Santisima Trinidad by md1400cs – FINISHED - OcCre - 1/90 - cross-section - bashed
very nice.........hull side looks sweet!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Hi Mates,
Thanks for the likes and nice comments. Finished up the lower gun deck inner wall timbers - added lights, then slid its deck into place. Need to add nails here and there along with hooks for carriage blocks/ropes to those inner wall planks, as well as to the wales on the port side.
Used the kit provided knees – they are not "correct" but fit really well - and won't be too noticeable, I hope.
Going to try to salvage, and fix that deck framing that did not work out earlier with this build– might be ok for mid-gun deck?.
1.thumb.jpg.c629c45487d06d4f4f391768e2f001a4.jpg2.thumb.jpg.64e1d6196bb644b2c6966fdf16c68bc5.jpg3.thumb.jpg.c09e9690c4c925a48be3fcd1cc08ff39.jpg
Edited by md1400cs
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Link to comment
Minor update, did not much care for the kit provided ladders, so used some after market bits as well as adding some extra details.
Happy with the results – especially seeing that the just installed lights are also working properly.
1.thumb.jpg.ded55866178ab2aea864bd7a334b1079.jpg2.thumb.jpg.3f2912e2561e8dbd059c8c58e5d321f6.jpg4.thumb.jpg.73affe6b948bfea8b5d9070024aa56dc.jpg5.thumb.jpg.d7d0e9ea44176493fff016404e2dcd6f.jpg7.thumb.jpg.603adc1e26f2768522f6369565f3ef01.jpg8.thumb.jpg.235890985cab572717c16a553d157c36.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
looks really nice Michael  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looking very sharp!
"A Smooth Sea NEVER made a Skilled Sailor"
- John George Hermanson
-E.J.
Current Builds - Royal Louis - Mamoli
                    Royal Caroline - Panart
Member : Nautical Research Guild
Link to comment
Denis, E.J,.
thanks mates !
Now thinking of how to add extra details to brass guns. Will post some ideas....
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Martyn,
Thanks - yes I remember your light nightmare with your ST cross (though it did work out very well indeed)- As I keep adding lights percentages for failure go up, don't they. Hoping to add at least six more lanterns -
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Thanks Frank,
PS: on page 3 I have a complete explanation regarding light choices, power and where to buy - much easier for you :)
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Hi mates,
Preliminary cannon barrels detail upgrades.
Intended to run breech rope through center of carriage – but then decided to instead run rope to the barrel’s necks and looping - as many have done. In this case did not like the look of it (lack of proper neck)
Hence the added detail needed for guns themselves.
Here out-of-the-box;
Also noted an Issue with kit provided brass wire –much too thin
and trunnion holes were also too thin
easy fix indeed
3.thumb.jpg.a0b01e485e306f36e2bddb58e7fcfdf1.jpg4.thumb.jpg.76e72e2e152469d1d3a7cb0b22d1c3b1.jpg
Now also added detail bits to barrels. Emblems from Syreneasily curved. Just testing at this point – once barrels are air brushed emblems might look just perfect indeed. Washers were intended for the wheel axles, but did not fit -so plan "B" struck - hmmmm
 5.thumb.jpg.b5d838fdc5998190b0f60ea1e25cda48.jpg6.thumb.jpg.fc6d7af9b49bd2c9fdb818a2952de4be.jpg
One issue – not crazy about the location of the gun's second reinforcing ring, my looping the dolphin over might not be correct. But it appears to be at the 50% weight of the barrel. Any suggestions mates - should I move the dolphins forward a bit – though they should be just above the rimbase – I think??
PS: Used Gorilla Super Glue Gel – the bits are very secure….
7.thumb.jpg.1cc9a001733f64b9d3da843dfe97da82.jpg8.thumb.jpg.61aea9ee1cc119336edbbb2c5e14dd88.jpg
I will do the others then get the air brush to do its job
As always thanks for your help, dropping by, and the likes
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
cannon looks good Michael....dolphin is a term I'm not familiar with.  are they the two loops you added?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Denis,
they are in fact the two loops. I needed to Google canon part names to come up with my "educated" post haha
Still learning ship part names.
Cheers,
FYI
cannon_partsx1000.jpg.c95d9187500c3b873d7fc94ad41e0be2.jpg762701018_cannonparts.thumb.jpg.909d1246b226b731006ef34b4a149d97.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
don't feel bad....I never knew that there were so many parts to a cannon  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Hi Michael
The cannon looks very good. I think you'r right about the position of the dolphins: They would help handling the barrel and therefore would best be placed above the centre of gravity. If the barrel stays more or less horizontal if you hang it by the dolphins it should be ok - otherwise you could try to move them. But in my opinion another point is more important. As far as I understand the trunnions are part of  and cast with the barrel and should give the impression of being of the same metal as the barrel. Wood wouldn't be able to hold the heavy carriage to the fast recoiling barrel when firing the cannon.
You are on a fascinating journey with this build - thank you for taking us along.
Peter
Link to comment
Peter,
Thanks for your kind words, advice and note. Yes indeed you are correct, trunnions were indeed part of a casting.
So I needed a compromise trying to get a more realistic look. Wood looked to fill that visual void. Alternatively I had thought of ordering some after-market cannons from Chuck (he has great looking brass ones with trunnions [thought prob. not period correct for this build]  - first pic).
But this is such a minor detail compromise that wood it will remain. Pics of the first still not completed carriage/gun. And for all intent-and-purposes the compromise will visually disappear.... and look like part of the casting  :cheers:
Again thank for your kind post.
Regards,
PS: Syren emblems came out PERFECT !!
1716931189_cannonfive.jpg.opt385x382o00s385x382.jpg.35e60bcab2ae0b1a9ca46dfd7715a5dd.jpg428366742_IMG_0187copy.thumb.jpg.1eac66f16d5f44d35e2fd4e944365a99.jpgIMG_0191.thumb.jpg.b297012f603240bd883e2b9ccaadedc0.jpgIMG_0192.thumb.jpg.884ba2a7dc9c84173ece8ec5628c694d.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Pter,
Thanks for your nice post - much appreciated.
Working on some ideas for adding capsquare details to the carriages.  A lock key and chain should also be added - not sure yet --needs paint - will thin some black and carefully apply. in any case I plan on only doing the front facing carriages, and weather deck ones with these added bits.
1.thumb.jpg.19e425b350715b915ae7625d13c9d165.jpg2.thumb.jpg.5e02e49ffbe151c3823ee81d913c56a7.jpg4.thumb.jpg.ee90c9ceb188b4d4eeb8b7a0b4efa3fc.jpg5.thumb.jpg.fbd824660df710f68d94b7833e8a4b94.jpg1893092879_carriagenamescopy.thumb.jpeg.504e363edf5f8fbfbd61482c4c33af0c.jpeg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Your canon assembly is looking incredible! Loving all the extra details you are adding.
-E.J.
Link to comment
good thing you only have to do this to a few cannons {6?}........imagine doing an entire gun deck!  very nice bit of detail!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
E.J, Thanks - much appreciated - Really enjoying following your current log .......
Denis: Yes indeed, doing those two bits reminded me of how glad I am that I did not think of this during the Vasa. That would have really been a bit too much.
Now working on how to secure these first four carriages. Won't post again until they are properly lashed and buttoned up.
In the meantime I did set up the framing timber bends for the mid deck - it will be a relief to be done with these piddly details.
Cheers,
IMG_0242.thumb.jpg.129fc62650d2540ed6b3d065efb8de60.jpgIMG_0246.thumb.jpg.a33f31ee0a62777ddf9b086929e44d8d.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Hi mates,
 So - got sidetracked thinking about my last build and the canon door ropes simply attaching to each door and burying rope ends inside the hull.
Then, this being my first cross-section, the interior becoming the primary reason for this type of build, I started wondering how those door ropes were raised or lowered and how they looked from the inside.
Googled some searches and came up with these two solutions. there was one other but ignored it.
I think that I will use the single block pulley one – the double block version would probably be better suited to larger wider gun doors that had two ropes attached to the outside of each larger door. And having to do twelve of these it would be easier as well. Here are some shots of what I came up with. Also those double blocks are too crowded looking.
I also need to add treenails to deck here and there –hmmm forgot to do those bits.
Cheers,
1.thumb.jpg.e84e8d939b95e259c6628612700d0333.jpg2.thumb.jpg.f0dc7a4daf5662de4fd2396339eaf356.jpg3.thumb.jpg.a8f0301c22018c2552ee8641ddd371bb.jpg4.thumb.jpg.093fb40792ac27061eab40a084cd7f3e.jpg
Edited by md1400cs
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Beautiful work Michael.
During my visit to Vasa I took this picture. Looks to be a simple but effective solution.
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
Patrick,
Thanks for the post. I had not thought to looking at the Vasa museum photos, but given that these two ships were separated by a century or so - I did not..(Santisima 1769  Victory launched 1765) Yes diff. countries 😊.....
This lead me to do a Goole 17/18th cent gun deck images search. I also looked at the HMS Victory - so many actual photos available, and same  vintage as Santisima. Below is the Victory photo. That is the one  design that I ignored because it would have added details that would have been almost out of view. But it got me thinking of using blocks for the leverage potential. Then found photos of a kit one of which used two blocks, and one that used only one.
Yes the Vasa solution is indeed  an even simpler solution. In fact that was my thought in the first place even before doing any searches. But I think that I will stay with the single pulley/block idea "just because" (In American english) that means one does not have an actual reason for something, but will do it anyway :D I would imagine that every language has a similar phrase.
As always thanks for the help, posts and likes !!!
PS: Almost all images of gun decks excluded the gun door ropes.
Regards,
hms-victory-is-a-104-gun-first-rate-ship-of-the-line-of-the-royal-DME4YG.thumb.jpg.febfc297c985cfb9af4bf747b56ddb96.jpgms4005.thumb.jpg.8bb741a3d84a0d75a574d1c539e4a63f.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Hi Michael
I believe but could be wrong that the tackle for the gunport ran along the beams above like the picture you show from the victory, ports on the quarterdeck and forecastle didn't usually have ports and were open as was the deck, I'm not sure that a sideways rove tackle as you show and on the picture/gun station above is correct, tackles usually pulled in a straight line not around a corner unless with a sheath
Regards
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Hi Michael,
watching your build, I’m learning something new every day!
i think Paul above has made a good point.
looks like there would have been a lot of chafing if the rope had to bend 90 degrees around a corner to the side.
Tackle on the ceiling seems to make more sense!
ill have to check the Constitution next time I’m in Charlestown, Ma.
nice job,
Frank
Link to comment
Paul, Frank,
Thanks for your advice - this is new territory for me - so the help is much appreciated. You are both certainly correct and as Frank thought - the chafing would also become an issue. I just did a search of the USS Constitution, and the ropes are also indeed pulled from above.
Easy fix - in that the middle gun deck has not been installed, I can add the ropes/blocks to the upper beams before installation.
Thanks Guys
Cheers
Edited by md1400cs
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
One last bit  -- found this one that loaded right after - super interesting indeed.
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
Hi mates,
Finished up the lower gun deck. Rigging was time consuming, but looks to be worth the effort. Need to do a bit of black touch-painting, add a few treenails here and there, add knees, sponge poles, buckets, etc..
Now on to mid gun deck need to; Add lanterns, block and tackle for the cannon doors….
Not sure what to do with this deck?? Thinking of just leaving it more-or-less as is – (not adding four more fully rigged guns and carriages along with extra planking). My intensions were to leave as much visible as poss. with this cross section. Will install the stairs. May add just one gun to that deck towards the aft. :default_wallbash:
Here are some updated photos. As always thanks so much for following, visiting, and helping
Cheers,
1.thumb.jpg.00777b22ada66ee5a894b5a53b7356b2.jpg2.thumb.jpg.7bb1e3cb9c402ef97bb9ab3c402e24ea.jpg3.thumb.jpg.8404e8fd0f2acd3ab096a0e22cb6d478.jpg4.thumb.jpg.d491e883df9bb818f223eabd77503410.jpg5.thumb.jpg.501779bb32a6c5fa85a4ea6e13bf5e75.jpg6.thumb.jpg.40253a0b11c559362df577dd95558334.jpg7.thumb.jpg.7e83c1fdf54270daa3888d082e2a8dcc.jpg8.thumb.jpg.f1a3fdd95458fe9dd651913c61847656.jpg
Edited by md1400cs
Michael
Under the table:
Completed:
Vasa-Corel -
Link to comment
I think that the ropes that lie on this deck are for the gunport doors on the deck below
Regards, Patrick
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
