frames, and have some sheet stuff from :- http://www.originalmarquetry.co.uk/category_Saw_Cut_Veneers_3.htm
I planked both Pickle  and Pegasus using the Boxwood flat lines from the above company. Very useful 0.7mm thick strips in varying widths up to 10mm, and small square section stuff.
Cheers,
B.E.
Link to comment
Post 10
Stern ports
The prospect of doing these was quite daunting and I trawled all available logs for photo's and approaches before I started.
My approach was as follows.
I firstly cut the strips for the sills to fit snugly between the frames.
4676
Allowing for a small exterior over hang to take account of the transom curve, I marked the width taken from the plan, and cut it to size. I worked on the basis that the inner line was square to the frames and that the sill was level to the waterline.
I fitted one and checked it against the plan. With the pva semi set on the first sill I added the second sill, and matched it to the first again using the plan as a guide.
4677
Checking the level of the sills.
4680
A section of 'port' sized wood was formed to get the position for the Lintels. This was done once the sills had set.
The lintels were then cut to size and glued into place using the top of the port  'jig' as a guide.
4736
Both sills and lintels were then sanded to conform to the stern frames.
4820
The moment of truth, will the plan template fit.
Not really a shot in the dark, I used several copies of the template to check progress as work progressed.
4819
Seems to fit fairly well.
4825
4827
4828
4829
Moving onto the Square tuck piece next, then back to a little more fairing and fine sanding.
B.E.
31/01/2018
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
