USS Confederacy 1778 by CRI-CRI - FINISHED - Model Shipways - scale 1/64
I did't found Chuck's mail adress
I publish also my message here, without another solution :
Hy,
I got a problem : the figure head is accidently broken, and I need a new for replacement, if possible
I glued the broken part, without great success (look at attached pic)
Could you send it ?
If you are OK, I shall send you my postal adress
Thanks,
Cheers,
Christian Faivre
Link to comment
Share on other sites
31 minutes ago, CRI-CRI said:
Hi, dear followers !
I did'nt found any laser cut bolster part
Have to do it myself ?
Cheers,
Christian (Next Monday, 75 years old... Nothing else to do, but to die... 😋)
Allons Christian, ne soyez pas si fataliste. Vous faites de superbes maquettes, dignes d'etre presentees dans un museum local ou le hall de votre mairie. Il serait dommage et regrettable pour la communaute des maquettistes, que vous mourriez.
For the missing part, I would contact Model Shipways. They are usually responsive. Of course, the fastest will be to build it yourself.
Yves
Link to comment
I've been watching along as you do a fantastic job! Will I ever tackle such an undertaking, I really don't know? My last build, "Syren" pushed my boundries at just over a year. But you certainly are an inspiration.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Link to comment
I started the brake pumps today : replace manually a round section into an octogonal one was an interesting job !
Pics will follow when finished
Thanks all for your comments
Cheers,
Christian
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
