HMS Victory by GrandpaPhil - Mantua - Scale 1:98 - Kit-Bash
Hello Phil,
I've been following along on your build and it's coming along very nicely indeed.  Your painting of the grenadier is top notch - the coloring is perfectly subtle and subdued, and the shading is spot on.  I wish you continued success.
Gary
Completed Scratch Builds
Link to comment
Share on other sites
Thank you very much!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Thank you all for the likes and the comments!
I made my port-side chesstree and installed it.
I also installed the second fender on the port-side.
Link to comment
The starboard side chesstree is made and installed.
Link to comment
I made and installed both of the anchor palm blocks.  They were carved from 1/4” basswood sheets.
At this point, the majority of the hull fittings are done.   I need to clean them up a bit, and then I’ll touch up the paint down the sides.  I still have some boat davits to make, but I will make those when I make the railings, the hammock netting and the boomkins, netting and anchors up by the head.
The head is mostly done (except for what I just mentioned).  The stern is mostly done  (except for the boat davits).
Next up will be the upper gun deck.
Edited by GrandpaPhil
Link to comment
You constantly have me looking up terms-chesstree contains a sheave for the mainsail
Link to comment
1 hour ago, Emmet said:
Seems silly but I have looked everywhere trying to find a way to add a second page to my log.  Does it just happen after adding a zillion pics or is there a way.
When there are enough comments a second page will appear. You probably want to post these type of site questions here though: https://modelshipworld.com/forum/47-questionsinstructions-on-how-to-use-and-post-to-this-forumsite-problems-or-suggestions/ so they aren’t buried in a build log.
Link to comment
On 1/1/2020 at 11:30 PM, GrandpaPhil said:
I used my new contour gauge for the first time to take the contour of the upper hull for the starboard fenders.
Hi Phil,
What a great idea, l never thought of that, l shall get one of those for myself.
Great work on the Victory.
Best wishes as always,
The Lazy Saint.
Link to comment
It’s a useful tool.  I found out about them on this forum (I don’t remember who had it).  It’s perfect for anything that has to be fitted to the hull.  I also intend to use it to make the cradles for the ship’s boats.
Link to comment
The Victory now looks like she belongs to Nelson’s fleet.  The port side is painted.
Link to comment
As soon as I saw your post I ordered one with the idea of making cradles (and for whatever other uses like you’ve found).
Edited by VTHokiEE
Link to comment
The black is done on the starboard side.
Link to comment
Thank you, everyone, for all the likes and the comments!
I painted the starboard side.  I’m happy with it.
Time to fit out and arm the upper gun deck and spar deck.
Forgot the picture
Link to comment
I installed the ladders.  They are made of poster board.
They aren’t perfect, but they are the first generation of ladders that I have scratch built.
Link to comment
I’m starting on the cannons.  I had a blast making them on the Prince de Neufchatel, so I’m making the rest of them for Victory (plus I liked mine better).
Link to comment
One 12 lb long gun.  The first of ten.
Link to comment
Great work on the gun barrel Phil, power to you for the others. 😅
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
I’m glad you guys liked them.  I made three today over the course of an hour and a half.  Once I sand them all, they should turn out like the last set (I think those turned out well).  Although, at 1:98, they are much smaller than last time.
Link to comment
I made my fourth cannon.  It’s actually the fifth, but I threw one away because I used a dull blade on it and it split out on me, beyond what I can repair.  I put a scale next to them.
I integrated the cascabels into these, unlike last time, where I glued a seed bead onto the back end of the cannons.
Quick note: I am using a scalpel to carve dowel rods.  These are not turned.
Link to comment
I made a mistake tonight.  I cut my fifth 12 lb long gun too short.  So, it is being made into one of two bow chasers (a medium length 12 lb gun).
Link to comment
Oh oh good save Phil 😆
Current builds;
Completed:
Link to comment
Handcarving-pretty neat
Link to comment
Thank you all!
Here is the first bow chaser:
Link to comment
Looking mighty fine phil,  the more you do  adds  so much to the build.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
