HMS King George V by RGL - FINISHED - Tamiya - 1/350 - PLASTIC
Sigh, to prove a point that Pontos did not use the KVG for their KVG upgrade, the bridge piece is s not the same. I’m about cross eyed from the wind deflectors. It is easier to break the piece apart and instead of a 1 piece requiring 15 bends, it’s 5 pieces requiring about 3 bends each.
As you can see i had to use a razor saw on the flybridge to get the side panels on. The Instructions say this piece is flat.
Greg
Link to comment
Share on other sites
The chinese make it look easy at Pontos  - must be thier small fingers.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
You have certainly mastered the manipulation of PE Greg; looks great! That shot of the dry fit sure shows how much detail was on these beasts.  A wonder you don't get RSI from all that PE folding.
cheers
Pat
Link to comment
Pat, he gets HSI, and ESI
At least you got value for money, Greg, kept you busy for quite a while ...  See you got rid of that humongous signature too, I hated the thing, every build meant I had to update. I know what I build, it shows (or not, depending on the quality, so very little shows)
Carl
Link to comment
amazing the amount of PE that went into these two structures so far.    looks great so far Greg :)   really nice the way you boxed off that bridge part.   judging from all the PE scattered around........your amassing quite a stock pile.  super job so far!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
you probably have a good amount as well.  have you done anything more with that IJN ship you were working on?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Octtuplet 20mm cannons. Over a day’s work to do 6 of them, individual barrels, ammo cans, brass and resin.
I wanted to do these up first to see how they fit on top of the main and secondary guns to measure up the railing stanchions that go on top of them.
You can see the three piece gun in the centre is just no comparison
Greg
Link to comment
Those are Superb greg,   I have them on my warpy kit in the pontos set.
OC.
Current builds
Completed works.
Link to comment
Jewels versus tinker toys with those 8 x 20mm cannon. Cross-eyed yet? ;)
Ken
Started: MS Bounty Longboat,
Link to comment
5 minutes ago, RGL said:
And a bit shaky
You need some rum.
OC.
Current builds
Completed works.
Link to comment
So Pontos barrels and ladders, handrail stanchions will be added after painting to keep them very fine. Pilot holes drilled, 1 unbroken.3mm left.....
The A turret is simple, just needs some stanchions added for handrails, I added a hatch on top, and some windows at the front of the range finders.
The B and Y turrets will have 20mms on them. Pontos gives you the option of the ‘’as Built” useless rockets for the ‘41 version.
I trimmed off the blobs on top on top that were proporting to be ammo boxes which I’ll replace later.
The back of the turrets have access hatches added.
Masts and cranes to go as major build pieces.
Greg
Link to comment
Aye, so much better ...
1 hour ago, RGL said:
I have Soo many spare IJN ammo boxes I had an idea.
Eureka ... that happens once every while ...
You have made some great progress blinging things up. When you look at it, the barrels are not really a challenge, neither a vast improvement, but the additional, undelivered pieces, e.g. the hatches at the back of the turrets, you use, to finish it,make it complete ... the cherry on the pie.
Marvelous
Carl
Link to comment
Today’s effort, the fore mast. These things are always a pain to build. I added the type 293 radar to it which used to sit between the forward secondary gun directors.
The little radio room is not glued in yet (none of it is for ease of painting, so there needs to be several more ladders s added later plus more rigging.
Greg
Link to comment
Tell me about it ... often not just the fore mast, sometimes the rear as well. Despite the pain, it turned out rather well ...
Carl
Link to comment
Ships cranes. Instructions tell you what the parts are and where they sit but not how to put the thing together. Just horrible. Not intuitive, not like the real thing either.
I wanted them moveable but it just does not align properly, do doubt it’s my fault but instructions would have helped. A lot.
Greg
Link to comment
Despite your frustrations, they look good. I wonder if you would be able to get them "fully" functional, since you would have needed a certain amount of friction which you do not really get with PE, or loose real fast. You can still make them twirl though ...
Carl
Link to comment
Real nice work Greg. That pe really makes a difference for detail.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Can't recall exactly what I had to do because it's been more than a year since my DoY build, but I used fine wire as pins to hold the crane boom to the cab as well as the piece attached to the boom and all the pieces were movable including the swing pivot/shaft that went into the deck. If I remember correctly, I may have had to re drill the holes in the deck for those to fit. Is that where you had problems getting things lined up, Greg. At the deck?
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
