HMS Kingfisher 1770 by Remco - 1/48 - English 14 Gun Sloop - POF
Glad you solved the brass problem.  It looks rather spiffy . . . hmmm, near perfect  ;)  Gonna blacken it I assume?
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Share on other sites
Remco,
besides the outstanding metal work, i am struck by the joints in the wood. Can you remind me what you use to show the joints, and how do you get these to be so perfectly even along the length of the joint?
Link to comment
Thanks all.
Mark, for delicate enhancing of the joints I use a pencil, but to simulate tarring like the joints on  the rudder I use very thin paper (probably 0.1 mm thick). It comes in different colors but it's not water proof so I use the white one and tint it with a black Sharpy. All joints are lined on one side and after gluing the pieces together I used a plane to shape the rudder and trim the excess paper lining.
Meanwhile the metalwork on the rudder is continued, the pintles and spectacle plate are made from separate pieces silver soldered together. Piet, when all metal work is ready I will try to brown them (instead of blackening)
Here they are temporary fitted
I noticed the hole for the tiller sits to close to the top of rudder, In need to make a little fix to lower it :(
I'm not sure how that happened......
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Very nice work Remco; that is incredibly fine joinery and metal work.
Ditto on the assembly/soldering board - can you provide name/type and purchasing details please?
cheers
Pat
Link to comment
Beautiful work Remco!
Cheers,
                       VOC Ship Surabaya
Link to comment
Remco the metalwork is superb, however I am still getting my head around the stunning joinery on the rudder sections. Nice way to solder the small elements on the corners.
A Master Craftsman and Artist you are Sir.
Michael
Link to comment
And the rudder is beautiful!
Maury
Link to comment
Link to comment
Hi Remco. Great work sir and have a question for you. The pins you have stuck in the soldering board, what are they and if purchase when can one buy some?  I got one of these soldering boards after seeing yours but so far have not found the pins. Thank you sir and keep the photo's of your build coming. Gary
Edited by garyshipwright
Link to comment
Thank you all for the kind words. For those interested in the soldering board, I purchased it here they also have the pins I use and some hold down clamps I didn't get but made them myself.
Beware that the board quickly heats at the bottom so you should place extra heat protection underneath it (yes I found out the hard way and now I have a big burn mark on my bench  :angry: )
Remco
Link to comment
WOW, the whole rudder is a masterpiece, superb work Remco.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
Beautiful work as always, Remco.  II really like the  idea of removable struts on the eyes on the spectacle piece.
Ed
Link to comment
Hi again Remco,
Would you be able to identify the soldering block and pin jig you use (see a copy of your photo below) - Is this home made (drilled)  from a solder block or is it a commercially available product please?  It looks commercial, but with your skills I would not put this past your abilities :)  It looks a very useful jig for such jobs.
Many thanks
Pat
Link to comment
Thanks Druxey - I need my wake up pills I completely missed that - thanks for the pointer Remco
cheers
Pat
Link to comment
A long overdue update, be it small is more than one way :)
The tiller hole was repositioned and the hoops were added
The pintles are browned, bolted & screwed to the rudder, (okay I simulated the screws.....)
Next up the Gudgeons, any ideas how long they need to be? TFFM only shows one, are #2 to #5 all the same length?
Remco
Link to comment
Remco, I cannot believe you actually simulated something.  Maybe you are human. :D
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Hi Remco,
I made my lowest one 36mm long and the second from the top one 19mm. The middle ones are in a straight line on the forward ends between them.
:cheers:  Danny
Cheers, Danny
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
