Centerboard Schooner C. Chase 1846 by Maurys - Scale 1:48 - FINISHED
Maury:
On the centerboard schooner models I have planked, the side view generally as a slight upward sweep coming into the stem, but if you turn the model over and look at it from the bottom, the planks will curve inward at the stem. Thus, the actual shape will have a slight S shape, but not as much as what I am seeing in your planking.
A lot of this has to do with how the hull is lined off. Druxey's illustration should point the way.
As for drop planks, on a hull such as this, I have never seen a drop plank used. On a fuller bow shape it is sometimes necessary to drop a plank. Our local builders would trim down to a minimum of 3-4 inches at the stem, but the strake could have a max width of maybe 7-9 inches. The planking rule you speak of had a lot of elasticity.
Russ
Link to comment
Share on other sites
Optical illusions...My earlier planking layouts consisted of dividing the number of planks along each frame and I ended up with that inappropriate "bump" as seen in post #113 where the pencil is pointing in the second shot.  This time, I ran a (glued) string from the measured point of intersection of the stem piece to a few points along several of the frames and then looked at the line from the side.  From there, I moved the string(s) up or down on each frame so the run APPEARED nice and smooth from the side and a nice smooth line looking from fore and aft.  Blue tape is used for the spacing at the bow without marking the wood.
CC_PlankString1.jpg.4f426cec4bb0ac80014e7d8b8d84ab3c.jpgCC_PlankString2.jpg.384d52a0ca4543ae9473ba2559bfc0d5.jpg
The run is much smoother now as seen the the following pics.
The strings are tacked down only about 10 - 12 frames back from the bow.
Minor tweaks to be done and the planks will appear to come to the stem much more smoothly now and the view from the side will be much closer to Druxey's suggested flow.
Maury
Link to comment
That's the trick to lining out, Maury: first divide the space to be planked mathematically, then adjust things until they look good to the eye from all angles. First the science, then the art!
Link to comment
The new lining out worked fine.  Druxey, thanks again for the reminder that the art still has to come in!
I've removed all the offending planks and re-lined out three bands.
The strings actually line up at the bow...angle distortion.  Some minor tweaking since the photos and all seems to be falling into place well.
Maury
Link to comment
Ahhh,  Much better Maury. Looking good.
Edited by Dowmer
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Link to comment
Druxey, I had that pattern early and from the side view, the big "hump" appeared (see post #113).  By shifting them to how they are now, the "hump" disappears and the line is fair from the side as well as every other view I examine.
Maury
Link to comment
Thanks, Maury. It looks (from the angle of the photo), that the first band of planking above the garboard might have to taper too much as it reaches the bow rabbet. Hopefully that isn't the case! Also, that an angle might appear forward of the third strake away from the garboard.
Link to comment
planking is getting done slowly.
Dark lines are not a gaps...just the pencil marked edge not sanded.
I have to check the 2nd plank below the wale to make sure it is seated in the rabbet...looks like it's come out.
Thinking towards the ceiling planking (inboard).  None of the drawings of cross-sections I have show any limber strakes or boards.  Were those things primarily on naval boats?
Maury
Link to comment
Usually on merchant craft there were no limber boards or channels above the floors. The drainage channel consisted of notches in the floors on their undersides, next to the garboard. Water flowed along under the frames, along the garboards, to the lowest point in the ship. Bilge water was then removed by the pumps.
Link to comment
Thank you Druxey
Link to comment
Planking continues.  Using the sacrificial bass wood for spiling patterns has really simplified the process.  It's really nothing like using card for patterns. Being able to sand to a tight tolerance on the pattern makes a huge difference.
You can see the un-planked window on the port side developing.
Maury
Edited by Maurys
remove link posted in error
Link to comment
Getting near the end of the outer planking...The remaining starboard drop plank(s) have been spiled but not yet bent.
They were shaped and fit but not glued in place 'til everything lines up properly.
Maury
Link to comment
Starboard Planking is done.
I'll finish the port side, leaving a portion unplanked.  Three strakes to go, then some sanding and touchup.
Maury
Link to comment
Whiskey strake is in.  Counter is planked.  I'll finish the transom before reattaching to the building board for the interior.
Rubber band is to protect the stem.
Maury
Link to comment
Indeed, I did.
M
Link to comment
Back to the shipyard after a vacation.
Attached is a photo of a portion of Chapelle's original drawing showing a "Scupper Strake" just above the wale.
Does this mean that there is a continuous opening in the bulwarks or that scupper holes were placed as needed in that strake?  All evidence I've gathered indicates these were "wet boats".  Getting water off the deck would have been important.
Appreciate any comments.
Maury
Link to comment
Are there any pictures of the boat or similar ones of the time period to give you a better idea?
Link to comment
Druxey, That's what I'm thinking. It exposes the frames to wear but I expect the bulwark frames were abutted to the top futtocks and were replaceable.   Dowmer, there is no other info. about the boat than the Chapelle drawing and commentary in the National Watercraft Collection.
Maury
Edited by Maurys
spelling
Link to comment
She's back on the building board and ready for planking the ceilings.
Since the centerboard is off-center, the keelsons are not equal port and starboard.
The first course of ceiling planks will line up for the subsequent strakes.
The first pieces are just spiled, bent and laid in place.  Some more tweaking to be done.
By the way, since Chuck has been praising Alaskan Yellow Cedar, I thought I'd give it a try on the interior.  It's certainly a lot softer than box.  When I sand the edges, there is some fiber left hanging so I'll have to be careful about that.  There is an obvious cedar aroma, so I won't be getting any moths (or shipworms).
Maury
Edited by Maurys
additional comment
Link to comment
More ceiling strakes.  Long-nosed clamps where they fit, Pressure from gantry above deeper into the hull.
Butt pattern is the same as the outer planking, but not on the same frames.
Maury
Edited by Maurys
added comment
Link to comment
While waiting for glue to dry, I knocked out the blanks for the two mast steps.  Notches around the several keelson timbers cut on the Byrnes saw using a sled.  Mortises will be cut once the masts are ready to be set.
The fore mast is on center-line and the main is off-center to right of the centerboard well.
At this stage, the starboard side has one more strake than the port.  BTW, I've started using Yellow Instrument Glue from Luthiers Merchantle Int'l.  Seems to hold every bit as well as Titebond, and has a fluorescent dye that shows up under black light for better cleanup.  About the same cost.
Maury
Link to comment
Nice progress, Maury. Does this mean that the main mast is off-center or does it 'lean' a bit to bring the mast head back to the centerline?
The idea of fluorescing glue is an interesting one. That's a new one for me!
Link to comment
Druxey,
All the info I've garnered about off-center masts indicate they were plumb (head does NOT lean to the center).  This countered the sailing impact of the centerboard being off center (on the other side of center-line).  I've seen quite a few examples in my journey with this build.  Re: glue, I learned of this at  Modelshipworld  link:  https://modelshipworld.com/topic/943-gluing-techniques-and-associated-information/page/4/?tab=comments#comment-628081  post #93 (Thank you Vossiewulf).  The dye really stands out under the black light so you can clean up smudges and spills before it sets.
Maury
Link to comment
This is NOT a full review of the book, hence not in the Book Review Section...just some comments:
The Evolution of the Wooden Ship by Basil Greenhill with illustrations by Sam Manning has been extremely helpful.  Sam Manning's drawings are tremendous and answer so many detail questions that arise in the course of a model construction.
Maury
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
