Trafalgar Class Submarine by Old Collingwood - FINISHED - Airfix - 1/350 - PLASTIC
hey there OC....finally got a chance to see what you are up to :)   off to an impressive start.   it will be interesting to see how your going to improve on this added detail your thinking of  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Share on other sites
Thanks mate,   yep its not always easy to make a round smooth object detailed and interesting, but I will give it a go.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Wife just took note of my sub build   and asked  "where does the batteries go"    :o:o:o
OC.
Current builds
Completed works.
Link to comment
OC.
LOLthats not good news
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
So what did you tell her?:P:D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Admiral said  she neds to be convinced its a submarine ........
Blushing Old Collingwood moment:o
OC.
Current builds
Completed works.
Link to comment
Sort of an update - I have been having trouble with the join line not joining flush despite sanding to two halves,  and even with many coats of paint it looked Horrid, so I tried to apply some styrene cement,  thi wasn't doing a very good job (dont the smallest and least complicated builds tend to give us grief):angry:
So plan number two was to use some C/A  and smear it inside and over the bow nose area.
This was done to some extent and when dry I was able to give the bow (super glued area)  and the rest of the hull a thorough sanding with very fine wet n dry and water.
The result was the affect you get when you sand a car down ready to re spray.
Then it was back on using my little hairy friend and muliple thin coats of dark grey.
No pictures as I didn't have the heart and thought it looked a mess,   still having to use my phone camera also.
Not the best day TBH.
OC.
Current builds
Completed works.
Link to comment
Well, I guess it was a little off-putting, OC. Stiff upper lip and all that, eh, what?
Or as that infamous cartoon character said: "Doh!"
Ken
Started: MS Bounty Longboat,
Link to comment
sounds like it might have been better to use filler........glue would only soften the plastic {never tried CA}.  is it salvageable?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Yeah  it just took a bit of sanding with fine wet and dry,  its had a few more coats back over the whole hull, but to be honest its like trying to paint a glass from top to bottom with a small brush.
OC.
Current builds
Completed works.
Link to comment
If I pull this one off  I think I will have earned the NRG achiever medal of stupid painting endurance.
OC.
Current builds
Completed works.
Link to comment
Type of brush? Kind of bristles? Paint brand?
You won't be let of the hook that easily, to call yourself an achiever of stupid painting endurance you will have to be at it a lot longer mate, note just a few hours. Besides what you find inacceptable could be well within the margins
Carl
Link to comment
OC, for filler I used to use Squadron green putty (also comes as white putty) worked well to smooth and fill in gaps on plastic.  Don't know if it is available in UK, I even have trouble finding it in the "colonies" ;) lately.
Link to comment
"Type of brush"   yep the hairy kind with a handle,  seriously  its a fairly decent size brush that I use for hand painting my Warspite build,   paint wise in using the excellent Lifecolor set of acrylic satins, they are really good.
Its one of those painting jobs - the more thinned out coats its get - the better the finish.
OC.
Current builds
Completed works.
Link to comment
Thanks Jack,   I think I have seen it on flee bay.
OC.
Current builds
Completed works.
Link to comment
OC
Even though I agree with Popeye and Jack that putty fillers are easiest to work with. Another old time alternative if you can't get putty for some reason, is to take left over plastic sprue and melt it in a jar of liquid styrene cement to make a paste. If you use the sprue from this kit, it will even match the color of the original plastic. Not as easy to work with as drying time is normally at least over night, even when used in small areas, but the results can be pretty good.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
2 minutes ago, lmagna said:
OC
I have seen that mentioned before,   the only experience I have with molten sprue  is with aircraft kits to make arials and comms wires, where you would heat up one of the lengths of sprue then pull it till it became a very fine string.
OC.
Current builds
Completed works.
Link to comment
I decided to mask the hull into sections to aid hand painting,  I did this in equal sections so as to look natural when the tape is removed,  just the one pic.
OC.
Current builds
Completed works.
Link to comment
I've used fine grained auto body filler (Bondo here in the US) to even out the divots on plastic. Has a strong odor, so wear a good chemical vapor mask. And do it outdoors (peace in the family, lads).
I have also seen folks using superglue with fillers. But you need to sand smooth fairly soon after you do that. Otherwise the superglue gets harder than the plastic and you remove the wrong parts.
Ken
Link to comment
Now that Ken brings it up I remember people used to use CA and baking soda. Fill the area with the baking soda and zap it! Stan away from the smoke though!:o Sets up instantly!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Here's the result after taking the masks off and giving the hull a gentle wash with a soft sponge.
OC.
Current builds
Completed works.
Link to comment
Back in the 60's/70's they used to make a filler for the model cars... wasn't a bad odor and very sandable.  I guess they don't make that anymore?
Link to comment
I remember that stuff, kind of a tan color? Absorbed paint like a sponge, too. Used it a lot for custom car models.
Ken
Link to comment
That's the stuff, Ken.  Came in a tube as I recall.  A bit of brush on primer and a light sanding would sometimes but not always stop the absorption.
Link to comment
Yeah, mark. Although way back when any idea of using a primer was not in my work ethic. Learned that with airplane models.
Ken
Link to comment
Looks like all your effort paid off OC, looks quite nice from Florida.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Cheers,
Thanks piet.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
