HMS Victory by GrandpaPhil - Mantua - Scale 1:98 - Kit-Bash
The beak head bulkhead is done and permanently installed.
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Share on other sites
Ye olde head:
It’s only dry fitted.
Link to comment
Ye other olde head:
Link to comment
I’m building the head gratings IAW zu Monfeld’s drawings.
Link to comment
I have the framing for the head gratings in place.
The first set of seats of ease are painted and installed.
I have a few more pieces to make and install so I can paint the framing.  Then I will start the gratings themselves.
I am going to use the exact same method I used on the Prince de Neufchatel to make the gratings.
Link to comment
The gratings now have something to sit on, so next step: painting.
Link to comment
That looks smart.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Just a suggestion phil  - where the beak head comes up and you have it flush with the heads decking,  it would be good if  you made an extion of the beak head as I understand it was designed  so the  bowsprit  can rest on it.
You would need to test dry fit the bowsprit  first  to get an idea  of how much  gap there is under neath where the beak head comes through.
OC.
Current builds
Completed works.
Link to comment
Okay, will do.  Thanks for the tip.
Link to comment
Beakhead extension
Link to comment
The head gratings are in place.
They need some trimming and some paint work.
The knight heads are just dry fitted.
I extended the beak head and will paint it when I paint the gratings.
I just need to make two fashion pieces that sit on top of the head rails and two double seats of ease and the head will be complete.
I’m holding off on making the boomkins until I get further along so I don’t break them.
Edited by GrandpaPhil
Link to comment
39 minutes ago, GrandpaPhil said:
Beakhead extension
Thats the ticket phil, should help the tention  on the bowsprit  when you fit it and rig it.
OC.
Current builds
Completed works.
Link to comment
Very tidy work phil, coming together now.
OC.
Current builds
Completed works.
Link to comment
Thank you for the likes and the comments!
I have the double seats of ease made.  After they dry, I’ll bevel them to sit level on the head gratings.
Link to comment
The seats of ease and the fashion pieces are made and on.
Except for some minor paint work, the head is done.
I started drilling the holes for the gunport lid rigging.  I have the port side done.
Link to comment
I finished the head, except for the boomkins and the netting.
I’m waiting until I get to the masting and sparring stage before I install the boomkins to prevent accidentally ripping them off.
I’ll do all netting at the same time because I have to install netting all along the rails.
I’m currently finishing the sides, then I’ll start at the front and work my way back on the deck fittings.  Maybe, we’ll see.
Either way, I’m having a lot of fun working on the Victory.  Deciding to scratch build the rest of the model was a good decision.  I’ve been having a lot of fun with it.
I just finished the hardest part that I had left which means that the rest should go smoothly (aka: I’ve already been down this road).FD51AB56-6B1A-415F-980A-EBF96819FA13.thumb.jpeg.e1b5064a00b8e4586debec253608befb.jpeg180DB415-66DE-40D1-8C39-4E3028D1D2D7.thumb.jpeg.fca429df8732770ae1aa15fa6a2ddd36.jpeg24B52C23-2975-4BD1-BC32-39B54B2106F3.thumb.jpeg.9096c240d7e8c05ebcb86dc52410e800.jpeg
Link to comment
I found out that my rigging line doesn’t fit the HO eyebolts that I used in the gunport lids.  I need thinner thread.
I also didn’t like the way my decks looked. So, I started making gratings...
Link to comment
Thank you very much, Mark!
This build has been a learning experience.
I’m getting better.
Link to comment
Phil  just another thought about your beakhead gratting,   dont foreget  you will need to feed the gammoning rope  that comes up from the beak slot/s, and  wraps around the  bowsprit  several times thats then seized  in the middle  under the bowsprit.
OC.
Current builds
Completed works.
Link to comment
OC,
  I know, I thought about that.  I was planning on cutting slots for the gammoning after the gratings dried, but I forgot.  Thank you for the reminder.
The Victory is the first ship that I’ve built which has a double gammoning.  This should be interesting (but fun).
Link to comment
Thank you very much, Richard!
Link to comment
Happy Thanksgiving everyone!
Link to comment
The gratings for the forward deck are made.  I have them sitting in place until all are done, then I’ll paint them and install them permanently.
Link to comment
Very nice work phil  happy thanksgiving to you and yours.
OC.
Current builds
Completed works.
Link to comment
Thank you very much, OC.  Happy Thanksgiving!
Link to comment
The gratings are all made and the deck hatches by the main mast are made.  The galley funnel is partially made.
I cut slots in the head gratings to pass the gammoning through.
None of the deck fittings are painted or glued down.  I still need to shape the funnel and make the end look hollow.
I need to make the pin rails.
Due to the scale, I am using straight pins for belaying pins again.
I still need to make the bellhouse, the skylights, the wheel and the binnacle.
I also need to make the ladders and my remaining guns.
Link to comment
I have the companionways ready for the ladders.
Link to comment
Thanks for all the likes!
The decks look better.
The fittings are just sitting there, and I still have many more to make, but I’m making good progress and I’m feeling a lot better about this build than I was.
The holes in the deck did not make me happy.
Link to comment
I glued down my deck fittings.
I painted the bulwarks.
I am much happier now.
This model is a hybrid.  My modeling skills have significantly developed in the two and a half years since I started working on it, so I have many problems to fix, or just live with.
There are many areas where I have ripped stuff out and replaced it.
The areas such as the stern and the quarter galleries, and the wales, I’m leaving alone.
I could make the stern and quarter galleries better than the brass sheet.  I will make the wales (which are too narrow) correctly in my next build.
However, the amount of damage that I would inflict ripping them out, is not worth it on this model.
So, I will leave it as is and move on.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
