Rustyj
Queen Anne Barge by Rustyj - Syren Ship Model - 1:24
Thank you OrLiN. Welcome aboard.
The inboard planking has been completed. Thankfully Chuck had the forethought to supply extra
planking pieces at the bow. It is a hefty bend and old hammer hands broke the first plank.
You can see the planking is not flush with the cap rail and forms a bit of a rabbet. You also can see pieces
added that do go all the way to the cap rail. These form a wider spot for the thole pins.
Well it's back to painting, painting, painting. :D
Edited by Rustyj
Share this post
Link to post
Share on other sites
Very nice....and yes that is the exact reason I added extras.  Same is true for the decorative panels.....you should be almost ready to add those too.  You are moving along relatively quickly which is good.   I see a Pegasus Cross Section Rusty beta test in the works for you!!!;)
Share this post
Link to post
That sounds great! I've had some time off so I was able to spend more time on the barge. Gotta go back to work tomorrow though. :default_wallbash:
Share this post
Link to post
I actually waited til I had the flag staff so I could make sure it was straight when gluing it in.  Thank goodness it takes a while for Titebond to cure which allows you to move the flag around while its in the step so you can get it straight.
Share this post
Link to post
Here are laser cut boxwood panels that need adding.
Again Chuck added extras because the are VERY DELICATE. Old hammer hands only broke
a couple but it was nice to know there were plenty of spares!
The inboard painting is done unless I make a boo boo. Next I'll be cutting out the printed friezes and inserting them in the panels.
Share this post
Link to post
The kit provides the various friezes all sized and ready to be inserted into the panels.
Chuck describes using a glue stick to adhere the friezes. As I didn't have a glue stick I
diluted some white glue, used a paint brush to apply it to the area inside the panels
and then gently press the frieze in place.
Next I will paint and install the bow flag support brace and the step.
Share this post
Link to post
Looks beautiful Rusty, those friezes really pop out against the inboard colour.
Incidentally my kit arrived today and altho’ I won’t start it until Cheerful is nearing completion, your log will provide me with a useful reference guide. :)
B.E.
Share this post
Link to post
Hi All,
I've been MIA for a bit. Vacation, family and good weather have kept me away from the workshop and MSW.
Well I've made it back to the shop for a bit of an update.
 The forward flag support bracket has been added as well as the step.
Here are the kit supplied laser wood carvings
and the kit supplied resin castings
and the optional resin castings
and the weathering powers to use on the resin castings.
Both the laser cut and resin pieces are great. I did get the additional resin casting just in case I either mess up the carving or get lazy!
They look so good it will be hard to duplicate.
Share this post
Link to post
This will not come as any new revelation to anyone but Chuck is a great carver. Me not so much. :D
I've played with the boxwood laser cut carvings and though they are really great I slaughtered them.
Soooooo I am using Chucks optional resin castings. They required very little clean up.
Chucks used weathering powders and I did the same. You can see the results below.
You also can see there's still a lot of clean up and touching up needed.
IMG_2677.thumb.JPG.b129415b6078c016027fcc7dae9b575b.JPGIMG_2676.thumb.JPG.2da48c08a90990695555f0c34509391c.JPG
Share this post
Link to post
Thank you all for your kind words and likes It's very much appreciated.
This is how I did it which fairly closely follows Chucks instructions.
After any flash was removed the resin pieces were washed in a mild dish soap and warm water.
The first power applied was "gritty yellow".  Then "highlight white" followed by "dirty brown".
The powders are applied with a clean brush. Small amounts at a time.
If I had too much of one color I'd just alternate powders until I was satisfied with the look.
Once I was happy with the result the pieces were sprayed with two light coats of Krylon clear fixative.
Thanks for stopping by!
Share this post
Link to post
While waiting for my barge kit, I ordered two sets of the boxwood carvings to practice on and I certainly needed practice. Of the 4 Queen Anne monograms, I murdered three before I finally got a feel for what I was doing. The fourth turned out rather well.  The carvings for port and starboard where a little tricky but between the two sets I have a set for the barge.  I took photos of my trials and tribulations.  I am also planning on covering all the moldings with real gold leaf and I plan on documenting that process as well.  With a little luck, I hope to put up a “mini” build log for the entire process. It’s been pretty challenging, but I’ve begun to develop a whole new skill set.  Something which drew me to model ship building in the first place.  I’ve posted a photo of the monogram below.
Best,
John
Edited by Landlocked123
Share this post
Link to post
Best,
John
Do you mean the Gold Foil Leaf or Gold Leaf Paint?
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
